Upgrades to 2000 2500 for towing
I've got a new to me 2000 2500 2WD Regular cab with NV4500 transmission and I believe the HX turbo (rubber wastegate tube). 190k miles and no idea how many miles on or even what injectors it has. I'm looking into upgrades to improve towing performance with a 14000lb trailer (20k GVW). I'm not looking to have huge HP or Torque, just to have a decently powerful, reliable and efficient rig. I definitely don't want to upgrade stuff and push it beyond its limits.
I don't currently have a EGT sensor. I know I need one.
I've already put on the GDP mechanical fuel pump so hopefully I won't have to worry about the VP44 dying for lack of pressure. Running 2 stroke with every fill-up.
I live in Colorado and have a 35% opacity limit on smoke coming out my tailpipe.
From what I've read I should just do what MoparMan himself has done and get 7 x 0.10 injectors and a Quad V2. I'm concerned about emissions if I have to remove the Quad to get it tested. I'd rather not tap the VP44
  • SAC or VCO?
  • How bad is the smoke on 7 x .10s without the Quad?
  • If I clamp the waste gate (and maybe use a boost fooler) will that solve smoke issues of running without the Quad for opacity inspection?
  • Do I definitely have to upgrade the clutch?
  • Do I definitely have to get ARP headstuds installed? Can I put in headstuds without a new head gasket?
How well do RV275s work for towing without a chip? Would I still have to upgrade the clutch? Do RV275s need a boost elbow and fooler to get enough air?
Anybody do a death wobble steering stabilizer mod?
The articles section is great on this site but it sure would be cool if there was a "list of stuff that works together" page that collated some of the great info floating around in the forums.
Thanks for the help,
Justin
  • Replies 64
  • Views 16.3k
    It's only taken me 17 years to get that far...  Quadzilla +150 HP VCO Injectors (7 x 0.010 @ 320 bar) 425 ARP head studs Exhaust brake 4" Exhaust  South Bend
  • For the money spent and the lack of necessary supporting mods, I would go with an Edge EZ and RV injectors. The EZ does the boost fooling and comes with a boost elbow for the wastegate hose. The RV's
  • Ez and rv275's should pass emissions without trouble.       Gonna be ~300hp which is plenty for towing.  Def need a boost elbow
9 hours ago, pepsi71ocean said:
NJ, Its become a **** show here with cops cracking down on smoke. And it used to just be only in certain parts its becoming more open. I was driving past a check-point today (in the other direction) and they had 3 diesel pickups pulled in and other cars, and the diesels were on the emissions testing area in the parking lot.
I hope it stays on that side of the river. I don't condone excessive smoke but I do have some soot on my mudflap. And who's to say it didn't come from off roading in the pine barrens the night before? NJ was always a little umm, diffferent.........
I built 2 CFA's in NJ. Mt Laurel and Howell. Howell was all union. Had some good people on the job but I never could grasp all of the union rules and regs.
The biggest mistake I made was pulling into the gas station and started pumping my own fuel. The guy in the kiosk liked to had a heart attack.
Edited by dripley
Are you saying it's becoming illegal to put your own fuel in :think:
In NJ, yes. Maybe not every where but @pepsi71ocean could enlighten us I'm sure. I did manage to find a couple sef serve pumps but yhey were off by themselves and had hellacious fire suppression system around them.
Really simple if you want to watch he pop pressure of your injectors. Just plug in a live data tool and watch the engine load. If it falling below 5% engine load the injectors are below the lower limit. If they start gaining idle RPM like instead of 800 RPM your getting 850 RPM then the injectors are well below 260 Bar.
It's been that way everywhere I've been in NJ for as long as I can remember.
It's that way in Oregon too. You can't pump your own fuel unless if you have a commercial account at one of the commercial filling stations. They are often never crowded and It seems to be a little bit better fuel quality, at least psychologically so :thumb1:, but you have to buy at least a thousand gallons a year to keep the account open. I like em cause you never see folks with yellow mohawk hair driving a Prius.
I think Oregon turns all there pumps off at night. I made a 600 mile run across Oregon most of it after midnight came into idaho after burning fumes for hours it seemed.  Tried to get fuel and pumps were turned off I was on back rds grrr.  Crystals wakes up cause I pull off for fuel I never stop for fuel. What's wrong. Well pretty sure were going to run out of fuel in the middle of nowhere. On a  strange rd with shoes hanging from the trees..
I ran 3rd driving by instant fuel meter thing and made it across the border. She was out took 34 gallons
in California you can't even get a homeless to pump your gas for money. nearly all station you pump yourself
You can legally pump diesel in OR at any station.  I do it all the time.
On 6/26/2019 at 10:58 AM, backcountrymountains said:
 4.10 will pull anything, right?
Does your truck have a 4:10 in it now?
On 6/28/2019 at 12:47 AM, IBMobile said:
If your from another state and just passing through NJ they can pull you over for a smoke test?  That doesn't seam right that they can impose there state regulations on an out of state vehicle.  What happened to interstate transportation with reciprocity.  .
One can question the legality of it. But most of us also don't have stock trucks either. And they see a gauge pillar or a edge on your dash they will call the njdep over and they will test you for federal emissions.
I was passing an check point (going the other way) the other day, and they pull people in. They don't care for what reason. If you have a truck and njdep or njdot pull you over expect to be looked over. I've seen guys from PA get popped with farm diesel when they dip the tanks. I've had njdot make me open my fuel water filter drain and they've looked at the color of the fuel.
NJ passed the law in 2016 and they will find things. A friend of mine got nailed on his 2008 Dodge being deleted and he put out a puff of smoke for 1.5 seconds. The law said a maximum of 3 consecutive seconds. So 2.9 seconds is good, 3.0 is bad. Anyways, $15,000 in fines later he's still trying to get that paid down.
I'm up in PA this weekend and I heard they changed the laws in PA for emissions testing now are only required after 7 year's. And certain weight classes for diesels now as well?
Depends on where you go. I've seen cops walk up and hand people the $500 fine for touching that pump nozzle.
Some places are forced full service. Reguardless of it being diesel or not.
Welcome to the people's republic!
That's a well written article Mike. I'm still happy as a pig with mine. Might as well as me in there too at the bottom.
7x.09@322BAR and no issues starting up down to 20°F.
Most of NJ is this way as well. Better get your gas before 9pm, most stations close between 8-11pm. Rural areas closer to 9.
 songs like New Jersey is worse than California, I hope it's only these two states. I don't want any monkeys putting anything in my tank. What is happening to America anyway. So much for freedom, the whole world is going nuts.
In NJ I believe it was to be sure the man in the kiosk did not loose his job. When I first started driving self service was unheard off. Cant tell you how many people put gas in my tank until I was in my 20's. Most of them smoking a cigarette.
That's just wrong for some reason, idk. I've been fortunate enough not to deal with it I guess
I agree with this NJ system being wrong and un American , There is a difference between the old style full service station where you paid a little extra for someone to fill your tank and check your tires and oil and wash the windshield.  vs.  a Law that says you can't pump your own fuel. I hope stuff like that don’t spread through out the nation, probably has more to do with law suites, lawyers and control
I can remember working at full service stations when I was in school, I got a lot of dates with that job. :lol:
Over here you do it yourself everywhere, might just get the very small stations out the back of beyond still filling for you but I've not seen one in years,  my Mum worked at the village station where we lived for 30 yrs and a good portion of that time pumping fuel.... thing is Benzine in petrol causes a type of cancer which my mum got.... so this probably has something to do with own filling here.. better someone pumps a little than every minute of every working day.
Its more about the people, we Jerseyans are stuck up, every time this comes up on referendum, the idea of self serve, it fails. I'm not sure if it will ever become a self serve state.
In what way?
I'm not understanding, are you saying pumping your gas is wron, or hem playin emissions nazis?
2 hours ago, pepsi71ocean said:
In what way?
Feeling free I guess, even though I'm a slave to the system in one way or another. It's all how you look at it. We can have an endless thread on this subject.
The funny thing for me was that I was a Jerseyan for a year back in 1959. My dad took a job up there. We moved from NC. Went to first grade up there.
My dad didn't  like it there and we moved back to NC after school was out. My mom used to tell me any time I read to her for the next couple years I had a Jersey accent.
