Normal EGT?
Experience of this last pull with the RV...Cruise set at 55 MPH, Edge Comp set at 5x3, RV275 Injectors, and I could climb over mild grade in 5th gear. Now the 2 larger grades I would shift down to 4th gear and rarely did I get to 1,100*F. The weather was cool 45-60*F on both trip to and from.
current pic of the rig
LMAO!
Which Brake Pads... need to hear your experiences
That's easy don't use your service brakes and have a exhaust brake then you don't have brake dust on your wheels nor do you need to change brake pads...
Acceleration still not completely smooth
Redneck version of LiveOak idea is to keep everything coated with engine oil. Reason... Think about it there is only 2 types of containers that battery acid is sold in. [*]Glass [*]Plastic - And plastic made of what? (Oil!)
Haven't even unhitched yet...
New guy with a few questions.
Ok. As for tapping the VP44 that is myth. It will NOT burn out a VP44 quicker. It just gives you full control over the fuel and timing. Without the tap you at the mercy of ECM and smog limits. With the wire tapped you can hold the fuel open to full extent of the module capablities.As for building power another thing to remember don't get carried away with large tires sizes. It best to be a size small and allow the tires to break free than break the input shaft of your transmission. Like myself I've done the 235's for MPG and transmission reasons.
Got to remember the frost and moisture is collecting on everything so in the morning cold it could be weaking the connections. This might be other connectors like the PDC main plug or the CCD connector above the valve cover. Might double check them and add some di-electric grease to them.
sluggish and laggy...any ideas?
Fuel pressure? What it like between idle to WOT?Boost pressure? Error codes? Yes. Error codes can be present without a check engine light.
Fan Clutch
Sorry I don't. But you could get one at the Dodge Dealer but you'll pay for it.
I hope this doesn't come to Idaho.
Like I posted on the other forum. It won't matter if your legal gun owner or not the fact is you have every low life drug user thinking "I know of these people that own guns" and he'll turn you in. Legal owned or not how does the law efforcement know. They just take them. 2nd Admenment Experience in America prior to the U.S. Constitution In no particular order, early American settlers viewed the right to arms and/or the right to bear arms and/or state militias as important for one or more of these purposes:[25][26][27][28][29][30][31][32] [*]deterring tyrannical government; [*]repelling invasion; [*]suppressing insurrection; [*]facilitating a natural right of self-defense; [*]participating in law enforcement; [*]enabling the people to organize a militia system.
Fan Clutch
I'm still running OE clutch.
Normal EGT?
Intakes valves are good between 0.006 and 0.015 inches.Exhaust valves is good between 0.015 and 0.030 inches.
gear oil
If you have a limited slip axle yes you require it....Or you could buy the gear lube with the friction modifier already mixed into it.
What fuel pressure do you run if you have a gauge?
So far mine is still holding up to the 17 @ WOT and 19 @ idle rule when the fuel is warmed up.
Military testing of 2 cycle oil in diesel fuel
Synthetic is not required.Synthetic is a double edge sword being that synthetics don't have a ash problem. But since synthetics are naturally wax free there is no pour point depressants used so synthetics will not aid in the colder weather it will still gell up.
a have a couple VP44 questions
Ok lets work it one step at a time then. Ask lots of questions we'll do what we can to answer it to the best of our knowledge. That fact will never change... Well there is several people on the site here that are setup for exactly that. Look at my own setup I'm towing a 31' Jayco Travel trailer and a smaller 8x8 utility trailer. Ask around why they pick the parts they did. Ahh... Diesel Auto Power (Jacob Kidd) good man with good prices. Ok. Building a truck is simular to building a house. What you need to do is sit down and do some soul searching and talking to the gang here. Now picture a HP/TQ number you want to reach for say 350 HP/800 TQ. Ok this would be your build plans. So now you would start working on all the weakness of trhe truck like fuel system, transmission, etc. Then after you sure of all the weakness are cover and your foundation is strong now you add the power and fuel. Because like building house on a weak foundation it will just fall over. Best thing is to ask questions and listen to advise of the family members here.
Well Ummm... The best thing right now would be to think about a Vulcan Big Line Kit. This will at least allow the stock pump to keep up with the injection pump and keep the fuel pressure up. I ran this for over 2 years till I got tired of replacing stock lift pumps. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/32-stock-lift-pumps http://www.vulcanperformance.com/Vulcan-Pusher-Pump-System-for-98-5-to-04-p/prs.htm
fuel gauge or isolator?
Here you go... At the bottom of the filter can.
I'm one of the rare ones that sees 100-110* in the summer time and then in the winter time be as cold as -25*F. Yes I live in the Northwest and in the State of Idaho. There is 3 things that kill VP44 injection pumps. [*]Low Fuel pressure [*]Low filtration [*]Low Lubricity The fixes to these 3 things. [*]Keep your fuel pressure between 14-20 PSI at all times this willl improve cooling and lubing of the VP44 injection pump while its under heavy load. [*]Upgrade or use high quality filters. While there is lots and lots of filter out you should opt for 2-3 micron filters. Do cheap out for the local part store filters. Study up and buy a good quality filter. [*]Bosch's study on fuel lubricity found that all fuel injection pumps had the best life span with fuels scored <450 HFRR. Using a quality lubricant additive will extend the life of your VP44 injection pump. More information... [*]http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/25-fuel-system/49-fuel-pressure-specification-for-bosch-vp44-injection-pumps [*](N/a) [*]http://articles.mopar1973man.com/general-cummins/36-fuel-system/68-hfrr-testing-of-common-diesel-fuel-additives
Stupid Question but what is a stock turbo on my 2002 auto
HY35W is going to be the stock turbo for Automatic.HX35W is going to be the stock turbo for manuals.
Pillar Gauge Install
Been there... Done that. :banghead:
Feel the love...
Actually only a 3/4" NPT plug is the boost the 1/2" is coolant.
1993 low power questions
You might search a while for the diaphragm. It's a tough part to find around here in Idaho. But he's right the whole AFC housing is based oon boost pressure and the ability of pushing that pin down inside the pump. You could loosen the starwheel to allow fuel on earlier. But double check all the boost parts for damage wear or sticking.
Chainsaw options
Yes they do produce a fancy chainsaw file and guide system that uses 2 files and files bottom the cutter and the rake at the same time giving a perfect chain.
