Bigger Couch...........Maybe??
MoparMom said, "Either get a bigger couch or start raising smaller dogs..."
Winter Front Testing
- Winter Front Testing
Electric Fans?- code 0251
Ummm... Well starting price of a VP44 is about $1,200.00... You might want to run through the vendor list here... http://mopar.mopar1973man.com/cummins/dealers/dealers.htm Or go over to the vendors area and ask them directly... /forums/67-Vendors-amp-Dealers">http://forum.mopar1973man.com/forums/67-Vendors-amp-Dealers As for installing most anyone with standard tools can install one but the only special tool is the gear puller. Some people have fab'ed up some steering wheel pullers or just purchased the actual puller...- When do you buy a new starter ?
- who wants to rebuild thier VP44????
Hmmm... News to me... There was a deal long ago on Cummins forum about swapping VP44 pumps and the swap usually end in poor running trucks... Well then the best thing I can say is becareful...- Winter Front Testing
Geez... Now I'm glad I don't have a 12V... All the junk that was added on your doesn't exist on a 24V...- Anybody out there?
Like Valencia??? I used to live in Mission Hills, Ca so I use to play in the valencia area going toward Zuni campground... Such a long time ago...- 930k mile service
- Plumbing the BHAF
- Troubleshooting dead end on dead pedal. Apologize for a long thread in advance
I wouldn't spray any kind of flamable material in the intake... As ISX has shown to us the grid heater can get above 500*F and could ignite most all flamable materials in the intake tract with explosive force (possible). If you got injection line loosen they should spray like a power washer while cranking not dribbling on the manifold. If it only dribbling then there is more air in the system yet. Because when a injection pump is primed up it will produce right around 4K to 5K PSI and yes it looks exactly like a power washer under the hood...- who wants to rebuild thier VP44????
Nope it won't work.- Plumbing the BHAF
- Gas Power Lazy Boy!
I need one of these...- Winter Front Testing
I'm going to double verify my number when I get a chance...- How low can you show?
I'll keep you in mind as I sit here looking at the snow on the mountains...- Winter Front Testing
Well the diesel is a different beast for cold weather. The amount of fuel used cold is slightly increase but just enough to hold idle governor speed. As for preheating the air the 24V do preheat the air only after there is coolant temp to do so... Like my 24V will match dead on for IAT and Outside temps. I start to see the offset about 140*f and then the offset grows as the coolant rises to 190*F and above. Typically the IAT will match cold but rise up to +40*F offset of the outside temp. Then if you got a winter front on the IAT will have a max of +50*F offset typically. Reason for this is the air isn't blowing through the intercoolers all the time. Hmmm... My fan only stays locked from 1st to 2nd gear then its fully unlocked after that it remains unlocked for the rest of the run...- 930k mile service
Umm truthfully... Join Date was October 25, 2009 so it wasn't too long ago..- Winter Front Testing
Oh My... Pants and Jacket... It must be cold now... Still a shock that totally blocked off there was very little change. Nice to see the engine oil is consistant about starting up mine does the same thing... Sorry to hear about losing the water pump...- temp problems
Ok... A few tidbits to add... The 190*F stock thermostat is basically closed by 188*F so at 190*F it barely cracking open. If your looking in the radiator for movement its not going to be there. When you'll see movement clearly is on a super hot day and the coolant is at 198*F now you'll see flowing coolant because there thermostat is fully open. As for the heater core test flow by grabbing the hose is not a true test I hate to say it... I had this exact problem with my 1972 Dodge PowerWagon pickup what it came down to was pulling the heater core and rodded it out. trust me after doing that it worked awesome. But in the same sense I had a plugged heater core and was doing the same thing feeling the heater hose lines and they were both hot assuming that it was flowing... Nope they weren't flowing good at all... Its convection of hest it was heat the coolant regardless of the flow. Now truely if the heater core is working propelry there should be a few degree fall on the return line but on a plugged heater core both line will most like feel the same... Because if the heater core is dumping heat in the cab the return should be cooler. Just like the radiator the upper hose will be hot as hell and the lower hose is cold to the touch this is showing that the radiator is doing it job properly. So my thought is heater core is still partially plugged up...- Installing edge comp, need help
There was a bug for the first cold start but as for any shut down and restart... (Clueless) The only thing I can say is double check your source is good 12V and not a loose connection... Double check your ground is good too. Beyond that I would say its time to talk to Edge...- Winter Front Testing
Really quite odd there was no difference...- CPUz
Oh Man... I would love to have that CPU... Then with 2 MB of level 3 Cache... 2600 Mhz x 4 Cores... Compared to my wimpy 2700 MHz x 2 Cores...- 930k mile service
Boy that says a lot about Chevron Delo... Make it to 900K and still rolling... I remember the first phone call I got from Caj and he was barely rolling over to 700K miles... How the miles fly...- Odd Readings
Cheap $8 dollar needle valve from NAPA (WH6820)... Then how to set the valve... With a digital gauge it going to be tough... http-~~-//www.youtube.com/watch?v=M33ZCc8b-7Q - Winter Front Testing
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
