  1. Sorry to say 2 cycle oil won't clean out a blockage... Then more than likely the Edge Filters in the connector tube would prevent the debris from entering the injectors. Question: Did the stock injectors fix the stalling issues?
  2. Hey ISX... How did you do for MPG number on the trip towing? Also I'm curious did you have any problems with engine temp without your fan in place?
  3. From what he told me last night on the phone... For $1,200 bucks in this transmission and got 300K plus on this transmission I'd say he got his money worth...
  4. Sorry to say even I've got torque management with a 5 speed transmission... Right around 25-30 MPH it releases and all hell breaks loose for me... 1st and 2nd are mild... But 3rd is a whole new animal...
  5. That's sad to hear... Hey CajFlynn you could talk to JohnFak he's in St. Louis area...
  6. Well GlowShift is one of the cheaper gauges on the market but fairly popular too. I tend to agree the the GlowShift gauge look better over the Autometer. Not to mention your 0-100 PSI fuel pressure gauge is a bit wide don't you think?
  7. The only thing to remember about doing work on anything around the airbag requires you to disconnect both batteries for a period of time to discharge the firing capacitor for the air bags. So after that you safe... If it was me before I'd go through the trouble of doing a clock spring I would test the clockspring for opens and short with a DVM from pin to pin. This way you can also check the control switches too...
  8. Well I sorry to say I checked over my books and didn't find anything about the tone ring torque specs... So if it was me I would torque it to the specs of the bolts capacity and use some locktite on it as well...
  9. Hmmm... I would say to look at wiring looms and see if something is getting pinched...
  10. In your case the IAT sensor sense the temp reports it back to the ECM and either uses one or both grid heaters to warm the intake. I would check for error codes to see if the P0380 or P0382 pops up that would tell you if you relays are good. There is a fusable link near the batter running down to the grid heaters. So check and see if the at the relays (studs). Then using a live data tool like a ScanGauge II or simular check and see if the IAT is dropping below 65*F or is showing a invalid temp say like 90*F on a 50*F morning. This points to a failed sensor within limits but will not trip a error code. Tell you the truth you don't need grid heaters till about 40*F...
  11. Doing my mod will put a extra 2-3" worth of height on the pipe and make it that much more highier and les likely to make a mess... Yea I do put a drip on the shop floor now and then but very little mess under the truck.
  12. At this point they should be filled with non-null value of the next service of each.
  13. Give CaJFlynn a call he wants someone to look at a truck for him... (To buy)
  14. http://engineserviceinc.net/Light_Duty.html This should work for ya...
  15. Edge Juice = Edge Comp Edge Juice (Hot Unlock) = Edge Comp Drag They are basically the same module with the same programming... The Edge Juice though on the hot unlock has a 6th level... When the Comp only has the 5 levels and then I think they both fuel all the way to redline. The only difference is Edge Juice got all the pretty toys and Edge Comp well is just a box...
  16. That error code normally comes from the Smarty... If you return to stock setting, clear your codes and run awhile you find the code never comes back till you put the Smarty back on again....
  17. As far as I know there is no gasket for the front cover and most people just silcone the cover on. As for removal... Fan belt, fan and pulley, crank damper and pulley... So that should get you at it... Knowing the filler neck is steel I would remove it find a piece of copper pipe and soldier a patch over the hole in the filter neck. I done this kind of patch work on steel fuel tanks when the owner got over zealous and drilled into the fuel tank. (Not me!)
  18. Mopar1973Man replied to HayHauler's topic in Introductions
    Welcome to the group... Sound like you got a good deal on a truck that was repaired and freshen up...
  19. Chip is technically like the enhancement box... This comes from the gasoline engines where people phyiscally pulled the the "Chip" out of the early GM vehicle and replaced them with a "Enhanced Chip". But as you know there is no way to do this on our trucks so its either "Re-Flash" the ECM with a "Programmer" or use a "Enhancement Box"...
  20. All elbows are 90* fittings... But there is a male/female threaded coupling to allow removal of the down pipe.
  21. Passing on a message for CajFlynn from a cell call... Could someone take a look at a truck for me down in the Houston, TX area... Please contact CajFlynn at 303-570-4325
  22. I think that's 1/2" or 5/8" ID hose...
  23. Shopping list... 3 slip-slip elbows1 slip-male thread elbow1 slip-female thread coupling2 hose clamps6" of 3/4" heater hose4-5 feet of 1/2" PVC pipe
  24. Most programmers are limited to 60 HP that's it... I think there is only so far you can go with values before the ECM just goes . But Now most fueling/timing boxes max out at 120 HP... Except Quadzilla Adrenaline at 150 HP... But since most fueling/timing boxes alter the signal after the ECM and can extend well beyond the limits of the ECM software so this why most boxes tend to produce more power. But like I told you ISX on the phone the wire tap to the solenoid on the VP44 is the factor that adds the fuel beyond the ECM's abilities. So without the wire tap most boxes limit to 40-60 HP period... So the theory is if you beef up the ECM signal and getting more fuel then the box would add more fuel on top of that signal too. Now Smarty is able to cut back the torque management and get the fuel started heavy and hard down low were most boxes can't do it because they are at the mercy of the ECM's torque management. So with the stack it should produce a wicked combo. But now running 3 fueling mods with White's idea...
