Welcome to my World
I wish you all where there when I had to comdemn my 1972 Dodge Ram W350. I had the worst luck with snapping the front axle all the time and the axle was only made for 1/2 a year so find part was expensive and insane priced. Well after hanging around other forums I think I know the cause of my problem know but I no longer have the truck. But now in hind sight I learn basically all failures have a reason and a cause like JL Welding here with the pump. But the tough part is now the answer. The answer is not obvious other that that we could of helped him fix it... But some where down the road we will find it.
Tractor Forum Got a Face Lift
Not a problem I believe in "Link Love"...
AirDog
Gauge pod you get from Autometer or a Autometer dealer. As for the AD 165 I think those don't require a draw straw unless you got intank pump.
Welcome to my World
Oh Geez... Come on JL... You know better about fittings and torque... I called you anyway to see what the heck was up with you...
dyno day
Man I wish... I would love like hell to show up and run the rollers but I just don't have the money to drive all the way out there... Good luck to the rest of you you got to post up a copy of the dyno sheet on the performance areas though!
New diesel toy on order
Nice... At least its a diesel... I would love to have small tract like that so I could do some land scaping and dirt moving and make the yard the way I want it...
tcc lock up???
Ok... Now does it do this without the cruise set? Funny feeling the PCM is at fault... (Cruise control)
Help! No water temp, oil pressure, or tach. ECM failure?
Try the cluster testing... http://mopar.mopar1973man.com/cummins/2ndgen24v/cluster/cluster.htm
Big thumbs up for Moparmans state
The reason why it doesn't bother me is because the sole fact is if you not hearty enough to live in the back country and be a long way from a big city you not going to make it. There is no cell phones here, no FM radio really, no coffe shop (starbucks), etc. Just miles and miles of wilderness. Maybe that why... When I quit the fire dept I switched hats from fire fighter to Idaho Co. Search and Rescue. Yeah this is what Idaho all about... This is only 4-5 straight line to the highway but there is no big cities, no nothing. Place like these your on your own. There is no cell signal to call for help, even our fire/police radios couldn't reach a repeater tower, and then it might take a skilled ATV rider at least half a day to get out of here. (Notice in the second pic there is no trail or orad anywhere) There is no roads to follow back.
Diesel fuel...
Hey Gang... I got ahold of the local fuel station owner and going to see what information I can get about diesel fuel and the quality and testing the fuel must meet... He said he would look up the shipping invoice and see if he could find any information about pourt point, HFRR, and othe good information. Lets see where this goes...
tcc lock up???
Hmmm... Just replace the brake light switch since there is no way I know of to adjust the switch... Now is the APPS sensor still showing this .4 volt change all the time or only randomly?
Lots of places... Just happens to be the two local real estate office in Riggins, ID http://www.blevinsrealestate.com/ http://www.salmonriverrealty.com/
tcc lock up???
Another one I thought of that could be a issue is the brake light switch. This controls locking/unlocking of the TC. I've heard where a lazy pedal could be just enough weight to trip (flicker the brake lights) and cause this lock.unlock weirdness.
Over flow valve
Hmmm... Now the fact of the old Edge box was mess up that give a bit of light to the fact of a possible short or simular cause a excessive current draw or loading of the pump. Anything is possible... But I glad to talk to others about the welding issues to verify the thought... As for the overflow valve it doesn't open till 14 PSI so i'm starting to suggest the 14 PSI as a minimum pressure to help in cooling the electronics and keeping the pump happy longer... There is no proof of this yet but I can say my pump is 113K miles and doing good...
Trip Report II
Not bad at all... 20.5 MPG is nothing to sneeze at... Wait till you get the summer fuel with lower cetane you should be able to push that number up a bit more!
ABS Actuating?
Dealer is the the only one I know of that is capable of seeing the speed sensors... There is a few SnapOn scanner that can too... As for the price I don't know...
Vp 44 trouble, or ground problem
Oh Yeah just been busy web page building... But comments are in blue...
ABS Actuating?
Perfect... The your problem could be with one of the front sensor... The sensor is reading off slighlty causes the ABS to start to fire a bit. Because if the rear sensor had problem you would see the speedometer needle stick at zero or read erratically or show just a bad value. right now the problem is so mild to the ABS computer it not tripping the light but once the difference increase the ABS light will come on and the ABS system will eventually fail completely returning back to old school brake system. On these truck it really easy to lock up all 4 wheels.
ABS Actuating?
ABS light on? P0500 codes? YES Speedometer work or not? How about they other 2 questions?
ABS Actuating?
ABS light on? P0500 codes? Speedometer work or not?
Oil pressure Gauge
I would plumb a test gauge and check the oil pressure and see what you got... Then replace the stock sender and go from there...
More 2 cycle oil stories
That's funny... I remember day of driving gasser and always though the smell of diesel was nasty... Now gasser really stinks and burns your eyes compared to diesel.
RV275 Results...
Can you change spark plugs in a gasser? Well it just as easy just different... http://mopar.mopar1973man.com/cummins/2ndgen24v/injectors/injectors.htm
compound LP turbo
Smart man... You know the limits of the head gasket and limit your boost properly...
Interesting point there Flman... Might be a good idea to hook a battery disconnect on the system to isolate the truck from the frame... But as for grounds there is several ground under the hood... There is one near the battery on the driver side, there is one behind the starter on the block, and then the common cable that hook to the block... but the dodge FSM would be the best resource for looking up all the grounds...
