hard starting
As you can see there is only the ECM controlling the fuel pump circuit.
hard starting
There should be modulated power being sent to the lift pump in pulses (ON/OFF/ON) while cranking. You might check with a test light if you can.You said the lift pump is stock correct? And hooked to the stock connector right? :confused:
Straight Piped Exhaust
Great... Nice to know a bit of exhaust work gave you a small gain but it worth it... :D
hard starting
Ok... Lets go over this carefully... Watch the video on testing starting pressure... http-~~-//www.youtube.com/watch?v=NCJjMzRImpA The 3 pound drop is marginal and so is the 11 PSI at 70 MPH... It possible the P0216 is caused from the low pressure. But I would suggest you at least upgrade to the Vulcan Big Line Kit... http://www.vulcanperformance.com/Draw-S ... ps9804.htm
Pure Flow Raptor problems
Let me know how it turns out... I've got the old school drawstraw and so far no big problems here I can drive down to 1/8 tank without much issues...
Was gonna adjust my valves when...
You must be a one in a million...If it was me I would grab a 1/2" Impact and drive that sucker on...If you got a strap wrench to hold the pulley and drove the nut on you should be good...
Hmm, well I tried..
Well thanks... That hell of a comment there... 8| LOL :Lmao
Hmmm... It could be cracked nipple or a bad O-ring...So maybe it might be a good idea to do the drawstraw... I gather you going to do the fuel module one right? :confused:
N-P 241 chain replacement
The best I can say is the case has to be removed from the truck and the case split open to change a chain... (reading throught the Dodge FSM Page 21-890 or 2525 page of Adobe). As for the Dodge FSM. http://pdftown.com/Dodge-Ram-2001-Service-Manual.html
Visor
LOL I love your "Girl in a Box" LOL As for the velro idea... I seem to be caught up in it... But I always got about 1 foot of velcro stuck to the inside lid of my center console so no matter what I'm doing I can grab a chunk of velcro and stick something to the dash or other wise... :rolleyes I should be the velcro king... ;)
Adding Forward turn signal lights?
Hmmm... I might not be a bad spot to put them on the arm of the mirror. Like you said the snaking part of the wiring is the tough part... Those mirros I would love to have right about now... ;)
Another idea is to go to a motorcycle shop and look at aftermarket fairing turn signals. There are several different style of tear drop turn signal out that are small enough for like a mirror setup or such... As for snaking wiring out... That might be fun... The door panels have to come off and the mirrors should have a hollow on the bottom. Now are the mirrors power adjustable? if so then the mirrors have leads running into them. So that means you could fish 1 or 2 wires into the mirrors and hook up you lights... I've got a clue about the mirror after my damage I'd done to my truck 2 years ago... (Pulled a tree down on the passenger side)... Take notice the mirror is gone and the pretty dent... `
Rusty spots on brakes
Most liekly like a hot spot on a flywheel.It would be interesting to mic it and see what was occuring. Also I wonder if the rotor had formed harden spots in it (work hardened)? :confused:
Showing off the Jack-O-Lantern
That's cool... I love the idea... At least its very creative idea... > B)
Visor
LOL I didn't know that the driver side had a mirror? At least mine doesn't... :confused: As for the monitor couldn't you use velcro and just velocro the montior to the visor??? :confused: (Crazy idea)
re; grid heater
Sorry I know I don't... You might try a wrecking yard.
So the stock sender connection was the air leak for sure??? Where the Raptor ties to the stock fuel pickup? :confused:
around 30 m.p.h.
I don't make them or sell them I just provide the infromation so you can buy them... :thumbsup
Another idea is to pressureize the fuel tank with about 1-2 PSI and see if the fitting leak at all... :confused:
Small Block gassers
There were a few updates to the engine 5.9L and 5.2L with there own problems too..
Rotella Stinks?
Or do my crankcase vent mod and be done with it... B) http://mopar.mopar1973man.com/personal/2002/crankcase-vent/crankcase-vent.htm
Scan Gauge showed up....
It can only see what the ECM/PCM monitor... As for boost reading on the 98.5 to 2002 is incorrect and doesn't display properly... But the 03 and up model year Cummins show correcly... The voltage offset in our MAP sensors fouls the reading... But all other sensors work fine... (IAT Temp, Coolant temp, flow rate of fuel (GPH), Engine load, MPG, APPS sensor, MPH, RPM's, Voltage)
Ok... Do you still have stock plumbing between the filter and the VP44? If so call Vulcan and get the big line for between there... As for the wild pressure I would do a lift pump diagnostics. http://mopar.mopar1973man.com/cummins/2ndgen24v/lift-pump-diag/lift-pump-diag.htm While doing the test I would look for flow and air bubbles while the pump is running. If the flow isn't up to snuff or there is air bubbles in the fuel you know to back track and find your air leak.
around 30 m.p.h.
APPS sensor calibration is here... http://mopar.mopar1973man.com/cummins/2ndgen24v/apps/apps.htm
Hmm, well I tried..
Well you tried... I've gotten several weird looks and such from other when I'm pouring out a dose of 2 cycle oil on my tailgate... I just keep doing it and so far I'm at 106K miles on the VP44 and I plan on going for the long haul... I hope my VP44 gear puller get used on many other VP44 other than my own... LOL The funny part is these people are the very same people will to dump WVO or WEO/WMO in the fuel tank... :thud So true... It is a marathon... I still got my crosshairs set on 200K miles... Yeap... Well see who's left standing in the pile...
