  1. For the most part yes. Both AirDog and FASS both come as a complete kit. This means supplied draw straw, electrical, pump, and all plumbing. You end up removing everything from the fuel tank to the engine and replacing. The only thing I will suggest with either kit is to get the Vulcan Big Line Kit so you keep the stock fuel filter can.
  2. Out here it attracts cops to pulling you over for speeding. They watch for the black cloud to show and then go after you. After living through the heavy dense fire smoke out here the last thing I want to do is no start rolling coal. I've had enough smoke for the time being. Ugh! The part Iove is the smokeless tune I run. People see a fairly stock looking truck smallish tires, no lift, etc. Assume they can whip on me. LMAO! Mostly end up in my rear view mirror. In under 100 yards I whipped a stock 4th gen no to long ago. Out ran him to the merge point.
  3. I always wondered why people want a lope tune or a smoke tune neither one produces a good tune and makes the truck run really crappy. Why?
  4. @dripley to toss in the comic relief for the evening. By chance did you happen to remove the one way check valve? This would also create that drain back issue too.
  5. 190*F (PN: 375-190) https://www.napaonline.com/en/p/MRD375190 180*F (PN: 375-180) https://www.napaonline.com/en/p/MRD375180
  6. Not sure exactly but it would be just a bit bigger and better flow than my 60/60/12 I've got now. All I can say is ask him. I'll even tag him in hopes he shows up here. @dieselautopower
  7. @Dynamic warned me about it when he modified the transmission for pump in park. It would drain back overnight. I do notice that the whine of the pump in park is now gone because fluid will flow in park or neutral. Compared on stock it only flows in neutral.
  8. This is correct. But still in all the line size is too small.
  9. Stock transmission does not drain back typically. I've never had to wait like now. Every morning I've got to start it wait about 10 seconds before the transmission will do anything. Before it would move instantly after starting.
  10. At any rate, all that stock plumbing has to come out. It's just too small of pipe for what the engine requires. All the banjo line are 6mm (0.23") This is smaller than 1/4" fuel lines. Our engine does the best with full 1/2" lines and keeps the pressure stable over a wider range of fuel demands.
  11. I've been running NAPA thermostats and never found a bad one yet.
  12. I highly suggest against this. Canned tunes are only built for stock trucks. Now after you put bigger injectors and other mods on that canned tune will not fit anymore. This is what pushed me away from the Edge Comp toward the Quadzilla at least with the Quadzilla you can control your fuel to boost and keep the smoke down to nothing. Where my Edge Comp couldn't run any setting without smoking fairly good. So with that being said the Edge Comp will not fit. I'm not sure what turbo that is exactly. Sounds like my HX35/40 Hybrid. I would suggest you get ahold of Jacob over at Diesel Auto Power he's got a better turbo that will fit. He's was wanting me to jump on this because it would fit my fuel I've got at 7 x 0.0085 injectors. Now my 7 x 0.0085 injectors from DAP and my HX35/40 (60/60/12) turbo with the Quadzilla on Level 3 (of my custom tune which is CANBus only) I can haul my RV (31 foot Jayco) up any grade 6% or 7% with my foot mashed to the floor and never reach 1,200*F. If you wanting custom tunes guys here will be glad to help build a tune that does what you want. You can even jump in the Download area and download available tunes. https://mopar1973man.com/files/category/22-quadzilla-standard-tunes/
  13. Something about the valve body. You will have to ask @Dynamic about this.
  14. Just Neutral. There is a mod that transmission rebuild can do to make it pump in park as well. The side effect is the torque converter will drain out over night.
  15. Nope. You need to pull the radiator and inspect it in the open. You'll be surprised of how much debris is in the face.
  16. Even without oil vapor. Just the road mud will dry and cake up on the radiator as well.
  17. Just need a better fuel system. The overflow valve typically opens at 14 PSI. So any fuel pressure below 14 PSI the overflow is closing. It's completely closed by 10 PSI. As for the overflow valve typically they don't wear out. This still brings you back to getting a AirDog or FASS. Not going to change til you upgrade.
  18. I wonder if those will hold a 9,000-pound Cummins?
  19. I watched the reverse... Few big names went to AMSOil ATF in the power steering and ended up eating the pump and steering gearbox multiple times. Our systems are not designed for ATF. Now 2003 on the Sagnaw box was discontinued and Ford steering box was used from 2003 on. Hence way the 3rd and 4th gen use ATF in the power steering.
  20. Heck I've never gotten that high yet even idling in parking lot for 3 hours with 110F outside temps. No airflow around the fuel tank.
  21. Don't do it. It will cause seal failure. Our system are designed for power steering fluid. 3rd gens are a Ford steering box and requires ATF.
  22. Lets say it really rare for anyone to trip the P0168 code for high fuel temp. I can't remember the temp that trips the code. Lets say the highest I've seen is right at 140F. Winter time ill have to watch and see.
