  1. Make sure its 1/2" fuel line...
  2. I've got it as well. Mine keeps blow out and I've got to tuck it back into the bumper. Might cut mine off soon.
  3. Yeah on Dodge trucks its open on pin 3. It terminates at the ECM though.
  4. Nevermind... Need morning coffee yet...
  5. U-joints you need to pull the shaft to truly inspect it most times. Once free of the vehicle you see the sloppy joint typically fast. Now on the vehicle might be a bit tougher but grab each piece of shaft between the joint and rotate against each other. See if the joint got bad bearing cups.
  6. Fuel pressure? You need to have a gauge in the cab. I'm going to bet the fuel pressure is really low. You need to keep 14 to 20 PSI while at WOT going down the pavement. As for the loss of fuel prime that is because there could be air leak in the injectors, injector lines, crossover tube o-rings, return banjo at the back of the head. Suction line air leak. Fuel drain on the filter is leaking. Suction side leak are tough because they never drip on the ground. You'll need to put 1-2 PSI of air pressure the fuel tank and hunt for the leak in the system be like a moist spot.
  7. I'm still running $60 an hour out the local economy is weak out here. I charge by my actual work hours if I can bet the labor book. If I'm over the book rate hours then I typically cap the hours to the book. It's a humble pay but its something.
  8. 30* on stock is a bit too far. About all your going to get 27* where it will hold better.
  9. 12 years mean time between failures isn't bad either. Most likely longer period of time for the AirDog between failures than on Fuel Boss. I don't think a belt will last that long for 250k miles and 12 years. My downtime was about 4 days. No worse than the down for other failures and ordering part like injectors or injection pump. So when I lost my VP44 after 243k miles it still was down 7 days waiting for parts and get it back on the road. Like injectors still got to wait for new injectors to get here still 3-4 day wait time. So down time to me is meaningless. It will happen.
  10. Now seeing all the pins on the Members Map I would like to offer another great idea to everyone. It would be awesome to vote for a president of a region or state and then start making group meeting or get together's or wrench parties. Where states get together possibly in the summer where everyone meets up and get to know each other. Come on guys I know you'd love to get together share your knowledge with other members. Just in the small handful of people I met in person and the few hundred I talk to on the phone are all great people why not all work together and aid each other? https://mopar1973man.com/membermap/ The map is growing daily and the more member that get there locations posted the more we can figure out groups.
  11. Ah... PCM is not seeing any communication from the ECM. Double check the two connectors to the cowl. The CCD bus is in one of them. Remember PCM is the primary computer and the ECM is the companion module. This will aid you in testing the APPS wiring.
  12. Just talked to my buddy @Taz in McCall as of 10pm last night they didn't really see any rainfall at all. He said a few drops hit the windshield of his truck but mostly dry. He informed me 2 new fires started down in the Cambridge, ID area last night. I'm not sure of the state of those fires or did the local FD catch them before going wild. Then there is @Evan with 10 new fires in Mountain Home, ID area. Don't look like we gare going to get much slack till the rains really come on and snow flies.
  13. Key fob? (Security system locking out), ASD relay issues? (Check for error codes)
  14. https://www.dieselautopower.com/airdog-150gph-air-fuel-separation-system-a4spbd004 Full kit you can call and verify. The only thing I don't like on these is the quick connect fitting that may leak air. Some of us have called Vulcan performance and converted back to old school push lock fittings.
  15. No. It will help with longevity. The whole idea is to keep pushing high volume of cooled fuel through the VP44 pump to keeping the pump cooled and lubricated. If you figure the average VP44 temperature on a 100*F day is about 130-140*F you need to keep it fed with lots of fresh cool fuel. The fuel tank naturally heats up too because of the amount of returned fuel from the head. As long as flow is high the VP44 lives for a very long time. My last VP44 went 243k miles when the timing piston got stuck in full advancement. (P0216) 4 ways to kill a VP44... 1. Low fuel pressure. 14-20 PSI is optimal. 2. Poor filtration. This is why I suggest the double stacking of the filters. 3. AC noise. Excessive AC noise will fry the ECM and PSG on the VP44. 4. Poor lubrication. Today fuel in the US is 520 HFRR, Bosch requires 460 HFRR or less.
  16. ECM is booted if the light comes on instantly with the key. So I'm wondering if you have an air leak in the fuel system and losing prime. It common to have suction side leaks that never drip or leak fuel. Bad crossover o-rings will make it hard starting. Banjo bolt at the bad of the head if the sealing washers fail it could cause starting issues. What's your fuel pressure during cranking? Does it rise to cranking pressure and pulse up and down normally or does it sit at zero for long period before jumping up? Security feature might play a role and prevent starting that would be the PCM more so. Do you have a key fob?
  17. We were downgraded from 3 to 2 by about 2pm yesterday. I was never even paged out to get a truck or do anything the fire is still 3 miles back in the backcountry and long ways from homes yet. Here is what the whole evac was about is Hillman basin road they figure the winds were going to be 40-50 MPH out of the west and the storm would push it down on the homes in this area. But its still along ways away as of this morning. Funny part I measured only gusts of 10 MPH and average wind of 4 MPH. I also chewed out one of the managers of the fire for this needless callout of evac. They admitted it was handled wrong and the wrong area called out for evac. Last night with @JAG1 on the phone about 9pm we started our lightning storm (dry). Very wicked looking cloud to cloud lighting running back and forth across the canyon. Then out of nowhere, it started to pour rain dumping at a rate of 2 inches an hour. Managed to measure out 0.5 inches after the storm stopped. Sad to say the valley filled back up with smoke this morning but I know the fire been knocked down by this rain storm hopefully US Forest Circus don't pass up this change of catching this fire and putting it to bed.
  18. Umm... That ground is here... This is the important one! All the other grounds are rather meaningless subsystems. (lights, horn, etc) You might do the ground wire mod and never look back to this problem again.
  19. Does the wait to start light come on instantly? Does the light come on after a small delay? If the wait to start light doesn't come on the ECM is not booted up and the VP44 and lift will not power up.
  20. No. Problem is they spend lot of time dead heading and this is hard on the pumps. This why the Raptor series fail quickly typically. Now the AirDog 150 like I've got has a 3 hose return line that allows the pump to continue pumping freely without dead heading. Typically you burn rate is about 2 to 3 GPH and you've got 150 GPH pump pushing where is the 147 GPH going? Raptor is dead heading and AirDog 150 is returning to the fuel tank.
  21. Maybe they are upgraded bolt that is longer. You might call your supplier and ask them there was changes to bolt lengths.
  22. High volume pumps have better pressure stability. So 95 GPH pump will have larger pressure swings. Like I'm around 400 HP realm and only have a 2 PSI swing from idle to WOT to 100 MPH. If you opt for a 95 GPH pump you might see 5 to 7 PSI swings. Simply. If your supply volume is greater than your demand volume the pressures do not fall much. Then if the demand volume out weighs the supply volume the the pressure falls. So if your looking for VP44 longevity then you need to keep above 14 PSI all the time. My AirDog 150 hold 17 at idle and 15 PSI at WOT. 95 GPH is good for true stock and no towing. No tuner. Stock injectors. Just stock daily driver.
  23. Yes but the voltmeter has to have a 2V or 20mV AC option. If you volt meter only has like 200V option then it's not going to work. If the volt meter responds with a 29 to 31 volts its too cheap of a meter. Typically a good DVM around $100 buck will do it. Like I've got a old Fluke 75 which can measure multi-frequency down in the mV range AC.
  24. AirDog 150 or FASS 150 is most likely the cheapest option. Any kind of direct replacement pump is not going to work. The problem is all the banjo bolts and stock 6mm (0.23622 in) fuel line needs to go away. All fuel system kits change over to full 1/2" from the fuel tank to the injection pump. Then with the Airdog or FASS and a Big Lin Kit from Vulcan you can keep the stock filter which now allows for double filtering of the fuel. This extends my filter life so far to 60k miles per filter change.
  25. Just checking on https://inciweb.nwcg.gov not listed as of yet. Hang in there...
