  1. Basically I would start with changing out the cam sensor. Which in this case is the tach sensor for the 2001 to 2002 model trucks. So that explains the tach drop out. But If the sensor doesn't fix the issue I would say its time to ohm test the wiring. Yes a loss a tach signal will put it into limp mode.
  2. Still got all my OEM battery holder bolts and clips yet and no sign of wear.
  3. ECM sends the shutdown signal. As for timing solenoid its a hydraulic valve that send pressure to one side of the piston to advance timing or vent the pressure to retard again the return spring. You can see the 2 solenoid connectors off the PSG. One is timing and one if fuel pin.
  4. More or less they can test for leakage during the test. Or as Dodge calls it measuring the return flow rate. Your right there is no real pump up to pop pressure to make it open being the solenoid and valve is what actually makes it POP off. But spray patterns and internal leaking flow rates can be measured and checked. Which is part of the problem with CR injectors. Yeah the term "POP Testing" might not be correct like Wild & Free says "High Idle" isn't correct either. So lets just say "Injector Testing"...
  5. There are machines to verify performance and more or less pop test the injectors.
  6. Got that whipped it's $2.839 in Riggins, Idaho right now. Gasoline is $3.129... Sucks to be gasser owner now... The 96 dodge is parked under a tree...
  7. There is only 2 solenoids on the VP44. Fuel Solenoid Timing Solenoid The fuel shutoff signal just shuts off the power to the fuel solenoid and it stops running. Excessive timing will make it hard starting. Depends on what the OP's starting pressure is too. If the cranking pressure is between 7-12 PSI which is normal. Above that will create timing issues. The ECM has a 50% duty cycle on the lift pump to reduce fuel pressure this is one reason why we need to keep the ECM control of the lift pump. Now another test would be disconnect the lift pump and see if it starts easy if so then the cranking pressure is too high.
  8. I'm even happier with the idea of taking care of the cables and protecting them from damage in the first place. If you to look at my battery terminal they look nearly factory fresh yet except for the jumper cable gouges. The entire secret is using engine oil and not grease. This way if you work on the engine you don't lean over and get a big gob of grease stuck to your shirt or arm. Engine oil leaves a film that acid can't penetrate.
  9. I'm like yourself. I bought a old school AirDog 150 and no warranty because I was one of the few without a warranty nor the knowledge of the card. So if mine failed today I would be looking to rebuild the exist pump with fresh parts from Pureflow first. Beyond that most are heading over to FASS for replacement pumps. Now as from Eric @ Vulcan Performance he says that the AirDog 100 and AirDog 150 series have improved again. At least from his stand point he's not getting a bunch of warranty calls. All I can say is call and ask him about it.
  10. Personally I like to solder all my connections that way its water and acid tight. Acid can't make its way down into the cord of the cable and rot it out from the inside. Make sure to seal all joints with liquid electrical tape and/or shrink tubing. Makes thing last that much longer.
  11. It can be sensors. Like my last go around was the front right sensor that broke a lead. Little bit of solder work and good as new for now. I know eventually they will fail completely.
  12. Blow by test to me is a joke. Ask JL-Welding about his misfire problems and no blow by. It only cost him a total of $20,000+ to get fixed. If you want to check the status of each cylinder you need to run a compression test. Like JL_welding his problem was cracked piston but would not show up on a blow by test. Do mind you JL_Welding truck is a 24V engine versus a CR engine but the fact remain you can damage 1 cylinder enough to create a misfire but pass a blow by test.
  13. Yes. I still got my AirDog 150 and its nearly 10 years old. Purchased in 2006 from GOS Performance.
  14. Only the ECM controls the lift pump circuit. The only thing that will stop the lift pump circuit is that the tach signal drops to zero or the ECM is failing. VP44 has no abilities to control the lift pump if it on or off.
  15. No. There is no check valve in the inlet. The overflow valve is at the return side.
  16. Fuel pressure gauge? Fuel pressure gauge is a very helpful friend. If there is a loss of prime typically it can be seen on a fuel pressure gauge as a lag time for pressure to rise. May also show up as a sudden dip of pressure during cranking because of loss of lift pump prime. This will give clues on where the problem might be at.
  17. Or go to the dealer and pay $120 for then to scan it.
  18. Exactly what I do too. I typically run 4th gear (1:1 Ratio) on all speed below 55 MPH. It puts me right at about 2,100 at 55 MPH but like you said about 5 MPG higher. That's another reason I hate the auto's they make shifts at weird times and always requires human intervention to get the best MPG's. I typically have to run OD OFF as well on the 96 Dodge for optimal MPG's.
  19. First off I would have all injectors pulled and pop tested. Because it sounds like you got more than one bad. Then while all 6 are out I would do a compression test. Since it common for common rails to wash out all the rings with bad injectors. Then I would never replace one injector but replace all as a set. Yes common rail injectors are expensive about $3000 to $4000 for a set which is about 10 times higher than my old 24V. Which most likely didn't fix the ultimate problem. The problem is in the A port valve of the injector because its sticking open.
  20. Only fuel from one port is rather scary. That means that possibly the rotor has broke free from the shaft internal on the injection pump. It could be air issues yet. So don't give up yet. I've seen rare cases where a shot of ether is all that is needed to get it to bump over. Before using starting fluid make sure to disconnect the grid heaters and only use a very small spurt of startering fluid.
  21. Hmmm... You drive a hard bargain don't you? Ok. Since a cord is 128 cubic feet... I want 128 cubic feet of water or 957.506 gallons. So more cubic feet of water water the more cubic feet of wood... Fair trade eh?
  22. Even at work some guys like using gloves and other like myself hate them. Yeah they keep you hand cleaner for all about the first few minutes till you snag a sharp piece of metal and it tears. Where normal skin would slide over. Now sloppy jobs like packing bearings yes I'll wear gloves save me from washing all the grease off. As for NAPA filter I'm using them now as well. 120 mile round trip or 250 mile round trip for Fleetguard filters is just getting too much.
  23. Can't. The ash levels are too high now and will leave nasty deposits on the pistons and injectors. This is why 2 cycle oil theory started because 2 cycle oil is ashless.
  24. Like Mopar Mom is starting her own indoor garden. We've been enjoying home grown tomatoes. Now I've picked up some bell peppers and other herbs now too. Kind of the reason for the desk change so we had more room in the living room for our indoor garden. Small but producing. As for junk food we are not buying potato chips and mostly good wholesome food here too. MoparMom is the kitchen guru. As for meats I'm the picky one there I'm more in favor of our local butcher here in the valley than store bought meat better quality. also we can buy Elk meat as well. So I'll say we are not as tight diet wise as you but eating better than 90% of the public.
