Spuratic fuel pressure
Just right. 14-20 PSI of fuel pressure under normal road load conditions. Should be 7-12 PSI while cranking/starting. Time to pack up and run from that shop because he's clueless. Because the ECM, PCM and VP44 do not get grounds from the body or frame but directly from the battery cable themselves.
01 dodge speedo doa
Means the data from the ABS computer is being lost or erred while traveling from the ABS computer to the instrument cluster. All ABS modules should be flashed for tire size for speedometer calibration. But in your case withe the bouncing I'm really puzzled not knowing is it the speed sensor or wiring before the ABS. Or is it the ABS communication on the CCD network that is screwed up. Either way you going to need a dealer to look at the sensor and ABS module to be sure. As for the communication the dealer should be able check that with the DRBIII tool.
JAG1 made it to my place.
If your not careful I might end up camping in your yard this summer.
Log Home oil treatments
I will validate that... It does turn the wood dark or black in color.
what did i break?
Heck... If I pull that much apart I would of replaced the darn clip.
Well you seen my wood deck. We've been using boil linseed oil and mineral spirits. Over time the wood has blackened but not rotting.
01 dodge speedo doa
Some sort of data loss going on or CCD Network issues.
Pyprometer gauge hook up
I tied mine to tight I can't get to my plug on my gauge. Thanks for the pic.
Need some help for a buddy
Yeah... I wasn't impressed. Great low end and then very flat up top. I rather have the UDC but not available for 24V. That's how I got my high idle flash was Bob Wagner sent me his programmer for about a week.
haunting ghost in my truck
Personally I'm not a fan of the P7100 conversions. More or less like ripping electronic fuel injection off for a old school carburetor. Like the carburetor it was not as efficient as electronic fuel injection. Like the p7100 its very limited it tuning also it has zero timing advancement like VE or VP44 has.
I wish Smarty was that way for the 24V trucks. O.o
Ugh! That's expensive.
I used ground in my setup but it was bit difficult to get hooked up solid. Look closely at the instructions it will show it.
2005, Cranking No Start, No Communication at all, No gauges, No low beams as of a week.
Curious too.
hydroboost
There is a write up for rebuilding the hydroboost. http://articles.mopar1973man.com/general-cummins/33-brake-system/79-brake-hydrobooster-rebuild
installing egt temp sensor
Heck I've got a 5/16" bit zipped tied to a 1/8" NPT pipe tap ready for pyrometer work.
New CCW
Let's say I'm not huge gun buff nor do I want to be. The pistol I have was my Father's pistol he purchased years ago. I've got fair to good accuracy for self-defense. As for the concealing I could but I hate how uncomfortable it is. Being I've always got a fire radio hanging on my left hip a pistol hanging off the right hip kind of balances out my left to right weight. So as for getting into a different pistol, calibers and stopping power, etc. Out here if its animal and you gut shoot the animal most of the time the haul off to die elsewhere or just firing a round or two in the air typically is enough to make the animal change it's mind.
Here is a bit chart. So a 21/64 would be the closest bit to a R.
Amsoil intake fail
Dream on... No one want to drive to Idaho. Especially where I live in the middle of nowhere. Yes. It's true I walked away from the shop I was working with being I was having a disagreement with the shop owner. But I can do my own thing and run my own show. I've got plenty of people I can do work for.
Most here suggest Smarty programmer over Edge for CR Cummins trucks.
New CCW
I'm in the process of renewing my CCW permit with Idaho. I still carry my 9mm Star Pistol every time I take off from the house. JAG1 was kind of surprised about that. At first didn't realize I had with me and then after then he paid attention to if I was carrying or not. I'm a firm open carry person but have the CCW for the slim chance that I'm caught in a condition that would conceal the weapon. For me it more of a issue locally of the four legger (Animals) messing with you. Then when I travel to the Big City then you have to worry about the two leggers messing with you.
Baby got a new pair of shoes....
I like the wheels those are pretty sharp looking...
OBDLink LX Diagnostics
No not currently... But I'm fairly sure with a bit of digging I might be able to address it. (Might...)
Well I got a neighbor that stopped in last night to tell me here sister in New Meadows, ID is have vehicle problems. The vehicle in question is a 2004 Dodge Dakota 4.7L V8. She was explaining a surging issue she has been having issues with. Before I left the house I grabbed my Android Tablet and the OBDLink LX Dongle. So Looking over the vehicle its just a good old used Dodge Dakota and nothing seemed out of place. So I hooked up the OBDLink LX and turned on the ignition and read the error codes. It came up right away with error code number and the generic definition of the code. (Oxygen Sensor) Then I figure I would verify the code is real so making note of the code number I reset the codes. So now I started the engine and let the OBDLink LX read all available PID's and show me live data. This is way nicer than the old ScanGauge II. You can see like 15-20 live data PID's at once. So it was fairly obvious of what was wrong you can see the oxygen sensor in question was stuck at 1.23 Volts and the rest where cycling as normal. Also the code came back instantly. This impressed the owner big time being I was able to pin point the problem without really getting my hands dirty. So she'll be bringing this truck to work on in the near future. So I will have to admit the new OBDLink LX I picked up is a well worth it tool for anyone's toolbox. Works extremely well. The only mistake I should of done was smacked the screen capture function and I would of had all the vehicle data. During the diagnostic period it all ready tapped the Mode $09 area of the ECM and pull the VIN number and year of the truck for me. To me that's awesome to practically have everything in a single diagnostic run. Comparing to the old school Innova scan tool and the ScanGauge II I'm highly impressed with the data this little OBDLink LX Dongle can pull for you!
Got a new dash today
Nice job. Yeah the color is a bit off. You could of ordered a can of dash paint from most of the vendors and colored it to match. But it's got to be better than looking a shattered dash.
