OBDLink LX Diagnostics
No not currently... But I'm fairly sure with a bit of digging I might be able to address it. (Might...)
Well I got a neighbor that stopped in last night to tell me here sister in New Meadows, ID is have vehicle problems. The vehicle in question is a 2004 Dodge Dakota 4.7L V8. She was explaining a surging issue she has been having issues with. Before I left the house I grabbed my Android Tablet and the OBDLink LX Dongle. So Looking over the vehicle its just a good old used Dodge Dakota and nothing seemed out of place. So I hooked up the OBDLink LX and turned on the ignition and read the error codes. It came up right away with error code number and the generic definition of the code. (Oxygen Sensor) Then I figure I would verify the code is real so making note of the code number I reset the codes. So now I started the engine and let the OBDLink LX read all available PID's and show me live data. This is way nicer than the old ScanGauge II. You can see like 15-20 live data PID's at once. So it was fairly obvious of what was wrong you can see the oxygen sensor in question was stuck at 1.23 Volts and the rest where cycling as normal. Also the code came back instantly. This impressed the owner big time being I was able to pin point the problem without really getting my hands dirty. So she'll be bringing this truck to work on in the near future. So I will have to admit the new OBDLink LX I picked up is a well worth it tool for anyone's toolbox. Works extremely well. The only mistake I should of done was smacked the screen capture function and I would of had all the vehicle data. During the diagnostic period it all ready tapped the Mode $09 area of the ECM and pull the VIN number and year of the truck for me. To me that's awesome to practically have everything in a single diagnostic run. Comparing to the old school Innova scan tool and the ScanGauge II I'm highly impressed with the data this little OBDLink LX Dongle can pull for you!
Got a new dash today
Nice job. Yeah the color is a bit off. You could of ordered a can of dash paint from most of the vendors and colored it to match. But it's got to be better than looking a shattered dash.
Need some help for a buddy
Now if this something EGT gauge could of prevented or is it a designed weakness of the engine that was resolved later in time?
That's some serious carnage. Question to the 3rd Gen gurus what is the cause of this failure?
Friday Funny.
Geez...
Need injector help
Even my +50HP are fun... Just ask JAG1 about them...
Lift pump fail
Heading to 200k for my AirDog 150. But I bought it back in 2006 when thing were better back then... Only need 7k more of the VP44 to cross 200k miles.
swepco oils
http://swepcolube.com/ http://swepcolube.com/products/swepco-308-premium-cj-4-plus-diesel-engine-oil Been around awhile...
Who's got the lowest miles of any second Gen?
Russ got it... But sad to say looking at the history of Russ truck it looks like the RusT won though...
OBDLink LX and Android Tablet
I see that the fuel temperature shows up on the Cummins Onsite but its limited to just the ECM. Lots off good data there just limited to Cummins Onsite.
Nevermind... I can't play at all. 243,000 and climbing every day.
01 dodge speedo doa
If I had time on my side I would consider making a removal tool out of the broken tap. Take notice there is four hollow gaps along the broken part of the tap in the housing. Now carefully mill out the center of the old tap till you have two pins basically to fit into the hollow gap in the broken piece. Before going on I would blow out all debris, lube and heat the part. Now carefully attempt to spin it out broken piece of tap. But that's much easier...
swepco oils
As long at the oil meets or exceeds the minimum requirement of the device... Why not. The only other factor will be is cost.
How Much?
- OBDLink LX and Android Tablet
First off let me be very very clear about something. OBDII information will not add more gauges than there is sensors for. So if people are looking to replace conventional gauges with OBDII directly it's not going to to happen. Being fuel pressure and EGT's are not part of the ECM sensor array. So that being said I want to learn how to dig out the hidden bits of data that are floating around the ECM & PCM like fuel temperature and Transmission temp. Those would be a nice addition and goal to reach for. As for what I know. I know that both my 1996 Dodge Ram (Gas) and 2002 Dodge Ram both use ISO 9141-2 (5 baud init, 10.4k baud). The refresh rate is roughly 4.2 PID's per second. I know that out of the standard OBDII data there is 10 known PID's for the 2002 and 14 PID's for the 1996. Being the 1996 is a 46RE automatic I should be able to tap the transmission temp sensor and get the fluid temp. Then on the 2002 Dodge I know the VP44 has the fuel temp sensor and modules like Quadzilla and Edge both can read this data from the OBDII port. The biggest thing is doing all the reading of SAE and different OBDII standards. Bad part is Cummins did NOT follow the OBDII rules so the extended data is going to be a bit tricky to find. Now are a rule of thumb most manufactures changed from Mode $01 to Mode $22 for extended data. But like after doing my study work for the past two days finding Toyota uses Mode $21 for extended data. So this just makes addressing a bit tough. So I've been digging into ScanGauge II and seeing similar things of data and addressing. That's what gave me the break I needed was looking around and finding header address 68 6A F1 used on most ISO 9141-2 even if you look close you'll see ScanGauge uses the same thing. http://www.scangauge.com/support/x-gauge/xgauges-for-iso-vpw-vehicles/ Which now looking again tonight as I type this. I starting to understand the ScanGauge II X Gauge format in rough layout. TXD (Transmit Data), RXF (Receive Filter), RXD (Receive Data), MTH (Math). So after the ELM 327 document you'll see how the ScanGauge II does the data search for the information and displays it. But to keep the confusion down I like the Android Tablet idea much better because your working with human readable information and not strictly Hexadecimal like ScanGauge II. So now just look at (link below) and look over the Mode $01 data. This is what most tools like ScanGauge II are capable of seeing. Now If you got the talent for ScanGauge II and Hexadecimal then you could follow along and get the extended data to work also. http://en.wikipedia.org/wiki/OBD-II_PIDs Now open this up and flip to page 15. These PRN's are the extended data hidden in the ECM. SAE J2178_2v002.pdf Like PRN 102F is engine oil pressure, PRN 1044 Fuel Temperature, PRN 180B on page 16 is Transmission Temperature. Just going to take more study time.- Amsoil intake fail
Look a bit long at the picture the filter appears to been struck from the firewall side. (On the end cap?) Look close at how the metal screen folded up.- Spuratic fuel pressure
Always love every ones fuel pressure numbers. Fact is Dodge states 10 PSI as a minimum. As a group we state 14 PSI to keep the overflow valve open (Unofficial). But I love hearing the all the pressures ranging from 5 PSI to 10 PSI from all the different shops.- 2005, Cranking No Start, No Communication at all, No gauges, No low beams as of a week.
Just for information value... If your ECM did die then here is a spot you could try. http://www.kleinbottlecomputer.com/- rear LEDs
Ummm... Stock bulbs. Funny thing is I've still got factory light bulbs all the way around the truck yet (except headlights). Never lost a taillight yet. http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Taillight-Bulb/_/R-LMA3157_0455488658- How Much?
Dorkweed's sense of humour is still going...- OBDLink LX and Android Tablet
Ummm... You are too quick to give up. How about... http://www.obdlink.com/mxwf/ Designed just for Apple products (iPhones, iPads, etc.)- Amsoil intake fail
That's the thing the metal screen is what gives it structure. So I really doubt its heat cause. Your hood isn't making contact with the filter is it? (Crushing)- Amsoil intake fail
That looked very similar to a filter a vendor sent to me to try but when I got the filter it already had the standard pin holes like K&N filter does. From the picture it appears to be a standard washable media filter. So my bad on that... But I wonder what the price of the filter vs. the life span before being consumed now? Being its not washable how many miles will it go before pulling a water column vacuum on the filter? As for the damage if there is no holes visible I say go for it. But if the media was distorted enough to create a pin hole I say replace it. EDIT: Looking back at the picture. You didn't rotate the filter did you? If you didn't move it then I would say its possibly been sucked down. But if you did rotate it from the bottom then I would say it was damaged from beating against the fender. I can't see getting damage on the top of the filter unless it stands taller than a BHAF which mine barely rubs the hood near the firewall. But still mine is not tied down and not distorting.- 2002 Hard start, occasional stall, not fuel related (this time)
Just probe the wire with a test light to see whats going on. - OBDLink LX and Android Tablet
