MAP sensor
Trade sensor with someone else first before buying a $100 dollar sensor. At least verify the sensor is truly the cause and not a bad TST box or wiring issue. Cleaning the sensor will do NOTHING. 0% of all MAP sensors that have clean have ever fix any issues.
New tires
Like my TowMax ST tires (Loard range D's) on my RV are 5 years old now. Coming due for replacement. Then my BigTex trailer is 2 years old with Maxxon ST tires (load Range C's) as well. No issues with either trailer and limit road speeds well below the 65 MPH limit of ST tires. If you trading up for LT tires watch the specs closely. You might gain on the speed angle but lose on the weight capacity also side wall strength.
ABS Control Module and Edge Comp
Yes. Make sure the Edge Comp is unplugged before flashing. This just ensures there is nothing to goof up the flash process.
Where all you guys/ gals live.... is it gettin' crowded too?
Here is a example of how crowded. Went to Council, ID to take care personally stuff. Drove along at 55 MPH and ended up behind a semi and two other vehicles driving slow because it just snowed few hours before. Roads are just wet. But from my house to Council, ID in 1 hour exactly for 52 miles. Then got done there and turned around and went to Grangeville, ID and taken care of more up there. Idaho county is the largest county of Idaho State and it only got 1 traffic light in the entire county. Crowded??? Where? Go to a large city like Boise, ID and you'll see crowded.
Steering Brace
Join the club but I found that excessive pressure in the front promotes the wondering issues. Like scaled weight is 4,400 in the front. 4400 / 2 = 2200 / 3042 = 0.72 x 80 = 57.8 (58 PSI). The only change I've done is drop 5 PSI from the math to 53 PSI.
Paint Help
Still say you've done a good job restoring the body paint to a good level of appearance for a rattle can.
Paint Help
Not bad at all for what I see on my monitor.
Turbo Kits
The best solvent that I was told for peeling all that baked on carbon and junk is Carb Dip. Just make sure to remove all rubber part before dipping.
Steering Brace
Now try doing the tire pressures like Wild and Free suggested it will change the way it runs too. Shocking but true.
hello from cali
What year of truck you want? I might just have what you want...
Where I'm at there is so little traffic till summer time then it gets a little busy but still not bad. Hard to get crowded when you have to either live on the benches of the canyon bottom above flood level or find a way to built at the top of the canyon and plow your own roads in and out.
Good Morning
We had a winter but nothing like what I've seen in the past. Typically we have 2-3 feet of snow here and I spend nearly every day plowing snow. This year I think I plowed maybe 4-5 times.
Good Morning
Heck last night I woke up at 2am to the sound of rain pouring down on the steel roof. I mean pouring down.
Weird Water Temp Readings
Just take note of it. Might be just a fluke. I won't jump at changing thermostat right away.
Troubles at home
You an JAG1 need to get together and chat sometime. Sometimes you need a different point of view to understand what is going wrong.
Good Morning
Strange enough spring start in February which was weird for us. We typically have snow on the ground yet and spitting snow off and through this month. Ummm... No. It would be a extremely cold ride and long walk home. This green??? Wait till April / May and the water is turned on. Then we'll have green grass. This is just half dead lawn from last year.
Good Morning
It was a beautiful morning here so I grabbed the camera a shot a few pictures of the sun rising over the canyon.
Factory stereo amp location
The factory amp is mount directly on the front speakers in the doors. There is one amp per side so there is a amp on left that drives all the left side speakers and then there is a amp in the right door for all the right side speakers.
apps keeps going bad
Pull the fuel filter out of the way. Then there is a Allen screw holding the plug into the ECM.
Welcome to the family... First off did you test for excessive AC noise from the alternator? Grab a digital volt meter and test right at the alternator BATT terminal it should measure less than 0.1 AC volts. Second did you do the diagnostics for the error code? http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/151-p0122-apps-sensor-signal-voltage-too-low
ABS problem
Time to collect warranty on the ABS computer and then check for alternator noise which should be below 0.1 AC Volts.
P1690 thrown
Most likely from the top. You'll have to pull the stock fuel filter out completely and then your looking right at it.
Valve seals
Vise grip would be in the way of valve retainers that you have to remove.
TRUCK VIBRATION FIXED !
Fixed for you...
Mike will you please be more specific as to exactly what you want.
Even if I follow his example... https://www.autorepairhelp.us/ But then certain amount of the members would most likely bail out to degree.
