Dieselfuture
  1. Had flurries here in Iowa this morning after all this rain we had for the last couple of weeks, these are all farm fields
  2. My hands get sore once in a while, don't get any ideas now.
  3. These are older pictures but you get the idea
  4. I got SS nerff barrs, I would not put running boards on if you have any salt on the roads. There are some newer push button bars that telescope out from under the truck but pricy
  5. You have to wait for the wts light to go off, ECM is booting up
  6. Always good to double check gauges against themselves. I have two gauges for fuel pressure and for boost, one through the quad and one mechanical iss Pro
  7. Took years to build it, some good old virgin steel, not beer cans they use nowadays.
  8. Which road were you on and what part did you drive through. Can't really miss my place, has a tall privacy fence I like the fed over rebuild dodge better
  9. Your phone is fast to correct you, mine does the same thing, very annoying, stupid AI
  10. Morning Mike, you're up early for being in your timezone. Time for the liquid adrenaline
  11. Get rid of that pos. If you're going to spend money on the good pump, I would almost go mechanical like fuel boss, but there are other ones out there and you can maybe live that Airtex just to prime the system, but definitely get it off ECM power. Another thing to do would be, have all your fuel lines in 1/2 inch, and I mean all, return, inside a fuel basket if you have one, ect.
  12. what he said ^^^, probably just a coincidence. And if you use any kind of biodiesel you don't need to add to cycle to it.
  13. Why is your fuel yellow, is it straight biodiesel. I could have swore the last time I looked at my fuel it was more greenish color, unless it's all that two-stroke oil
  14. That's ok not everyone needs training wheels
  15. https://mopar1973man.com/forum/185-standard-quadzilla-adrenaline-tunes/
  16. No, synchromesh only, unless you want to try and repot back with results I've read of few people running something other than synchromesh but never heard the end results, probably sold the truck and never found out.
  17. They did what they were supposed to, I'm not complaining about it a bit. I took my chances gambling with programming a used and unknown to me ecm.
  18. Looking at your armature, you'll still have some ac noise, just judging by my experience.
  19. It's for new generation ecigarette
  20. There is a delay relay mod or you can actually buy a relay with a built-in delay already. Sounds kind of confusing I know. But if your truck starts with half a crank like it should, there really shouldn't be a problem starting. plus ECM Cycles power to lift pump so it's not going to be full pressure till the engine does start
  21. https://www.ebay.com/itm/Lighter-Socket-And-Removal-Tool-New-Lifetime-Warranty-Dorman-56457/401462334168?hash=item5d790512d8:g:jtEAAOSwYc5aOAEZ:sc:USPSFirstClass!52722!US!-1
  22. When I made my own adjustable track bar in bought a poly bushing for $10 that was meant for bottom and used it on top instead of the ball. I still have factory press in kind in bottom as its still tight and the one that is meant to replace it at top. I was cheap at that time that's why I made my own, now I would probably just buy a kit.
