Me78569
Everything posted by Me78569
  1. It is explained in as much detail as I could There is even a youtube video..
  2. because there was a HUGE HUGE HUGE amount of work that would have needed to be done to make the old lvl 0 be the new level 1 and valet mode be lvl 0. nearly all sections of the code would have had to be redeveloped.
  3. I dont honestly remember %100. I think you tie in a 5 volt source to the pin 7 using a 10k resistor. Then the pin 7 goes to your arduino sensor input pin.
  4. There are OEM datalogs in this article you can also do the datalogging yourself and see what OEM timing is doing
  5. it's 0 here now and looking like -10 tomorrow. We will be seeing -30 before to much longer.....
  6. Anyone that says electric is free is clearly not looking at the entire picture. My excitement is in the technology and how well electric is suited to a drivetrain. The automotive world will look alot different in 20-30 years.
  7. yea, money is being throw at it rapidly now. hopefully the grid can catch up
  8. https://www.motortrend.com/news/toyota-solid-state-battery-ev-2021/ Solid state batteries in testing next year. wide production of solid state batteries will help all around with range and charge times. We will see where Musk ends up with his cathode free and cobalt free as well. interesting stuff.
  9. I think you it just needs to get up to temp. it looks to me like exhaust from a truck that has sat for awhile. I don't think it is coolant or oil.
  10. I am not sure if the CR3 pump suffers from the same issue with fuel spec as the VP44 does. I don't run 2 stroke as I am pretty sure bosch took US diesel into consideration when deisgning the pump.
  11. That would be my guess. I would run it for a bit and see if it clears up.
  12. I would jump to anyrhing yet. How much white smoke are we talking about? How long has the truck sat for while parts came in?
  13. someone turned on winter mode. we have had a few days of -10* so far and the snow is starting to build up finally. Ice fishing has been slow, but it is better than working.
  14. call DAP up and get some 7 x .010's and a sxe 62. that's a proven 500 hp setup that is well mannered.
  15. My truck always did this. I never worried about it. Also timing is hugely high to start on cold morning.
  16. I am not a fan of the 2stroke from them. I don't like moving parts of that nature.
  17. I had the issue with sloppy shifting and it was part number 3 in the top diagram. there is one on either side of the rod that centers it.
  18. I'd do the quad + the 57 gxe + 7 x .010's for a work horse build if I was going to build one today.
  19. here was my messing with it. Keep in mind that 320 bar is not creating extra wear. 310 stock is only the pop pressure, the pump continues to build pressure's much higher than 320 bar. I ran all the way up to 350 bar witout noticeable issue. I noted the best mileage and smoke control and driveablity at 330 bar. Was it worth it? I dunno looking back on it, it was fun to mess with, but the normal guy wouldn't notice.
  20. Make sure you don't have OEM high idle enabled. that's what it sounds like.
  21. 23k is too much for 200,000 miles in my mind. It is still a vehicle and stuff wears out.
