Me78569
Everything posted by Me78569
  1. Old and new tunes are the same. Dd vs towing vs mpg don't really need different tunes. Mpg is best when you use your right foot correctly. Towing is best when you turn power down and fun driving is better when you turn power up. Use the tuning as a way to tailor the quad to suite your driving style. I like. Lvls 5 Timing 7 or 8 Timing scaling g 80 Tps pump min 30 Tps pump max 100 Can Tps min 20 Can Tps max 100 Boost scaling 25.
  2. Had an issue exactly like this due to a bad crank sensor. They can do funny things.
  3. I give Mike a hard time about mullets, but I figured I should share the love nothing like a Redneck wedding. See Mike, Mullets are still awesome.
  4. That could be it, but I would think you would notice the truck cranking at a slower rev only on one battery in the cold. I'd replace the cable regardless.
  5. Pretty much right in the middle of the back of the head. Follow the t up to the head. Replace the washers on the VP they are cheap.
  6. More than likely yes. check the back of the head and the fuel return t near the firewall.
  7. The last group of moog parts on my truck didn't last at all. I could use the Ball joints as bells after 10-15k I went Rayebesto on my wifes truck for the entire front end and it is staying tight.
  8. I use the yellow teflon tape typically. Little late to the party, but
  9. Park nose downhill and report back.
  10. Yea, nature of the beast, I have cut large sections of wire out of my truck and replaced it with new stuff.
  11. Cowboy, Figured you would like this project I am working on calibrate tool for the vgt holsets.
  12. Got ya, Can you take a picture? Both the Transfer case and Tranny use AFT+4 so either could be leaking. transfer case R&R is pretty cheap ~$150 and easy to do. I just did mine and I wrote an article on it. IF it is the output seal on the trans you will need to drop the trans case then replace the seal. I honestly don't remember if you can replace the output seal on the trans wihtout pulling the OD housing. I think you could.....
  13. https://youtu.be/RwX_EpNR4CA
  14. The canister on the side of the block is a heat exchanger, it helps warm up the trans fluid when cold and cool off the trans fluid when hot. Where is it leaking from? The lines?
  15. OR this article for early trucks
  16. Does it have a lockup switch? If so return it back to stock and see what happens. if there was a short in the switch or something you would all sorts of issues.
  17. I have never tried setting the pump min up to %99, that would be IF she did floor it to %100 it would give all wiretap fueling instantly. Not sure how well it would work hahah.
  18. The trans won't downshift if it is locked, if you go to "n" I think it will unlock and the. You should have 1st. Not that it helps the issue. I am not expert, just thinking outloud.
  19. no idea haha....I am not much help I would guess the lockup solenoid is sticking open. When he stops, and pulls it to "N" the goes back to D is the TC still locked?
  20. I guess yes, but the arduino code talks to the turbo, if the turbo says the internal temp is cold & the arduino detects idle state it will go into warmup mode and close the turbo down. Pretty nice.
  21. She is a great dog......plenty of personality, talks back, and is lazy..... eats birds / rabbits / mice....... I was pretty tore up when we took her in way back when. Glad we got some more time with her.
  22. Well got to thinking today that stuff is going pretty good. Sure I am poor and my truck rattles, but I have a house, food, and a wife so how bad could it be? Anyways thought it was a good time to share some pictures of the little things. Nokie 8 or 9 years old.... don't remember. 1 year and 4 months ago she was given a month to live due to Cancer. She is sitting next to me now as happy and healthy as can be. Gotta say life is treating me pretty well, who knows how much longer she has, but I don't worry about that.
  23. Upper right corner, Account Settings, Signature
  24. turn it to lvl 1 Or timing 5 time scal %100 fuel stretch 1200 tps pump min %70 tps pump max %100 tps can min %50 tps can max %100 boost scaling 40
