Me78569
Everything posted by Me78569
  1. DAP would be my choice
  2. I was not ready for the amount of stress reduction my 2018 gives me compared to my 2nd gen when towing. you can tell the 4th gen is worlds more capable, even though it has ~150hp less than my 2nd gen had.
  3. there is no comparison between my old 2nd gen and my 4th gen. you couldn't drag me back into a 2nd gen
  4. Agreed. Assuming the quality of the 2 is the same.
  5. The random numbers are "aids" which are the software names in the quad program for each tuning variable. They are not in any nice order which is why we built the tune builder. I don't have the list of what is what anymore.
  6. Can you post the same to this sticky? https://mopar1973man.com/topic/12839-how-to-import-export-custom-tunes-in-the-iquad-app/?page=7#comment-220683
  7. Using the part number lookup tool for a 2002 you can see the group 2 section that starts with 2wd front end. It has the part numbers for everything you need. Plug those part numbers into rockauto.
  8. have you used the part number lookup tool and just searched using the part number?
  9. It's in the tune section. https://mopar1973man.com/forum/185-standard-quadzilla-adrenaline-tunes/
  10. Pretty much that. The long bed shaft is pretty long for a single unit.
  11. done, sucks that the brakes were not working.
  12. Bad designs happen, which is why a warranty is offered.
  13. I can't imagine living through the times she did. I wonder if we will see the rapid change she did over the last 96 years.
  14. Seemed like the day would never come (in a good way). Rip
  15. as it should. aftermarket items should really not be added until the warranty is up with the manufacturer. Kinda crazy in my mind to spend $50,000+ on a new truck then install aftermarket powertrain stuff on it. have there been many issues with the Oem lift pumps on 3rd gen + trucks?
  16. You can be under 450 by just not using wiretap levels. In my mind it will be a nice setup with the 62. A 57 would be better, but I wouldn't be having buyers remorse.
  17. 50*'s at night and 80*f in the day. river is right at 70* so we have been water skiing and wakeboarding daily.
  18. Issue is not in the tune. Your load is high at idle so it must be something in the pump or injectors causing you to need a lot more duration than normal to run.
  19. what injectors do you have and how old are they?
  20. Me78569 replied to Mopar1973Man's topic in Ford
    I dont think I have ever had a good uhaul, I dont think it has much to do the brand of vehicle.
  21. Yep, if I do that then I am more likely to want to cut more wood at another date. if I go hard for a day I am burnt out.
