Anyone use any oil drain valves in place of the drain plug
- Replies 19
- Views 4.3k
Bullet 3 posts
JAG1 2 posts
Leaky88 2 posts
hdpwipmonkey 2 posts
Yep...that's the one I had. Your assumptions are right on the money...it did drain a little slow. It did however give me enough time to drink another beer while it was draining.
I drive over sticks and grassland.... different things so I don't want the worry of a quick easy drain down there. I ordered new drain plugs from Genos for both my 2nd gens and like the bigger socket
Volvo earthmoving equipment use a nice oil drain that uses a drain adaptor to open the valve but they also use a cap which is screwed back onto the fitting for added insurance, I'd say it may be too b
I just got done changing the oil in my truck. This is the first time I changed the oil myself. I used Goofy-Lube the last 2 times (I know, I know, WHY would you do that...). When I went to take the drain plug out I noticed 2 issues, one, the square spot where you put you're 3/8th inch socket wrench was partially stripped (Goofy-Lube) and two, the plug was so tight I had to get a cheater bar to break it loose (I won't be going to Goofy-Lube anymore).
My question is if anyone uses any of the drain valves in place of the drain plug. I saw some for sale on Geno's Garage like this one and this one.
Just not sure how safe it is having something like that hanging down off the bottom of the drain pan.
Any thoughts or experiences with them?
Edited by hdpwipmonkey
