Anyone use any oil drain valves in place of the drain plug
I just got done changing the oil in my truck.  This is the first time I changed the oil myself.  I used Goofy-Lube the last 2 times (I know, I know, WHY would you do that...).  When I went to take the drain plug out I noticed 2 issues, one,  the square spot where you put you're 3/8th inch socket wrench was partially stripped (Goofy-Lube) and two, the plug was so tight I had to get a cheater bar to break it loose (I won't be going to Goofy-Lube anymore).
My question is if anyone uses any of the drain valves in place of the drain plug.  I saw some for sale on Geno's Garage like this one and this one.
Just not sure how safe it is having something like that hanging down off the bottom of the drain pan.
Any thoughts or experiences with them?
Edited by hdpwipmonkey
  • Replies 19
  • Views 3.7k
  • Yep...that's the one I had.  Your assumptions are right on the money...it did drain a little slow.  It did however give me enough time to drink another beer while it was draining.
  • I drive over sticks and grassland.... different things so I don't want the worry of a quick easy drain down there. I ordered new drain plugs from Genos for both my 2nd gens and like the bigger socket
  • Volvo earthmoving equipment use a nice oil drain that uses a drain adaptor to open the valve but they also use a cap which is screwed back onto the fitting for added insurance, I'd say it may be too b
I drive over sticks and grassland.... different things so I don't want the worry of a quick easy drain down there. I ordered new drain plugs from Genos for both my 2nd gens and like the bigger socket I can use. Your right about staying away from the oil change goof balls. I've been changing my own oil ever since I was 16 and still don't mind doing it.
I used one on my previous truck with no problems...definitely made it easier.  The one I used didn't resemble either one you listed though.  It was a setup similar to a valve on a tire stem (push to release).  It had a separate fitting with a hose that screwed onto the pan fitting that released the valve.  A little more tamperproof than the ones you listed.  All my trucks have always been lifted so I never had any problems with ground clearance.
On this truck I replaced the OE drain plug with an aftermarket that has a separate gasket and a hex head on it for easier removal.  I also replace the gasket periodically.
39 minutes ago, JAG1 said:
I drive over sticks and grassland.... different things so I don't want the worry of a quick easy drain down there. I ordered new drain plugs from Genos for both my 2nd gens and like the bigger socket I can use instead. Your right about staying away from those goof balls and doing it yourself. I have been changing my own oil ever since I was 16 and still enjoy doing a good job of it and not having a hoser doing it.
I don't usually go off-road with my truck, at least not yet.  I'd be more worried about something kicking up and hitting the valve but with it needing 2 movements to open the valve I'm not sure how easy it would unintentionally open.
I usually always change all of my own oil except on my wife's rubicon because we have it covered from the stealership :spend:and on my truck because I didn't have a catch pan big enough for 3 gallons of oil (until today).  From now own I'll be doing it myself.  Both times I had it done at Valvoline they "forgot" to lube the truck at all. :doh: The last time I pulled it out and stopped in their parking lot and checked and then pulled back around and pulled it back in and made them do it.  I honestly don't know where they get some of these guys at... :shrug:
I saw one similar to that on Geno's site too (here) but in the video it didn't look like it drained as fast as the others I linked.  I did like that it was a little lower profile then the others though.
Yep...that's the one I had.  Your assumptions are right on the money...it did drain a little slow.  It did however give me enough time to drink another beer while it was draining. :party:
Volvo earthmoving equipment use a nice oil drain that uses a drain adaptor to open the valve but they also use a cap which is screwed back onto the fitting for added insurance, I'd say it may be too big for the Cummins sump thread though
Cat use a small tap which really does look wrong but in 40 years I've never seen one leak or come undone
I have that first one you linked to, got it from Geno's.  I've had it on about 3 years with no issues and I have gone off road and through some fields with it as well.  It's nice being able to change my oil without needing any tools.
I had strongly considered one of those with the green hose.  I'm still on the fence as to whether I should change my oil pan due to damage, and the new pans have an 18mm drain vs. the 22mm we all know and love.  Until I finally make up my mind on the matter, I won't be buying a drain.  I'm also not sure I can justify the $50 cost when I only change the oil a couple of times per year!
id be afraid of the valve being opened by some punk thinking he is funny or someone getting back at me because they got butthurt somehow.   and i offroad so not for me.
I to like the equipment drains with hose but also dont mind just pulling a plug out of a oil and tranny pann
When I worked at wydot we used something like this on plow trucks. You had to remove a cap and screw a hose w/fitting on that was attached to a pump and used oil tank. Worked great. No spills or drips.
At what intervals should the drain plug gasket be changed?
Thanks Leaky
Thanks Leaky
I don't know what interval is recommended for an aftermarket but I change my gasket every other oil change.  The oem plug doesn't have a replaceable gasket if I remember correctly...it's built in to the plug.
I have used both of those, the ez and fumoto. I put them on all my trucks and they are well worth it to me. I have a fumoto on my current 98 and I also put one on my girl friends jeep. The fumoto I got for her came with a little lever clip, for her piece of mind, but ive also used a small hose clamp where the lever is in the past.
That is what I-was thinking also. Aftermarket is all readily found.
I have entertained getting the quick change set up but also fear some one draining it just for spite.  Thanks Leaky
Thanks Leaky
When damaged or weeping. 398k miles still on the OEM plug seal.
I've been changing my own oil since 15 yrs old (1966). If suddenly there was no plug to remove using a socket and wrench I would probably get all dizzy and step right in the oil drain pan.
I think when I get more oil filters from Geno's I'll be adding a Fumoto drain valve to the cart too. :thumbup2:
485k and still on the oe plug.
I'm still on oe plug, but for next oil change I got a new one from Cummins for 10 bucks. Mine has a small tear in it, not leaking but not taking any chances ether.
