  1. Old video... It will show first attempt a ari bubble comes through on the second it shows the 50% duty rate of fuel pressure bouncing.
  2. Start of next week I've got to head right into the hub of it all and get Eileen's medication being they will not ship pain meds.
  3. Above 15 PSI mine won't start either. That's why cranking pressure is dropped is because too much pressure will cause over advanced timing. This is why ECM duty cycles the power during cranking to reduce fuel pressure. Like pull the belt and test. If it starts hot then it's too high of cranking pressure. Like us electric guys just unplug. If it's still a problem there is a delay relay that could hold the power off during cranking. This is not an option on mechanical pumps.
  4. I pulled my other fire radio from the shop and fired it up in the house. Just mere minutes ago I heard the first case of Corona in Riggins, ID head to the hospital in McCall Idaho. I know of 2 cases in McCall already and one for sure in Riggins, ID.
  5. No. There is literally nothing to see. It's all by feel. No way to even make a video with my big paws in the road. You can't even see the sensor from the top.
  6. Too high starting pressure needs to be 12 PSI down to 7 PSI.
  7. Hes got pre and post EGT's.
  8. In the this case the cam sensor got replace that stopped the P0341 code. Then the grid heaters remain unplugged for now and still the circuit breaker is holding. My new one is here on my desk waiting to be installed. Oh just for teaser... Cam sensor on a 2001 truck can be changed in under 30 minutes.
  9. Up here in central Idaho isn't too bad. Most have started self isolation at home way before the press release of the notification. Highway past the house is quiet most of the time. Already have cases of Corona in Riggins and in McCall already.
  10. It will help it. Less restriction, easier flow. DDRP are not all that hot of a fuel pump. Typically mount in the factory position.
  11. VOID stickers typically around the VP44 plug, usually removed or torn after replacement.
  12. I always suggest 1/2 inch lines better pressure stability. As most of us tend to upgrade power a bit more and add tuners for performance and/or economy reasons.
  13. Funny, @Wet Vette little Hyundai whips the 1996 Dodge no prob... 2002 not happening...
  14. Just getting broke in... As for the VP44 pumps they will go 250k miles on average. You do need to upgrade the fuel system. 14 to 20 PSI is good fuel pressure.
  15. Module Master https://www.google.com/search?q=module+master 2006 S Main St, Moscow, ID 83843 (208) 892-0764 Comes with 5 year warranty and all parts used are upgrades. All for $130... https://modulemaster.com/rebuilds/shop/brakes/abs-modules/abs-kh-dodge/
  16. Yes just last week a EMT was traveling too fast to respond to a call and wound up rolling her vehicle off a mountain road. She survive with injuries. Out here you cannot just rely on service brakes to survive 7 to 15 miles of downgrades. Most of the dirt roads could be in the 6 to 12% grades on average. There are some roads 16% and greater and most are not marked. No matter what its super nice to come down a grade without touching the brake pedal and keeping your brakes cool till you need them. Not hoping for the already hot and smoking brakes to stop you in time. @JAG1 found out that without a exhaust brake it will heat the grease up in the front wheel bearing and shortly afterward the wheel bearings fail.
  17. Always rev match my gears to lighten the load on syncros. Easy peasy... Try the bigger grades like 16% grades in the back country. The 6% and 7% grades are child's play. No riding the brake pedal in any of my videos. 90% of all stopping is done with exhaust brake. Even fully loaded with firewood, or hauling my RV trailer which GVWR is 8,500 pounds.
  18. When the alternator field shorts to ground on the blue field wire it will completely burn up the PCM. This will cost you about 750 dollars to replace. Not to mention it burns up the voltage regulator completely in the PCM. The fuse will protect the PCM from any damage from bad alternators or wiring faults. Being the master fuse for the PCM is 20 Amp and the circuit board will not tolerate the 20 Amps on the PCB tracers at a dead short. The 5 Amp fuse blows early enough to prevent damage and been proven by another member that had a alternator short out and blow the field fuse. The fiberglass circuit board is gone there is nothing to repair.
  19. Yes, more than enough time. No difference. I will not engage unless you seriously lagging on throwing a gear but with the exhaust brake on it just going to hiss a bit and not impact the shift. You can tap the throttle once and reset the 3 second delay. I've got a few other tricks. I've got a toggle switch on the stick. So when I'm traveling a grade I can let the truck coast and time to elapse the 3 seconds. Then when I toggle the switch its instant on exhaust brake then. Still to this day I'm doing brake pads replacements evey 180k to 200k miles. I use the exhaust brake for 90% of all stopping power. The service brakes (pedal) is only used below 25 MPH.
  20. Beyond that you'll need to have the ECM repaired if the flashing continues I would contact Auto Computer Specialist in Florida.
  21. W-T ground wire mod and the Alternator protection fuse is my suggested starting spot.
  22. Even the older generation is being just as bad too. I've got people coming to me and saying "Everyone is going to get one way or another why bother trying."
  23. There was a guy a while back that did a rocker panel repair and cab corner repair. He explained it all on the website here. I'll try to find it.
  24. Like myself I just reduced the rolling resistance and don't need a deeper pan, or strengthening. My little 46RE @Dynamic built it 4 or 5 years ago. Since I swapped up tires to 215's on the 1996 Dodge 1500 now this little truck has some pretty low transmission temp even on the hot line. Typically float about 140*F. The only time I seen high temps was towing up a residential 8% to 12% grade to public lands to ride my ATV. Then we got it up in the 230 to 240*F realm. Speed limit is 15 MPH up this road. Can't get lock up so it was on the torque converter till I got parked just past start of forestry. I left the truck in neutral and idling and the temp fell off quickly after eating half a sandwich. Then shut down the engine. This only happened once... I plan on changing the ATF+4 and the filter really soon. This is where a manual transmission shines. Because there is no slipping or torque converter to heat up.
