  1. Opps. My bad... Got caught off guard by a first gen poster.
  2. Welcome to the family Dante...
  3. Great example of the start up problem. I was doing wheel joints today and finished up. I fired up the truck and drove it out the door. Walk back in the shop grabbed my cell phone started the iQuad App and tossed the phone on the armrest. Came back after about 5 mintues and checked it out. iQuad tried one time and failed, never tried again. Shutdown the app and start again. Left the phone on the armrest again. Changed clothes. Came back again after 5-mintues tried once and quit again. Just sits there with all zero'ed gauges. Even though the truck has been running on high idle nearly 10 minutes and can't connect. After 4 more tries it finally decided to hook up and display. The only trick that helps a bit not always is make sure the iQuad App is started first before the truck. Even then the app hang up and does its one time try and quits trying.
  4. None. It would force itself down the highway till it burned up. Correct. Even the newer 6.7L truck with a VGT turbo will do the same thing. They don't detect high driver pressure.
  5. I've got the same style of wastegate bracket as in the video it would be super easy to just pull it off and add the spring and eye bolt.
  6. PCM must remain hooked up its the source of the network. This is why 24V retro fits in to Ford or Chevy have issues because all they use is a ECM and there is now no OBDII port since the PCM is the master controller. The ECM is secondary.
  7. The boost fooler I'm running now I really can't get a good adjustment from it. I'm wondering how stiff of a spring do you have to run to make this work?
  8. Running a ground to the chassis of the PCM will do nothing. None of the internal circuits ground to the case of the PCM. If using an external regulator I highly suggest you only use that is a temporary fix till the PCM is repaired. External regulators were discontinued because of charging problem based on its method of temperature detection. PCM ground is the actual passenger side battery terminal no added ground required. If you want a good ground system look at W-T ground wire mod. My simple version...
  9. You need to read this article and do the testing. It could be any module causing the issue of communication. Basically if the CCD network is shorted to ground, +5V or +12V that network is dead. You need to measure the CCD voltages which should be 2.49 and 2.51 volts out of the OBDII port. Then if they are not, keep disconnecting modules till it returns. The module you disconnect and the bias voltage returns then that is the module that failed. PCM supplies the network its required. I'm pretty sure the Cluster is what supplies the bias voltage. @Chris O. I think can verify this.
  10. I've seen setups like this... Personally, I don't have one. I'm not particularly impressed with it. Manual exhaust brake controls can be done but you have to instruct all people using the truck to make sure to not have the exhaust brake on while attempting to throttle this will for sure do engine damage as the EGT's will skyrocket. The only reason I know this is years ago I call a warranty claim on my exhaust brake the vacuum valve was sticking on and if the exhaust brake was applied yet as you throttled it would skyrocket the EGT's. I had to unplug the vacuum to disable the exhaust brake because of a faulty vacuum valve.
  11. The front axle needs to be centered with the rear axle. I don't know of a proper way to do this other than get it on an alignment rack where they can measure the axle placement. Might need to find a different shop for the alignment. Also make sure to explain to the shop that you are running custom parts and what is different and that you would like to get the axle centered. This way it can be measured from the rear axle and lined up properly.
  12. Interesting... Anyone willing to try this crazy idea?
  13. The other thing is once you got them that hot to things are going to be done. Replace the brake pads they are not designed to be cooked like that and pads will most likely fail later. The second thing is the rotors are not designed to be cooked either and you most likely have warped rotors now and take way too much to turn them true again. Other things impacted by the heat is the caliper pistons and the caliper seals. The pistons will cake up brake fluids as it heated and harden to the piston. The seals are only rubber and only can take so much heat. The brake fluid as well I would wonder what its condition is too.
  14. Too high you need it to fall in the 7-12 PSI other than that the timing piston is forced too advanced and makes it impossible to start. Make sure your lift pump is controlled by your ECM and that the operating pressure is not too high. This is the reason I suggest 15 to 17 PSI operating pressure. This way cranking pressure is low enough to start easy.
  15. Well, you better be careful the new bearing might be sitting on a store shelf too long. Bearing and the grease are not affected by storage. The grease lifespan is affected when excessive heat is applied like you hard braking down long grades. The bearing lifespan is affected by tire size and excessive wheel offset. The only thing that can be affected by weather and time is the seal that keeps water and dirt out of the bearing if the bearing seal fails then the grease will be contaminated with water, salt, MagChloride, etc and then the bearing life is shortened.
  16. According to different weather site average yearly rainfall is 11.56 inches. I'm past that already at 16.53"...
  17. For the amount of hammer time I've just spent on my truck, I'm rather tired of swinging a 6-pound hammer and heating everything up with MAP gas torch to get it apart. I just fought a unit bearing yesterday for 4-hours. Now gave up on wheel joint I couldn't move that also required 25 to 30 tons of pressure to just make the bearing caps move. Then now I've got to put it all back together again...
  18. Best to have the truck sent to an alignment shop and have it set properly. This will make an impact in thrust angle and if its going to dog track or not.
  19. Like here we got 0.27 inches of rain last night and for the year total 16.53 inches so far. Very dry here. Here is what I got minus the lightning detector. https://www.acurite.com/hd-display-with-5-in-1-weather-station-and-lightning-detector.html Very accurate weather tower. I like the idea of looking at the barometer and watching the pressure trends. I can then tell if the storm is small and move through quickly or large and hang around for the days. How strong the storm is etc. It also keeps track of a 1 year worth of weather data.
  20. Just trying to pull my driver side unit bearing off yesterday resulted in about a 4-hour battle. The Air hammer tool did not work. I spent a majority of time smacking that bearing with a 6-pound hammer to get it to even move. Spray the gap down with PB Blaster and let it soak in smack it some more to even get it to move. I ran my compressor so long I was blowing the breaker trying to get it to move. Now the reason for this is the fact this is the bearing that failed last year I replaced at a friends shop in Marsing, ID. When I did I didn't have access to anti-seize and other materials. It was installed clean and dry. The salt and MagChloride have played their roll and made this unit bearing nearly a solid piece with the knuckle. Not to hijack @JAG1 thread... Now the reason for the unit bearing to be removed was to do the wheel joint on the driver side. It was a factory wheel joint. (356k miles and 16 years). I couldn't get the clips out let alone move the bearing caps. I finally gave up at 4pm and called a friend in New Meadows, ID that has access to a 100-ton press. Needless to say, using about 20 to 30 tons of pressure to get the bearing caps to violently jump to even move. I would of never got those bearing caps out with a 6-pound hammer... Moral to this post... Just because you can install or have parts that can last 300k plus miles. I highly suggest against doing it. It will require even more effort to removing a part that has been installed in the suspension or axles for over 16 year and 300k miles. Make sure to use lots and lots of anti-seize on all parts and bolts!
  21. Wait to start lag is a bit off a problem pointing to ECM failure. As for lack of start is there lost of prime? Will the truck start if parked nose down? What is your cranking fuel pressure? (7-12 PSI).
  22. On mine some time it tries once and quits trying to connect. Which this forces to shut down and restart the app. Sometimes it takes several tries to get it to connect.
  23. Same here. Mine would the same as yours.
  24. Yeah I would say send it back for warranty work
  25. The speed data is digital. So both wires are required. Then if the CCD network is down to any device then the ECM or PCM would toss either P1694 or P1698 codes. So if there are neither codes then the network is functional. If the ECM has no CCD signal... If the PCM has no signal...
