Past 300k milestone
Tee fitting on gauge leaking
engine dies after hard acceleration, hard start/no start after
30 PSI of boost and just compression will produce 1,100 PSI of cylinder pressure without fuel injected. Add heavy shot of fuel and advanced timing I'm pretty sure at some point the injectors could be overwhelmed by cylinder pressures more so with high boost runs. This why you see drivers throttle tap couple of time after a drop of throttle to keep fuel flowing till cylinder pressures fall.
Inner Fender Splash Shield Retainer
Should be able to get the fasteners from most body shops. The part number look up books are in the article database. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/part-number-lookup-tool-2nd-gen-24v/
Electrical bug! Bad ECM
Totally based on IAT temperatures. If IAT is reporting 15F or less then 3 CYL mode will start.
Teardown and Rebuild
They won't hold up to the winter snow conditions and unplowed roads safely not to mention one deer or elk could possibly kill us both. My last trip home the snow plows were having troubles keeping up being 3 of them were trapped on the wrong side of a vehicle accident and the one lone plow was working double time so I was driving through foot deep snow to get home. Little car could never do that safely. Not to mention look at the fact in 4 month later I'm going to be 100k miles of going back and forth I've got way better longevity with the Cummins, way less down time, don't have another vehicle to ensure, register and put tags on, plus we don't have the funds to buy another car now.
Low system voltage
Correct the PCM controls the voltage regulation. The blue wire is a +12 KEY wire. The GREEN wire is a variable ground lead. So these two wires need to be checked for 0 ohm from end to end to ensure that the field is being charged on the alternator. Both Bosch ND alternators are externally regulated just like it has been for around 50 years! I would bench test the current alternator and verify both DC and AC ripple voltages. I doubt it will pass. Another spot to look that is commonly missed is the alternator fuse.
Prolonged starting after springs and pushrods
No, during the hard starting. If the gauge bounces or falls during cranking its a sign of air coming up the line.
Nice Truck Little Fuel Problem
Try parking nose down to see if the prime holds? Do you have a fuel pressure gauge on the low pressure side? What does the gauge do during cranking?
Electrical Gremlins
@Dieselfuture Focus... Keep your focus here. Different topic about BPA plastics and health issue. I'm taking about sulphric acid and what can contain it. Then giving an idea on how to protect battery terminals.
Quadzilla Warmup / High Idle
Actually just easier to unplug the entire Quadzilla module that way its protected.
Door hinge
I agree... WD40 is junk. I tend to get two types of PB Blaster. The standard PB Blaster for getting frozen fasteners apart. As for typically lube maintenance of the vehicle I like the PB Blaster silicone spray works awesome.
Accidentally putting gasoline in a diesel truck
Accidentally putting gasoline in a diesel fuel tank I know people have accidentally pump gasoline into diesel fuel tank. The tough part is proper repair for this would be to have the truck towed to a shop or home and have the entire diesel fuel tank dumped of the gasoline and diesel fuel mixture and fresh diesel fuel put back in the fuel tank before starting the engine. Some people just are busy and not paying attention and end up grabbing the gasoline hose instead of the diesel. The quantity of diesel fuel remaining in the fuel tank and the amount of gasoline pump on top of the existing diesel fuel is what will make the decision on towing or not. If there is a majority of diesel fuel compared to gasoline you might just get away with adding 2 cycle oil to the fuel say 64:1 to 128:1 ratio to bring the lubricity back up in the fuel. The other thing is gasoline is very high cetane rating. Back years ago and some still do mix kerosene or gasoline to the diesel fuel to prevent diesel fuel gelling. So if you do happen to pump gasoline fuel in your diesel truck small amount you can get away with adding 2 cycle oil. Do not use ATF which is way too high in ash content and will create other issues on top of the gasoline diesel mixture you've got now in the fuel tank. For truck owners that have a AirDog or FASS fuel system, you could use a jumper wire in the relay and output line. Basically, disconnect your fuel line and pump the gasoline mixed diesel fuel out of the fuel tank using a jumper in the relay socket this way the pump does the work for you and pumps the fuel tank empty if your gasoline to diesel mixture was too high. If you still have the factory fuel system you could disconnect that at the injection pump or lift pump. Then using a shop vacuum reverse the hose so it hooked up to blow air. This should produce enough pressure at the filler neck to push the fuel out of the tank and through the fuel line to a buckets or fuel container. As for siphoning fuel from the filler neck is impossible on most Dodge Ram truck being there is a rollover ball in the tank neck. This prevents you from getting into the tank bottom and getting the fuel out from the filler neck. Be aware that most shops charge a hefty fee for disposing of gasoline mixed diesel fuel. In the same token running the gasoline mixed diesel fuel in the truck will most like cost even more in damages to injection pump and fuel injectors replacements.
Thermostat
That about when my fan locks.
Map sensor mod
Get a Quadzilla Adrenaline and turn up the fuel where you need it. Way better control of fuel and can produce way more power without excessive smoke. Remember excessive black smoke is unburnt fuel.
99 Cummins - new to me pickup - that has issues
Might contact @Dynamic and see what he's got to say about you transmission issue.
Door hinge
Kind of like this... https://www.dormanproducts.com/p-24617-703-273.aspx?year=2001&make=Dodge&model=Ram%202500&parttype=Door%20Hinge%20Pin%20and%20Bushing%20Kit&origin=YMM
Thermostat
Yes. It does show a rise even though real pressure doesn't change. This the only time I see skewed numbers. As long as the temp is not fooled then the numbers appear correct.
Again why I'm listing here hopefully @Quadzilla Power or @Quadzilla_Stephen see it. Quadzilla now seen it...
Electrical Gremlins
If you take care of the end you can have old cables that are new. Like I'm still running factory battery cables and never had to clean them once. They never corroded only removed the cables maybe a handful of times. But i'll have 20 year old battery cables that are absolutely fine. I'll ask a question. What is the only two materials that can hold sulphuric acid? A: Glass and Plastic. Q: What is plastic made from? A: Oil. So if you keep your teminal damp with engine oil they will never corrode. As for grease or terminal sprays are OK but also messy and could stain clothing. Where engine oil typically leave a light coating and terminal can't oxidize.
H-Pump Info
Could someone post a picture of this pump I'm curious about what it looks like?
Door hinge
Again proper maintenance does wonders my hinges are still tight and no alignment issues. The only thing my driver side door got hyper extended on time when the wind snatched the door out of my hand and whipped it open. I've had to do some creative readjustments to get that door lined up again.
Thermostat
ECT has a effect on the oil pressure reading when colder. But comparing the actual oil pressure, CCD network message and the cluster the number are fairly correct till the engine is cold. Then the oil pressure reads high when the ECT is fooled even though the oil pressure is actually lower. Normal run though it good enough for indication of pressure.
2010 2500 Ram 6.7 Issues
I wonder if the contact is shot on the starter. That would produce the Bendix popping out for the flywheel but not power for the starter motor to turn the flywheel. Welcome to the site. Ask plenty of questions. We'll all try to help you out.
Consensus on tapped pump
Correct... For your OBDII people that is 100% engine load. Engine load equal fueling message just converted from 0 - 4095 to a percentage.
