  1. Not me. I will say it a good idea to pop the rear panels and drown your latches with engine oil which will keep them going and prevent rusting up. The lower latch the rod has to come up to release.
  2. @IBMobile @Honey Badger Dads RV is using the electric rock now. But I'll have a full hookup RV pad out back soon.
  3. Well, it happened again. @Tractorman and @JAG1 showed up here with RVs. They made it about 6pm last night. We took off and had dinner last night at River Rock Cafe in Riggins, ID. Thank you @JAG1 for covering dinner for the group. We came back to the house and sat out back for most of the evening till 11pm chatting away about all kinds of topics. @Tractorman truck and RV on the left and @JAG1 with his truck and slide in camper. Guys are still sleeping in and enjoying the quiet out here.
  4. Don't! Leave the factory filter there at least you keep the fuel heater for the cold months which is very helpful to bring the fuel temperature up fast being the electric heater comes on below +60*F. Now the factory filter is mounted in that spot because it's near the coolant passage in the manifold. This is why fuel temperature and IAT typically match in temperature on long hauls. Fuel temperatures of 80 to 120*F are good to have helps with atomization and don't require a ton of timing to get good MPGs. Above 140*F fuel temps are too hot and asphaltenes are produced this is the black material collected in the filters. As for diesel fire, I think it's just commonly overlooked stuff. Pinched wires from modifications, and fuel leaks that couldn't be seen, but I really don't think anything is in the fuel. Ammonia Nitrate is a powder form and placed in fuel but it is still going to be corrosive and eat up the fuel system. (Injectors, pumps, plug-up filters, etc.) Look closely a lot of fires start in the cab. Then start tossing in gasoline-powered Ford Rangers and little gasoline cars it's not the fuel now.
  5. Ok. So my OEM starter lasted a long while. I replaced contacts and then finally it died. I pull it and replaced it with a NAPA New Starter which lasted a long time as well. When it finally gave up I had my OE starter rebuilt which cost me more than my new NAPA starter to have rebuilt. It is currently in the truck now but from here out I'll most likely buy new NAPA starters from here forth. OE starter isn't worth the cost of rebuilding any longer just to save the OE.
  6. From my experience, a lot of times the front seal of the compressor starts to fail with a slow leak that can't be sniffed or see any UV dye being the pulley slings the dye off and covers the dye with dust and dirt that makes it impossible to see. Really can't sniff behind the pulley while the compressor is running.
  7. Thanks for the reply. At least we all know that is a was a air or foaming issues which is typical.
  8. Some of the videos are for sure electrical fires seeing the loom melted. All them are moved trucks in some form. Lights, winch, stereo and amps, etc. Some could be fuel leaks not being g dealt with like number 4 rail line cracking which is known on CR engines.
  9. Typically air in the system. Air will foam up the fluid and make it whine.
  10. There is a complete version of HIDs.
  11. Parts are on the way... Should be here tomorrow at noon or so.
  12. So, On TikTok, there are several people that just lost their trucks to fires. There is a feeling that something is being added to the fuel to create said fires. First off it's not possible. You don't hear of diesel tractor-trailers having fire issues or farm tractors having fires. Yes, I know red dye and on-road fuel are from the same source just one has red dye added to the fuel. It is very possible these younger pups are making mistakes with their ground lighting, rock lights, etc and not properly fusing or properly wiring up accessories even stereo amps, and head units. Yeah, there were several trucks posted up on TikTok burning down. Ford, Chevy, and even a Dodge so it's not just like one brand it's all the modified trucks. Typically seen wide wheels, rock lights, etc. Very possible it's an electrical thing and a rash of bad luck. In response to this I posted up on TikTok about the W-T ground wire mod, another video showing there is no electrical hooked to my batteries except the ground for the W-T ground wire mod and the alternator charge lead coming from my 150A breaker on the side the battery on the passenger side. https://www.tiktok.com/t/ZTRoSkjwA/ https://www.tiktok.com/t/ZTRoSkg2o/ https://www.tiktok.com/t/ZTRoSdaUB/ https://www.tiktok.com/t/ZTRoBExX6/ https://www.tiktok.com/t/ZTRoSBXvY/
  13. Geez... Never ceases to amaze me with the BS that manufacturers can dream up. This vehicle is in Riggins, ID, and the owner requested an A/C recharge. When I got there it had static pressure of about 30 PSI but not enough to fire the compressor. I added freon and when the compressor started the bearing noise was bad. Not to mention the compressor isn't pumping either. I shut it down and notified the owner it was going to require a compressor and other parts. I called NAPA and found out that Chevy used two different compressors in that year. I ended up pulling the compressor just to identify the system the compressor no longer had a part tag or numbers. After figuring that out then found out they used 2 different expansion valves. WTF?! Needless to say, it's going to be expensive to just get this A/C going again. Waiting on the green light to rebuild...
  14. The reflector with halogens is going to be the key to getting a good pattern on the road. Where the factory headlight was the lens that gave the pattern. Now for a bit more money put a set of these in the headlights. https://www.morimotohid.com/morimoto-mini-d2s-5-projectors?quantity=1 That would give you all the light you'll need. Excellent pattern, the reflector wouldn't matter. The only bad part is you have to remove the lens from the new headlight by baking it in an oven and resealing them after installation. Next down here are the bulbs I used in Minnie my 99 Dodge Caravan I know they are not the right bulb number but not bad in price. Then you based back on the reflector quality on how good the pattern will be on the road. The Minnie headlights for a pattern isn't bad, but it's not stellar either. https://www.amazon.com/gp/product/B07GGRHPPY/
  15. I've got more done. I got the outdoor WiFI antenna up. Then I managed to get the camera configured. I found out the internal camera software works way better. Strangely enough you have to find the cameras IP of the work group switch and then type that IP address into the browse. You configure the camera on your browser. It has movement detection and I could configure the camera to send the video files over SFTP. I've got to tweak the video area to exclude movement from a tree. Sadly I fried a WiFI antenna here in the house. Then WiFI head for my place was whining for a update for its firmware. So laying on my bed early morning I hit the update button. It started and run for awhile then FAILED. Sadly the internal software is damaged and will not boot up. I've got to call TP-Link Tuesday and finish my warranty filing to get my replacement WiFi head. So far in enjoying this setup. WiFi has been better. Better range and coverage. Internal network is fast. I can transfer files between devices pretty quick. As for the Starlink I'm pleasured. The speed is better on clear skies. But if it get stormy it slows down. Then if then lightning you'll most likely lose internet. My last large storm was dropping 8 inches of rain and hour. Rain lasted about 30 minutes. But the lightning continued most of the night. Yea about 6 hours of no internet. At least now with Starlink I'll keep internet when the power is out being my solar power home. With Ziply (former provider) when the power was out I would lose internet. Being the fiber optics require power to keep the light pulses going. Yeah wiring is temporary for now i might move things (WiFi and/or camera)
  16. Clear lens is better but the reflector has to been quality to make a proper pattern on the road. Cheap designed headlight will have a really poor pattern.
  17. Personally, I love my Morimoto D2S HID headlights the best which I installed in Beast. A very wide path of light and also a very tall path of light on high beam. Lo Beam is cut just right not to blind oncoming traffic. As for economy-based lighting, I got clear lens headlights for Minnie. Then installed a set of LED bulbs into Minnie. These are good but pattern of light isn't as good as the HID's as Beast has but OK for night travel. I would suggest not to opt for halogen bulbs just not enough light in a stock housing or after-market housing even a clear lens. I've even tried the sport headlights with the relay mod and they suck badly. Light is not where it needs to be. Small hot spots on the road by no width of light to cover the road properly.
  18. Well I'm back to wrenching. This rig was my room mate in the basement. Needed some knock sensors, oil change, fuel filter and oxygen sensors. Knock sensors aren't to bad to do. Basically pull the intake manifold. You need to both fuel rails off but the injector plugs are released on bottom towards the manifold, weird but ok. The knock sensors are under the two large rubber plugs with one wire to each. The front knock sensor came out easy and the rear the hex head kept collapsing. Using my angle drill I drilled 2 holes in the top of the sensor stuck my needle nose pipers in the holes using a long screwdriver barred that sensor right out. Then changing the oxygen sensors was some what a pain in the rear.. Plugs buried on top of the transmission. Got them done. I had to pull the front shaft from the front axle just to get enough room to reach the front sensor plug. The rear sensor I had to use a hammer to shock the sensor loose with all the mud down there. Fuel filter was another pain in the rear. The the filter was held in place by two bolts but with all the brakes lines from the ABS computer in the way. The plastic holder was bound up on the fuel so bad by the time we beat the old filter out it broke the plastic. Got it out and boy that filter was plugged up. Lots of black junk came when you blew on the filter backwards. Yuk. No codes now and runs much better.
  19. Well I'm back to wrenching. This rig was my room mate in the basement. Needed some knock sensors, oil change, fuel filter and oxygen sensors. Knock sensors aren't to bad to do. Basically pull the intake manifold. You need to both fuel rails off but the injector plugs are released on bottom towards the manifold, weird but ok. The knock sensors are under the two large rubber plugs with one wire to each. The front knock sensor came out easy and the rear the hex head kept collapsing. Using my angle drill I drilled 2 holes in the top of the sensor stuck my needle nose pipers in the holes using a long screwdriver barred that sensor right out. Then changing the oxygen sensors was some what a pain in the ***. Plugs buried on top of the transmission. Got them done. Fuel filter was another pain in the rear. The the filter was held in place by two bolts but with all the brakes lines from the ABS computer in the way. Got it out and boy that filter was plugged up. No codes now and runs much better.
  20. So. Pull the Quadzilla lose and test that red/white wire for short to ground. Then I would test the power leads for both ECM and PCM. Again you need to unplug the ECM and PCM to verify. While your doing all this look for mouse damage or rub damage to the power leads for all 3 devices.
  21. Quadzilla is way different being first off Quadzilla allows for custom timing for the engine. Power levels... 0 Stock 1 Valet Mode 2 Stock Fuel 3 CANBus Fuel Only 4 - 11 is amount of wiretap each level is 10%
  22. Just a couple days ago we had a 100°F day my fuel temp floats 120°F only the engine returns to OE basket, AirDog 165 GPH draw straw outside the basket. The AirDog returns to the filler neck. Fairly steady at 17 PSI. Trip was 40 miles round trip to New Meadows and back home. Also fuel temp and IAT typically match. Climb to New Meadows roughly 1,000 foot climb. Quadzilla set on CanBus only (Lvl 3) no wiretap. Weird on is at 66 MPH, 2000 RPM, 550°F EGTs, 2-3 PSI of boost, but dropping 24 degrees advance at the speed pushing 22 to 25 MPG.
  23. Time ran out on the mini track hoe. It went back to Tates Rental Saturday in Boise. I've got to say Thank You to James which is @Honey Badger oldest son that got me the whole week for a day rate. The other dig work we did was add a RV pad in the back yard. Now with water and power. Sewer I've got to cheat do above ground but not biggy. I have a solution. As for my network I'm building I got my first camera wired up and took a bit to configure Linux to see the camera. I had the camera inside looking out at the drive way. Also you can see I had the view on my phone but my PCcan record if motion is detected. Now if the rain would stop I would get both mounted and wired. I'm adding outdoor WiFi antenna which will go 700 foot radius. I'm loving the fact there is only one SSID (network name) and can wander between building without dropping calls. As for the Starlink still working good till last night's rain it was coming down 8.xx inches per hour very heavy with lots of lightning which we lost internet and phone for most of the night. As of this morning I've got signal again.
  24. Sorry level one is Valet mode. Valet mode locks to the setting on the setting page and doesn't provide any additional fuel. I'm not sure you get any timing while on level 1. You should be on Level 2 which is stock fuel with timing. Level 2 caps out the fuel table to just 100% so no additional fuel above 100% will be given.
  25. Yeah, Tomorrow I'm going to be getting back to web work and shop work again.
