1999 Dodge lift pump
Just keep in mind you want 14 PSI as a minimum fuel pressure at WOT. This will help with cooling and lubing the VP44. The bad side is never pull fuel from the sender basket being that is the hottest fuel return from the engine and can cause VP44 damage to the PSG module. Being my fuel system I use an old school draw straw in the tank my fuel temperature has are considerably lower than most others on the forum here.
Air in Fuel Line problems
Yeah my pump is old and dirty but I might have a slow weep somewhere but the pressures are fairly rock solid. Yes the old school push lock fittings and JIC fittings are supre easy and don't use any clamps or seals.
Surging, bucking, intermittent code 0236
Boost fooler and/or boost circuit is having issues. Double check by ohm testing the wires. Check for your 5V signal and signal ground.
MAP Sensor at the least. The rest can remain.
Here check this out... https://www.vulcanperformance.com/Metric-Adapters-s/188.htm
Trans problems
This is a problem in the 4th Gens. I've seen that the PRND selector valve will get wear from the deflection of pressure on the valve body and there is an updated RevMax valve body for the 4th Gens. As for the 47RE I would say you are on the right track. The information I learned from Dynamic from his time here you cal use compressed air to simulate the ATF and verify the valving is actually working correctly.
Pilothouse/RAM3500 build
Chrome makes it go faster right? I want to see this beast run soon...
First off try removing the Quadzilla and seeing if you can reproduce the problem. If the problem goes away then the boost fooler in the Quadzilla is to blame. Now if the P0236 code returns there might be a wiring issue or a bad MAP sensor. Typically the P0236 is a boost too high for too long. Typically this is a boost fooler issue where the boost fooler is misreporting boost values. Like back in my Edge Comp days if you unhooked the MAP sensor and then ran the truck it would report max boost all the time and would set off the P0236 code because boost values wouldn't fall at idle or coasting.
I typically use my Fluke DVM for measuring the Amp draw of devices but it is normal probe type DVM.
Then the Raptor series is known for the issues of the quick connectors that they use. The seal will not prevent air from being sucked in on the suction side of the pump. So a quick test is to disconnect the suction line using clean thick axle grease then coat the the nipple with grease on the pump and side the connector back on and it should seal for a temporary time. If it does you need to convert over to the old school JIC fittings and push lock fittings that are all steel fittings. This would stop this issue. The other rare one is the pick up tube in the sender has cracked and sucking air when the fuel level drops below the crack in the plastic tubing.
America Today
Yeah, some of these leaked videos sometimes don't last very long and are pulled down. But I get tons of these kinds of video feeds from TikTok that everyone is so afraid the government is stealing your information from TikTok. Not so... Even with my my knowledge of the internet and servers the only thing they can get from my account is my phone number which is used to log in to TikTok. The biggest reason I watch TikTok is the fact the US government has no control over TikTok since it is a China-owned company and cannot push the democratic agenda that occurred with Facebook, Twitter, Instagram, etc. Being the US government cannot squelch the voices here hence why I find all the US Senate and Congress meetings these are leaked out on TikTok till they possibly get reported. Just like the Supreme Court has ruled that the Biden Administration was caught violating the 1st Amendment and been told they can no longer squelch the free speech of US Americans in social media PERIOD! Then you see the governor of New Mexico that is trying to suspend the 1st and 2nd Amendments and they are starting to investigate into impeaching this governor (Michelle Lujan Grisham) and remove her from office for treason. Mainstream media is pumping out the Democratic agenda full throttle I see this from many people even here on the website. All I can say is you must think outside the box. Don't bother listening to mainstream media because its all lies and cover up to make the Democrats look like they are doing good things for the Americans. Sorry, this is all BS. Look at the price of oil going up price of diesel and gasoline is going up. The OPEC is telling the US they are cutting production in half. I found another video where Biden had stopped all the oil and natural gas leases in Alaska now. The US is not really producing any oil now and we are dependent on the Russians and OPEC for oil now. Let's talk about money. US Dollar is crashing in value. BRICS nations are now creating their own GOLD and SILVER-backed currency that will have a conversion of roughly 55 US dollars to 1 BRICS dollar. This will make the price of everything here soon to jump out of sight. Then the US is talking about creating a new fiat digital currency that will not be backed by gold or silver but continue to be backed by debt like currently but the bonus will be that the US Gov't will be able to track every transaction with the FedNow and CBDC (Central Bank Digital Currency). Then if you are like me and want to buy a bit of ammo I might find that my money is frozen or might have Feds show up and want to know why I'm buying ammo. Yes, this has already happened with some people. I can go on and on about information I've found on the internet.
America Today
Please watch https://www.tiktok.com/t/ZT8jjWmvX/ https://www.tiktok.com/t/ZT8jjEjEw/ https://www.tiktok.com/t/ZT8jjpBRh/ https://www.tiktok.com/t/ZT8jjvF3n/ https://www.tiktok.com/t/ZT8jjK4oj/ https://www.tiktok.com/t/ZT8jjbMrm/ This is the US Senate discussing The Green New Deal and how its tied to China and Russia. Then there is more... https://www.tiktok.com/t/ZT8jjxgLT/
AC from AC?
Only a small tweak it is 25 PSI for most Mopar Products.
Anything that gets hot is a resistive connection. This mean the load stays the same but voltage gets reduced but current flow will increase typically. I would replace that fuse holder and check again.
AC from AC?
No, it's not normal. When A/C is running it should lock and stay locked. Cycling will enhance clutch wear. According to Sanden Compressors it should run locked normal but no more than 5 unlocks in 60 seconds. The only time cycling is normal is DEF mode in the winter it will cycle because of ambient temperature has condensef the freon and pressures are lower.
AC from AC?
Clutch shouldn't cycle. This is a sign your low on freon. Yup any coil like relays or A/C clutch can produce a surge or spike. If it was me I would check pressures on your A/C.
Bent Rear Sway Bar
This is why I have a small length of chain welded to the frame of the truck and a snap hook for my breakaway brake cable attaches too. This way if the hitch breaks from the frame the brake cable can still pull the brake pin on the trailer. So many people attach the brake cable to the hitch pin or to the safety chains. What would happen if the hitch completely failed and the brake cable was attached to the hitch? Bye Bye trailer...
America Today
Just consider the price of oil roughly 85 a barrel now and going to 300 a barrel. Then OPEC is cutting production. Then the dollar is losing value. Can you say 15 to 20 a gallon for fuel.
Bent Rear Sway Bar
Interresting... Is this a bumper pull trailer right?
Which I50 Amp Circuit Breaker
What did you pay for that breaker? I might have to replace mine on Beast. Next time I'm down I'll have to snag one.
Bent Rear Sway Bar
I've never really seen a sway bar bent but... Now I can say I have... You know what stock has to offer. So I would consider asking around at the local 4x4 shops and see what options you might have locally. Ask what kinds of performance options there are for the different kinds of sway bars they have.
America Today
If the government can hear and see everything we do with our cellphones why can't the government deal with these issues and stop these criminals? Maybe because the government can't actually track people like they claim they can. Heck if they could track people why aren't the drug lords stopped? Why is the "Crime Family" still running our country? Remember that the legal system now is not what you think it is. Look in any courtroom if the flag has a yellow tassel on the flag then it's Maritime Law, not Constitutional Law. This is why that is happening. LAW OF THE LAND The general misconception is that any statute passed by legislators bearing the appearance of law constitutes the law of the land. The US Constitution is the supreme law of the land, and any statute, to be valid, must be in agreement. It is impossible for a law which violates the Constitution to be valid. This is succinctly stated as follows: "All laws which are repugnant to the Constitution are null and void." - Marbury vs. Madison, 5 US (2 Cranch) 137, 174,176, (1803) Yeah, this was made law back in 1803... Just think of all the gun laws that they created. Those are all in violation of the 2nd Amendment. How about the police can video record you but some freak out when you record them and the cop tells you can't record them? This is a 1st Amendment violation. I can go on and on. You might want to visit a Democrat state and talk to the Democrats living in those states who are clinging to the same crap. Trump hurt my feelings, Trump is a bad person, blah blah blah... Just look at how the Democrats have sent tons of money over to Ukraine billions at a time. Look at how Democrats are still creating more and more taxes fees and fines. The dollar is crashing out so badly that I don't think we are going to make it to the 2024 election time. I feel the Democrats will find a way to start a war before the election to hopefully prolong the election time. Biden has been proven to be a criminal but here our own government is not impeaching Biden and dragging their feet.
dash lights and gauges powering up with key off
Common problem. People that use the tilt wheel will break the wiring where it tilts in the column. You'll have to pull all the wiring out one by one and repair the wiring in the column. More you tilt the column more it breaks the wiring.
Parma ID & Jobs
You should have my number give me a shout and we can finalize this even more.
