Quadzilla showing zero boost
Funny... In all the years of my Quadzilla being on my truck I've NEVER unhooked for jump starting any vehicles. Never had any failures of the Quadzilla. Now as for the boost issue is there any error codes like P0237 or P0238? If yes then unhook the Quadzilla and clear the codes. Now does the code return? If it does return then the MAP sensor or wiring is the cause. If not the the boost fooler of the Quadzilla failed. Just for info... Currently my tune for +150 HP injectors and stock HX35W turbo I'm now running 0 to 1 PSI of boost at 55 MPH. At 65 MPH it barely floats 2 PSI to 3 PSI.
How to Test for AC noise After WT mod
On manual trucks the AC noise affects the cruise control like on my truck say I could set for 65 MPH and holding good for several miles then all of sudden it would surge up another +10 MPH from AC noise then decelerate below the set point -10 MPH and continue the cycle till the field lead was unhooked then the problem stopped.
Adrenaline install + trans. temp. sensor
I used a dedicated ISSPro EV2 for my transmission temperature gauge. My ISSPro EV2 is installed into my NV4500 transmission. Then used the trans temp probe of the Quadzilla to monitor engine oil temperature being it gives clues on timing adjustment. Optimal engine oil temp can be as low as 155*F to 170*F. If your above this or near coolant temp then your timing is off either too advanced or too retarded.
Same way you would before you did the W-T ground wire mod. So take your DVM and red probe you touch the BATT post on the alternator and then the black probe you touch to the passenger battery.
No tach signal and truck idling strange after pulling engine and replacing injectors
After doing a oil pan gasket I know exactly how to remove a oil pan the easy way. You need a cherry picker and let the axle hang fully extended. It will nearly fall out. Yeah I've had crank sensors break off at the o-ring. I've drove a drywall screw in and attempted to pull it out nope... Then I continued to break off bits and piece till it came out.
It's always something
Hmmm... I've never had any issues on pull the PSG cover. You need to have the exact bit for the cover bolts there are not a standard torx bit its actually a special bit. I normally get a 1/4" socket and put it on a 1/4" ratchet and just place the bit in the socket and twist like a palm ratchet and they come right loose. If im not mistaken the PSG cover bolts are a 5 spline bolt and a normal torx bolt is a 6 spline.
Batteries, Alternator, Winching, Check Gauges
There is a app called "Grammarly" it helps. I'm guilty too...
Just a bit of info on this... Typically on average the IAT will show approximately +40*F over outside air temperature. This is not a good measurement of ambient air temperature. Then the only thing the IAT does is control the grid heater for length of time it will run to heat for start up. As for after starting if the IAT falls below +80*F then the timing will shift to add about 3 to 4 degree advanced. Above 80*F then it uses the normal timing. Optimal IAT is 100*F to 140*F. Battery temperature sensor is for the primary use of charging the battery. It measures the case temperature to prevent boiling the battery with excessive charge voltage. Most don't know that the battery temperature sensor also controls the grid heaters post heating cycle. Just tidbits to add. Good post @W-T...
The green wire varies the ground to vary the charge rate. Since the vehicles has current draws the alternator will always charge some all the time match current loads.
Be aware that if the battery voltage shows 12.00 volts it will show normal on the volt gauge. After the voltage falls to 11.99 volts it will slam the needle down to 8 Volts and throw the light and chime. Once the voltage rises back above 11.99 volts to 12.00 volts it will turn off the check gauge light and then show normal voltage. The only reason I know this is my USB charge point shows actual battery voltage with the key on. I can see actual voltage numbers on my USB port. @Tractorman is correct your best off with a Digital Volt Meter. You will be able to check each battery for its charging voltage. I've found several trucks that show correct voltage on the gauge but like the passenger battery is low like 12.3 volts and the driver side battery is 14.8 volts. This shows the battery terminals and/or cables are bad.
Which Holset Turbo?
No change between the HX35W (54/60/12) vs the HX35/40 Hybrid (60/60/12). Spool is better on the HX35W and with proper tuning I'm running near zero boost at highway speeds. Watch my Tiktok...
Tried a set of LED headlights
Minnie (1999 Dodge Grand Caravan) I did a fresh set of headlight cases and installed a set of $70 Amazon LEDs. I went with mid-line bulbs. After replacing the headlight case where the lens were fogged over. Now the LEDs are very close to my HIDs but do have a hot spot vs HIDs are very clean light. Total was about $180. Took less than 30 minutes to change it all out.
Knowing your load capacity and how to load your RV
Thank you @IBMobile that video is spot on... This is why I weighed my 31 foot Jayco before rolling to Cally to go camping with you boys and girls. With my RV fully load and myself in the truck my truck weight is right at 8,800 pounds. Then my RV comes in at 8,020 pounds. This is a total of 16,820 pounds total. I'm registered for 26,000 pound on my plates but I still check to make sure the truck or trailer doesn't exceed its ratings too. 2500 Ram - 8,800 pounds GVWR scaled 8,800 pound 100% loaded no more! Jayco Eagle - 8,500 pounds GVWR scaled at 8.020 pounds 94% loaded tight but got wiggle room just a little.
Truck Not Running Right
No. I'm going to pack up again and make my second trip to the moon again.
There are some of us that let there Cummins sweat horsepower. After 458k miles they tend to get well rather greasy grimey and dirty from being driven to numerous other states. 476k miles I will be to the moon and back.
Good Source for Re-manufactured 47RE Automatic Transmission
@Tractorman could you clear out your PM box. I was going to PM you but its full.
Oxygen sensor issue with aftermarket cats
Just to explain a bit... The first 02 sensor is going to create a mild lean rich sine-wave of signal. This is normal it will go rich and then lean and back to rich and continues. Now the downstream O2 sensor is expecting a typical lean signal showing the catalysis is function by burning the excess hydrocarbons that are coming out of the engine. When the sine-wave is seen in the second O2 sensor then the P0420 code is typically thrown for a failing catalysis since its showing that same sine-wave downstream and the cat is functioning. @IBMobile posted is true I've seen a video of this showing the code issue and then using two spark plug anti-foolers it will help correct this issue.
What happened to the tunes?
Sorry for the down time on the tunes we had some internal issues here. I will be working at resolving this Monday morning.
Jon did the transmission in Lil Red which was my 1996 Dodge Ram 1500 46RE which he upgraded to a 47RE and make it shift strong.
Tappet Cover Opinions
As long as the cam cover is complete flat you don't need to replace the cover. The gasket is a slip on o-ring and you use ZERO sealants. Just reinstall and properly torque the bolts evenly. Nothing more. I've done at least a dozen cam covers in my time and never had a return leak yet. The key to this is cover is flat and not warped and that you instal the gasket the right way. NAPA has a small tab stating which way toward engine. I've never had the need to install a aftermarket cam cover yet.
No Tach
More like a bad cam sensor it's about a 15 minute job to change. I just changed mine last for the first time for lack of tach signal. Be aware if the tach is dead then the alternator is too.
Hydrogen Fuel Cell...
Then why is USFS burning hundreds of thousands of acres of forests that destroyed all the trees, a lumber industry, price of lumber is high. But every forest fire produces more CO2 in one hour than my truck will in its entire life time. 747 Boeing consumes 5 gallons of JET-A fuel for every mile in the air. Jets are polluting more than any diesel truck. Propane is just a good at promoting early ignition on a diesel hence why the propane has to have a regulator and then some sort of control valve to dust the intake with the right amount propane to what the throttle is able applied. Then this would be a optimal setup but I don't know of any propane kits that are this in a package.
Take in account every biofuel of any type has less energy than petroleum (gasoline or diesel). When they introduced ethanol to gasoline it reduced the BTU's of the fuel. Same as when Oregon mandated biodiesel to B15 IIRC (125,000 BTU's per gallon) it has less BTU's than straight diesel (135,000 BTU's per gallon). So I'm not a believer in any alternative energy fuels.
New Tool - Hot Rod
You can Thank @Honey Badger she was the one that suggested I do reviews of products and post them up as videos and/or articles.
New Tool - Hot Rod
Yup. Now I can handle all the rust locked fasteners on truck frames like anti-siezed buttered on the threads. Kwel magic wand eh?
