Carbon footprint
It's all bullshit for most part, nothing more than get more money out of regular people. There's so much to learn if you get time it's crazy, just use a good decrement before making final decision.
Brakes, power steering
I believe it's called bubble flare
Which Torque Convertor To Get
On the bright side all you need to do is change your oil filter every once in awhile.
Vibration under 40 mph.
Did you install the tires or did you buy the truck with tires installed, could have some counteract beads inside. If that's the case take something heavy and go around the tire smacking it to break the beads loose. Front drive shaft shouldn't spin unless you're in 4-wheel drive, at least mine doesn't. I guess that would depend if you have cad or not.
Before I knew much... I needed different size fittings on Ranger on opposite ends, the only way I could figure it out was to get different sizes lines, then I cut each one in half and slid one in to other few inches, it was a tight fit. Then I used solder worked for few years till we junked the truck.
preparing for plowing
Same here, but I only put in plow springs, I don't think they are any longer.
Tool I listed is double flare
Dreaded White smoke.
The ones I used are from 4liter Ford engine and need work to make them fit. If shop is saying they'll fix it then the right way of doing it would be removing head and machining valve guide to accept newer style VS-C59LV top hat seals. If they will not remove the head then your options are, use same seals they did firs time and some adhesive to hold them in place or modify Ford seals vs-292v which is time consuming, but so far is working on my truck.
For hard lines I got a mastercool 71475 flaring tool and some corrosion resistant lines in a roll in different sizes. If you get one make sure to shop around so it includes all the fittings.
Tuff one.... Pass side vanity mirror, loose, black goo
Yeah, been a while though. I think I just slid the glass as far as I could and squeezed somethingin there, maybe rtv can't remember and then slid mirror back, closed the visor till next day. So far been good, I actually forgot I did this till I read your post.
All I know is it got rid of my Honda that started in any temperature and got another diesel commuter, we better not have crap fuel this winter, or I'll just have to stay home.
47re Trans Service Tips and Tricks
Note to self, not that I'll ever need Auto transmission parts , but I'll steer everyone else that may mention them clear of that place.
Elec connectors getting them apart without breaking
I use dielectric grease on multi connectors and some antioxidation stuff on single connections. I think that antioxidation grease is conductive, so you don'twant to use it on multi plug because it can short out.
Cheap truck
Guessing guy is thinking it's almost a new truck for half the price of new, why not try. If it was manual he'd have more luck imo.
Cheap truck
I want 50k for mine, first come first serve
Select what you want to quote by highliting, then hit little quote button that appears under, sometimes it doesn't. Or you can use @ and user name right after without a space. @Nicarlov
Transfer case leak
Without it you wouldn't understand anything at all Slow conditioning
Transfer case leak
Got to love auto correct
Transfer case leak
Glad you got it figured out, got a look inside at same time. Chain looks good yet, stretched a bit but nothing bad. Looks straight forward on how to, seems that most here turning ranches can do this job no problem.
Transfer case leak
So it was leaking on that seam then where case split? And not where it meets transmission. Originally I thought it was leaking at tcase. But this makes sense now. Pictures worth a 1000 words.
NV 4500 Overdrive Noise
How much do you trust your shop that did rebuilt. They could of said new shaft and didn't. Other than that grinding clunking in gear when I had my Mustang with t5 meant that the main cluster great had teef missing. Not sure on nv4500
Sounds like you're having the famous 5th gear nut problem
Transfer case leak
- Hey you guys I got to get rid of a skunk.....
I think they mandated enough crap for us, not that I don't agree more people need a sense of humor. I think we can all be more happy if we live a simpler life and not chase what naighbors have.- One cup and one pot, to pee in that is!!
I get that way sometimes, then I just move on as I'm not that picky - Hey you guys I got to get rid of a skunk.....
