Everything posted by IBMobile
Motor restore
I've tried Restore in a 2001 Volvo S80 with a 6 cylinder engine. Check engine light on, compression test show a low cylinder, not a valve problem. Added 1 can of the 6 cylinder Restore. After a few hundred miles of driving the compression was up about 20 psi, not enough to take care of the problem. Customer donated car.
Gun safes
I've got a medium size safe with electronic key pad and it's bolted to the concrete floor, see steeling ATMs. It's full to the point where I have to move 5 to get to one but I'm done buying any more firearms so I'm not getting another safe. I like the electronic key pad. It is easy to change the combination if need be. I put a fresh 9 volt battery in it once every 2 years or it won't open.
A/c problems over pressurizing
If the A/C is working and the over pressure blow off valve opens only when the truck is stationary with the engine on then I think you have an air flow over the condenser problem like Mike said. You still want to put a set of gauges on and check the pressure. Install A/C gauges and record static high and low pressure along with air temp. Start engine and turn on A/C with fan speed on high, after 1 minute record pressures and center duct temp. Montour pressures and temp for up to10-15 minutes. If high side pressure goes up to 400+ psi and low side goes to 0 psi or into a vacuum in the first 1-2 minutes then there is a blockage in the system and it is most likely at the expansion tube/valve. If the high side pressure goes up slowly and gets close to 400 psi put a large fan, set on high speed, in front of the condenser. If the pressure come down to normal then there is a fan clutch/air flow over the condenser problem. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/54_cab-interior/basic-air-condition-repair-r485/
Heater Grid: disconnecting it, (benefits?)
Does too. It's going to down to 57 tonight.
Defueling at 1900 rpm fummins
You can also find good deals on tools at pawn shops. I got a Fluke meter for $75 at one.
Checking / replacing relays
No, pulling them with the batteries connected and the key in the off position will not hurt anything.
Front oil seal
There is an article for that, https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/12-and-24-valve-front-crank-seal-replacement-r474/ or do it dripley's way. https://mopar1973man.com/topic/12727-front-main-seal/
Alternator Question
How to change the diodes and brushes in a Denso
Denso Alternator Diodes and Brush Pack Replacement
Replacing Diodes and Brushes in a Denso Alternator Replacing Replacing Diodes and Brushes in a Denso Alternator Remove 1the 0mm nut at the B+ post, the three 8mm nuts and the 8mm head screw. You can use a small screwdriver and gently pry and lift the cove off. The diodes and brushes are now exposed. Remove the dust cover and four screws that hold in the brush pack assembly, lift assembly out. Remove the four Philip head screws that hold the diode/rectifier bridge in, lift diode/rectifier bridge out. Remove the one screw holding the brush pack to the brush pack assembly. Clean the slip rings with 400 grit wet/dry sandpaper. Assemble with new diode/rectifier bridge and brushes by reversing the disassembly steps. When installing the new brushes try holding them into the housing with a small pocket screwdriver or a feeler gauge while sliding over the slip rings. When installing the rear metal cover do not over tighter the 10mm nut for the B+ Insulator. It will crack and or brake if over tightened. Prepared by: J. Daniel Martin / Martin’s Mobile Maintenance AKA: IBMobile 11/18/2017 View full Cummins article
- 1 review
- 5
DIY: Converter Lock up with Brake Pedal Release
I finely found time to write the article about my version of the mystery switch. I hope someone with an automatic can benefit from it.
DIY: Converter Lock Up with Brake Pedal Release
Torque Converter Lockup Switch with Brake Pedal Release System What it will do This system can keep the torque converter locked in 3ed or 4th gear. With a modification to the valve body 2ed gear can be locked up. When driving normal freeway speed the torque converter can be locked up with the momentary switch and stays locked up. The transmission stays in direct drive even when the accelerator pedal is released, there is no freewheeling, RPM level is maintained and torque converter unlock is done with either pushing the momentary switch again or pressing the brake pedal. When going up long grades select 3ed gear, overdrive locked out, then lockup the torque converter with the momentary switch. I have found that by doing this I see very little rise in the transmission temperature with a decrease in exhaust temperature of 200o F. Unlocking the torque converter is done again by pressing the momentary switch or brake pedal. The trans mission will up shift from 3ed to 4th but will not down shift from 4th to 3ed with the torque converter locked. When go down a long or steep down grade the locked up torque converter will help in slowing but without the added benefit of an exhaust brake. Another switch* is incorporated in the system which will lock up the torque converter and stepping on the brake pedal will not disengage the lock up. How it works The system uses three switches, two relays and a light. The first is the momentary switch. This switch is used to signal the transistor in the switching relay to either power the coil and close the contacts allowing power to flow between pins 15 and 87 or stop the power to the coil and open the contacts. The brake light switch is three switches in one: brake lights, cruise control and anti-lock brake system. The anti-lock brake system grounds through this switch, white/pink wire, and is closed circuit until the brake pedal is depressed making it perfect for grounding terminal 85 of the switching relay. When the transistor loses its ground it turns off the power to the coil and the contacts between pins 15 and 87 open stopping current flow to the grounding relay. The 3ed switch* can either be floor mounted or dash mounted. This switch is used to energize the grounding relay and light. This keeps the torque converter locked when using the brakes. I use a floor mounted head light dimmer switch to turn it on and off. The switching relay is used to control the power to the grounding relay coil with the use of the momentary and brake light switch. This relay is used in 1981-1988 Volvo models 240 and 740 that had 5 speed manual transmissions with the overdrive 5th gear is a Laycock overdrive unit and provided power to the hydraulic solenoid. The grounding relay is used to open and close the circuit that grounds the torque convertor solenoid via the orange/black wire at PCM connector B11. Since this relay is used as only a grounding switch its power rating can be minimal. There is a light add to the system that is on anytime there is power supplied to the grounding relay and the torque converter is locked up. I used a green LED light so that the color isn’t annoying and power usage is low. Parts needed 1 overdrive relay for a Volvo manual 4 speed w/od (M46) IPD.com part# 102250 1 Bosch type/mini ISO relay terminal 87 normally open (NO) 1 12V LED light, Linrose Superbright LED Frys.com part# B2191L5 1 push button momentary switch, Phillmor Push Button green Frys.com part# 30-12634 E-Bay 1 headlight dimmer switch O’Rielly.com part # DS109 1 ½ watt 33ohm resistor NTE HW033 Frys.com part# 999026 1 fuse holder with 1-2 amp fuse 6 Scotch Lock connectors 2 #8 X 1½” self-taping sheet metal screws Solder Heat shrink tubing 1 central lock motor harness from a 1981-1993 Volvo model 240. The wire harness is found behind the center of dash. 1 overdrive relay harness from a 1982-1993 Volvo model 240 with either manual or automatic transmission. The wire harness is found above left front kick panel for manual trans or behind right center of dash for automatic trans. 1 shift lever from a 1998-2002 Dodge Ram 1500, 2500, 3500, Dakota or Durango. If you’re making the wire harness 11 solderless insulated female spade connectors .25” sized for wire gauge 3-4 solderless ring terminals sized for wire gauge and grounding screws. 18-20 AGW stranded (16 AGW will work if you can’t find smaller) in different colors. Try Home Depot or Lowes electrical department. Putting it all together Study the wiring diagram and have all of the parts in hand before starting the installation. Most of the wire length is from 6” to 2’. The wires for the light and the floor switch will be 4-5’ depending on where you put them. The wire from the grounding relay to the PCM will be about 8’. The power lead with fuse can be attached to any wire that is hot when the key is turned to the “on” position. The power draw should be between 1 and 2 amps; with the system having its own fuse, there should be no problems. Install the ½ watt 33 ohm resister between pin #87 of the grounding relay and ground by cutting the wire and soldering the resistor in place. I used the wire harnesses and relays from old Volvos that were in a wrecking yard. I modified the wire harness and added extra wire for the longer runs. An extra shift lever can be obtained at the wrecking yard for a few dollars also. Installing the momentary switch: refer to article written by Me78569 DIY- Lockup Switch install into Gear Selector Arm. This is a great how-to article on installing a momentary switch in the gear selector. If putting the switch in the gear selector arm is a bit difficult then try installing it on the steering column cove or some were on the dash board bezel that’s easily reached. You will need to remove the panel below the steering column, the dash bezel and the head light switch for the relay installation and wire routing. The left A post cover will need to be removed if the light is going to be installed there. Take your time and identify what wires are going where, think two or three times before cutting any wire. You should not have to cut any of the truck factory wires. The only wires that need to be cut are the ones you are adding. Find where you want to put the relays and LED light. I put my relays behind the bottom panel under the steering column and worked out from there. I have my LED light mounted next to my transmission temperature gauge. It’s at eye level and I just have to glance at it to see if the torque converter is locked or not. The light on JAG1’s truck was installed in the dashboard bezel between the headlights switch and instrument cluster. You will need to drill a hole through the plastic then slide the light housing into the hole and secure it with the supplied clip. Once the light is secured the wires can be connected and the bezel refitted. The 3ed switch* for energizing the grounding relay is mounted on the floor left and forward of the brake pedal in about the same spot the headlight dimmer switch was located back-in-the-day. I mounted this by putting the switch on top of the carpet and drilling through the floor pan with the self-taping sheet metal screws. A toggle or push button on/off switch could be used and installed on the dash bezel if the floor mounted switch is not to your liking. * Caution: coming to a full stop with the torque converter locked will stall the engine and could cause damage to the flex plate, input shaft or other driveline parts. Prepared by: J. Daniel Martin / Martin’s Mobile Maintenance AKA: IBMobile 11/12/2017
Looking for nice 2001-02 Wheel center Caps
JAG1, I heard Dripley will trade you the hubcaps for a bag of this.
Can it be quiet and powerful?
Nothing like a good double untender.
Headlights very very dim
Check the grounds for the lights. The resistance in the ground connection may be to high, .
Lockup switch curiosity
I'm working on an article with pics and wire diagram, . Hope to have it done in a week.
Dying ECM?
Pin 6 is the power (battery) ground for the vp44 so this reading is correct. This is a data ground. It grounds in the ECM. This type of ground will either show very high resistance or open circuit at the battery. Black wire should show continuity between injection pump pin #1 and ECM pin #23.
P1689 P0215 assistance
If you ohm tested the brown/white wire from pin #36 at ECM to fuel pump relay pin #86 in the PDC and it's good then you should get 12+ volts when ignition is on or cranking with the starter. Do you see any corrosion? Have any ohm tests shown abnormally high reading? This is the underside of the PDC. There is no circuit board.
installing a fuel boss
When I first installed the Fuel Boss a small piece of rubber became stuck in the by pass valve with similar results that you experience. My fuel pressure was16-17psi at idle and 18-19psi when cruising. Over time the idle pressure has slowly dropped when first started from 16psi to now a pressure of 12psi when cold. As soon as the RPMs come off idle the pressure jumps to 17-18psi. After 5 minutes of driving the idle pressure is 14-15psi. This pressure is measured pre-fuel filter. Adding shims won't help. Now your by pass valve is opening at 17-18 psi and adding shims will only increase the pressure it takes to open the by valve. The lower pressure will not be effected.
Madness...
The last week in October, It's 6:20 pm and the outside temp is 99°F. The high temp was 103°F.
I've installed a manual lockup system in my truck and JAG1's truck. It uses a momentary switch that is install in the shifter to activate a set of relays that ground the convertor lockup solenoid. The lockup can be turned off by either pushing the momentary switch again or stepping on the brake peddle. When going down a long or steep grade a locked-up torque converter helps in slowing although without the added benefit of an exhaust brake. A foot switch is incorporated in the system that locks up the convertor which will stay locked until the switch is pressed again so stepping on the brake peddle will not disengage the lockup. When the torque converter is locked up with either momentary or foot switch an LED light on the dash is lit so there is no doubt if the manual lockup override is on or off.
1. Pin # 85 of fuel pump relay is ground. Ohm test wire for continuity. If good go to next. If open circuit, repair wire. 2. Pin #30 of fuel pump relay is battery voltage (12+ volts) all the time. If good go to next. If no voltage check fuse # 3 (25amp) in PDC. 3. Pin #87 of fuel pump relay is switched power (12+ volts) from relay to pin #7 of the fuel injection pump. Ohm test the wire from fuel pump relay pin #87 in the PDC to socket #7 in the in fuel injection pump connector for continuity. If good go to next. If open circuit, repair wire. 4. Pin #86 of fuel pump relay is used to energize the relay solenoid with voltage (12+ volts) from pin #36 of the ECM. Check for voltage at pin # 86 position in PDC. When key is turned on, voltage (12+ volts). If no voltage, ohm test wire for continuity. If open circuit, repair wire, If circuit good, then there is no fuel pump relay signal (voltage) from ECM. 5. Bypass relay to test injection pump by using a jumper wire in fuel pump relay socket between pin #30 and pin #87. The engine should start if every thing else is good.
Nickel dimeing me
All this with less than 100k on the clock. A full set of gauges so I can see what may brake next, 4" s/s exhaust, five lift pumps, the last two being a $600 Fuel Boss with a $110 Airtex backup, rebuilt transmission @ 60k, replaced heater core, a VP44 replacement, two starter motors, diodes and brushes in alternator, need a new dash, and I won't count the tires, brakes, batteries and belts (normal wear). I'm keeping mine so I can spend my kids' inheritance.
What are these for?
That sensor, impact sensor 56006911, is used in 1994-1997 Dodge Rams and the wiring diagram for a 2001 ram 2500 does not show them. If that broken sensor was used by the SRS the airbag fault light would be on. Did you have those inner fenders replaced with used parts?
