IBMobile
Staff
Everything posted by IBMobile
  1. When I bought the Fuel Boss a roll of Parker series 7212 JIFFY PUSH-ON 3/8 hose came with it. It's good with bio-diesel up to B-20. It's been on the truck now for 4 years with no problems.
  2. So you are saying B-5 or greater takes the place of adding 2 cycle oil for injection pump lubrication?
  3. This is what comes in a Fuel Boss installation kit. The hose is 3/8 or up grade it to 1/2 and you can add a draw straw or use the stock pickup. For my needs I stayed with the 3/8 hose and stock pickup. If I was to opt for more power like bigger injectors and such then I'd install 1/2 line with a straw. http://www.glacierdieselpower.com/product.aspx?pf_id=FB-98502
  4. A new small pulley is installed to the front of the crankshaft pulley/ harmonic balancer and the pump attaches to the engine block via the front oil pan bolts. This is where the belt adjustment is also.
  5. Yes it can that's why you would want to do this. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/59_fuel/installing-protective-lift-pump-relay-r501/ 2 volts wont run anything. If you want 12 volts with key on tap the red/light green (rd/lg) wire at terminal 87 of the fuel pump relay in the PDC and use it as the triggering power at terminal 86 of a relay, you install, for just the lift pump. This will turn on the lift pump anytime the pv44 is energized.
  6. I installed mine just over 4 years ago (5/2013) . Fuel pressure was 17 at idle and 19 going down the road when first installed then went to near 0 a few days later. I found a bit of debris from the installation keeping the fuel pressure regulator stuck open. It's e-z to open the regulator and clean out or adjust fuel pressure if there is a need for it. I keep a spare belt under the back seat but there is also that spare fuel pump in the fuel system. All I need to do is in stall the fuse.
  7. Yes, it does. The fuel pressure regulator is in that line and they have it returning the fuel by way of a t-fitting in the filler neck hose. I run the fuel boss the same way. An electric fuel pump is installed but the fuse is pulled for power to terminal 30 of the relay. This keeps relay triggering power flowing from the ECM to relay terminal 86, the electric fuel pump doesn't run and no fault code p o230, or p0232 is set.
  8. See if any of this helps.
  9. Mopar1973Man 3,642 Site Owner Administrator 3,642 20,413 posts Web Site URL Facebook YouTube LinkedIn New Meadows, Idaho 5 Vehicles Posted June 18, 2016 · Report post I'll be there... Who knows I might boondock it down the road from there. I found a few good spots for boondocking large areas for folks. There is one lot just west of Catfish Junction and then another just down the road about a mile if need be. All the times I've been to Catfish Junction the place always had a open slot. Never crowded... Might be for thatr event though... On ‎6‎/‎18‎/‎2016 at 9:07 AM, JAG1 said: Now if we could just get Michael Nelson to stop scotch brightening his running gear for the weekends he could show up too! What? I don't do such things... Hide Mopar1973Man's signature Hide all signatures Other places to check out on Mopar1973Man.Com Articles * Donations * Downloads * Garage * Calendar * Leaderboard * Member Map * Store * Support How things have changed.
  10. JAG1 you would LineX the floor in your house if your wife let you.
  11. A vehicle's gross vehicle weight rating (GVWR) is determined by how much weight the suspension can tolerate be for a failure in a component, by it's braking ability in a given distance at a set speed and the ability of the tires to carry the weight with out overheating and blowing out . Overloaded and you may not stop in time and go right through a red light.
  12. How do the wires and connections in the power distribution center (PDC) look? Start with the main cable from the left side battery to it.
  13. Sounds like a plan and big savings on housing. How's the roof and what about sewer dumping? JAG1 is right about the seals for the slides. If you can cover them from the outside it will not only help eliminate cold air infiltration but prevent UV damage also.
  14. Probably lube about the same and cost about twice as much.
  15. I'm still finding things out about my truck. Thanks to Mike, AKA Mopar1973Man, and these forums we all get to learn about the trucks we drive and hopefully pass the info on to others.
  16. The park light is dim and the turn signal is much brighter or are both filaments powering up. If you turn on the park lights and the right turn signal at the same time you'll see the difference. The blub, a 3157NA, is a double filament type. The turn signal and park light filaments are rated at 400 and 38 lumens respectively. There can be a problem with one part of the socket and/or blub and not have it effect the other. .
  17. A good time by screwing around with your truck. If all the other lights are working it is probably a bad weir/connector between the switch and the blub socket or the socket it self. First I would ohm test the light blub. I.ve seen blubs look good but ohm test bad. Next I would check to see if there was voltage at the blub socket. If yes go and ohm test the ground for the blub socket. If no trace the wire back to the connector (junction block). Is there voltage at the connector (junction block) pins C1 C5. If yes repair wire from connector to socket. if no check for voltage at pin 11 in the turn single/hazard switch. Ohm testing blub socket ground. if continuity (0Ω) then see above. If no continuity ( open circuit) then check for broken wire or poor contact at body ground.
  18. While getting my 5er ready for the up coming trip to Catfish Junction I found the AC shroud cracked just about beyond repair and in need of replacement. It has already been partially fiberglassed once and to repair it would coast me as much in matting and resin as it would to replace it. The AC is a Dometic Duo-Therm Brisk Air ,new style, 13500btu. I have found three suppliers of this shroud: 1 Camping World, 2 Icon Direct (thru Amazon), and 3 Dometic ( thru Amazon). My question is: 1 has anyone replaced the shroud on their AC unit, 2 who did you buy it from, and 3 what was the quality of the replacement shroud?
  19. JAG1 no need to wright it down. You can find it in this article.
  20. Their not the same. 99 OEM #56027221AB (DENSO) 136 amp 99 OEM #562839 (BOSCH) 136 amp 01-02 OEM #56027221AD (ALL 5.9L Cummins diesel)
  21. Had my 3ed Carter lift pump go out when pulling my 5er. I watched the fuel pressure gauge go between 0 and 5 psi, mostly at 0, for 300 miles. That was in the fall of 2012. 4 1/2 years later no problems with the VP. If you have another pump put it on, check fuel pressure and go. If the (new) factory pump you have is a Carter the fuel pressure at idle will be around 14-15 psi and wot is about 10 psi.
  22. This is true. The visible smoke test is done with the naked eye no other form of measurement is used. It is subjective to the inspector's eyesight, time of day, and if he's hung over or not. The test allows for a "puff" of smoke during start up and no visible smoke during the rest of the test. This month I had to modify a computer controlled Idle system because the smog tec said the engine was idling to fast at the factory setting 850rpm and should be at 750rpm. That 750rpm is only used for timing adjustment but the tec said 'nope, that's the speed CARB wants'.
  23. I've been thinking about putting the RV275s in my truck. The owner of the SMOG test and repair shop I've been going to has retired so no more brakes on my inspections. I'm concerned there might be smoke when the throttle snap test is done during smog inspection. I don't know about the quad xzt but the Edge EZ is not California Air Resource Board (CARB) approved. I now have to remove it before inspection. If the vehicle is registered in the hinterland of California inspection is only when title is changed but in the metropolitan areas inspection is also every two years.
  24. Find a store like Parker that make can make up hydraulic hoses with fittings. https://www.parker.com/portal/site/PARKER/menuitem.98bf0856fd643a238c23b35b8320d1ca/?vgnextoid=894fb34395d2b210VgnVCM10000032a71dacRCRD&from=parkerstore&citype=ParkerStore&vgnextfmt=default
  25. Most parts in old trucks are made from unobtainium .
