IBMobile
Staff
Everything posted by IBMobile
  1. That sensor, impact sensor 56006911, is used in 1994-1997 Dodge Rams and the wiring diagram for a 2001 ram 2500 does not show them. If that broken sensor was used by the SRS the airbag fault light would be on. Did you have those inner fenders replaced with used parts?
  2. One air bag , two air bags, or more, it doesn't matter. Theses are the crash sensor that send a signal to the SRS (supplemental restraint system) controller that a significant impact has occurred and the air bag(s) are to be inflated. If the Impact zones covered by these sensors are: the left front, the front, and the right front.
  3. Left front and right front air bag (SRS) crash sensors.
  4. I have a set of Gates hoses under the back seat for spares, they're from Rock Auto. Geno's also sell these. Rock Auto also have the Dayco brand .
  5. Ahh.... To be young and nimble again. And people do this for fun??
  6. I have test strips and can send you a couple. PM me with the address.
  7. You might want to crank it some and get the oil moved around before starting it. Sitting for a year I'm sure most of the oil is in the pan. If you're going to change the oil wait till after you start it. You my also want to check the condition of the engine coolant, not just the strength of the antifreeze but also its Ph.
  8. I left the stock fule return line alone and used the metal fuel feed line that goes from the teak to the location of the factory mounted lift pump as the return line for the Fuel Boss. I used a small tube cutter and cut off the ends of the line. The bypass valve / pressure regulator was attached at the end previously used for the lift pump and the other to the T fitting installed in the filler neck. I put a cheap lift pump, Airtex, in the mix. I have electric fuel pump run by a relay but the fuse is pulled so the ECM closes the relay but the fuel pump doesn't come on. When my VP44 went out on me I pulled the relay and jumpered the contacts for pin #30 and #87. This turned on the pump and primed the new VP with out cranking the engine. Mike saw how I did it.
  9. Is this the secret picture of you as a child dresses for "What I want to be when I grow up" day at school?
  10. Well it about time Goodyear made a decent trailer tire but the tire has been on the market for only 8 months so it's a little premature if they hold up in the long run. . I've been using the MAXXIS M8008 ST radial tire since 2004. The first set came with the trailer and lasted 9 years before dry rot took them out. I replaced them with another set of the same. The trailer just went on a 5,200+ mile tow with no tire problems. Amazon is selling the 225/70R-15 Goodyear Endurance for $145.87 per tire x 4 = $583.48. https://www.amazon.com/Goodyear-724857519-ST225-75R15-117N/dp/B076B4XM71/ref=sr_1_1?s=automotive&ie=UTF8&qid=1508198647&sr=1-1&keywords=goodyear+endurance+225%2F75r15 Amazon is selling the 225/70R-15 MAXXIS M8008 ST for....$115.97 per tire x 4 = $463.88 https://www.amazon.com/Maxxis-M8008-Radial-Trailer-Tire/dp/B004QL6I0U/ref=sr_1_2?s=automotive&ie=UTF8&qid=1508198814&sr=1-2&keywords=maxxis+trailer+tires This is a savings of $119.60. With a savings like that you can get 5 MAXXIS tires, a new spare also, for the price of 4 Endurance. Just my
  11. Pins #3 and #9 are not used by the injection pump that is why there are no female terminals for those pins in the connector. If you pull back the rubber covering to the connector you'll find no wires for those pin positions.
  12. All you replaced was the front brake rotors and pads. You also replaced the left front wheel bearings, inner and outer. You didn't have that clunk before you did this job? So it must be some thing you removed and reinstalled. Wheel bearings make a grinding noise as they destroy themselves if in stalled wrong. Brake calipers and mounting brackets are bolted on and tightened to a specific torque. As long as the bolt holes are not hogged out there should be no movement. That levees the brake pads. I've had, on more that one occasion, brake pads that were a few thousands of an inch to small and would shift back an forth in the caliper making the noises you have described when changing direction.
  13. Nice looking rims with out the door good price. I'll get a 2x4, measure it twice and still make tooth pics out of it. Some days it just better to stay in bed.
  14. Check out these vented locking/non-locking fuel caps. https://www.oreillyauto.com/detail/stant-5674/fuel---emissions-16775/gas-cap-12847/diesel-lock-fuel-cap/10508d/5699303/2000/dodge/ram-2500?q=vented+fuel++cap or this one https://www.oreillyauto.com/detail/stant-5674/fuel---emissions-16775/gas-cap-12847/diesel-only-fuel-cap/10838d/5699408/2000/dodge/ram-2500?q=vented+fuel++cap or this one http://www.autozone.com/fuel-delivery/fuel-cap/duralast-fuel-cap/848454_0_3071
  15. Experts warned Congress this week that an EMP attack by North Korea with a nuclear electromagnetic pulse bomb has the potential to kill 90% of the U S population in one year. The loss of the electric and communication grids along with the shutdown of transportation, water and sewer would cause wide spread famine and disease across the country. This would set the U S back to post colonial life with Lewis and Clark. Climate change doesn't look so bad now, does it?
  16. With man made climate change*, it's never to early for snow. Don't forget to do your part to reduce your carbon footprint. 1. Car pool with a stranger. 2. Heat your home with warm thoughts. 3. Don't eat beef, Eat more chicken. Cattle consumes large amounts of feed and produce a large volume of methane gas, a known greenhouse gas, were as chickens eat dirt and are gasless. 4. Buy your man made carbon credits to pay the State mandated man made carbon tax. *previously known as global warming I let that last guy drive my truck. All I got back was a couple of washers.
  17. Top is the brake line, middle return to tank, bottom is fuel supply. With the Fuel Boss pump I use the fuel supply line as a return line T into the filler neck.
  18. Good to hear from you again. Glad all is well. After the last go around of storms and flooding you raised your house up off the ground. How's that working out for you?
  19. Driply spotted in his Sunday ride going to get a burger.
  20. 3M auto super strength molding tape, 3M part #03609, 1 roll 1/2 in x 5 ft. You will find it at Amazon half the price of Oriellys.
  21. Be sure that the orange/black wire at pin #C2-11 on the PCM is not shorting to ground or the torque convertor clutch solenoid is hanging up. .
  22. Looks like it was a Mickey Mouse brake job.
  23. Take your time, have it checked out by someone that is well knowledgeable about that year and model truck. Just because a guy has tools and is breathing doesn't make him a mechanic much less qualified to inspect a diesel truck . If you fined a truck and want to have it checked out don't fall for "Well I've got someone else coming over to look at it and he seemed pretty interested in buying it". If the seller is being honest then he won't care who looks it over. When towing a trailer over 2000lb a trailer brake controller is a must and make sure the trailer brakes are in good condition. You'll need to pull the drums for that and might as well repack the bearings while your in there. I had my trailer plug disconnect from the truck one time which disabled the trailer's electric brakes, I felt like Freddy Flintstone trying to stop all that weight.
  24. Here's JAG1 getting ready to split some firewood. Here he is done
