Lost brakes while driving
Yes you need to change all the unit bearing in the front with new sensors and the problem will be solved. Note of warning you could replace the sensors alone but if the tone rings are damaged in the hubs it will not fix the problem. What it is that the sensor is reading on wheel at ZERO speed and you touch the pedal the ABS will back pump the pedal and prevent braking because it thinks one wheel is already locked up tight and trying to get the speed back. Been there done this... Just remember I've got 3 sets of sensors and never fixed it till I replace both front unit bearings then the lights went out and problem solved.
2 stroke info.
Me its about the monthly budget. Currently about $600 to $650 a month in fuel to keep Mom going to dialysis. Then you break it down and figure the cost per mile 0.16 to 0.19 cents per mile. Then when looking at fuel prices... 10 gallon price - I use this measure more so than price per gallon. I never buy just 1 gallon. Typically 12 to 14 gallons. John Day - 30.39 Molalla - 30.09 34.09 Ontario for me... Ontario - 34.59 Payette ID - 32.99 New Meadows 34.59 Riggins - 33.59 Cost per mile is a measure also that shows rate of usage vs cost. MPG is only a small window of info.
Buying a Quad soon
I'm located the same way in my cab too. The only difference I called Quadzilla and talked them and got the go ahead to extend the cable into the cab which was cut and soldered and shrink tube. (Beta test request) Works but this way but still issues with connection and retrying to connect for miles before it actually does connect.
'99 radiator drain 1/4 turn only?
The stock is 1/4 turn then pull out and the another 1/4 turn to open. My new radiator is just a threaded plug in the radiator.
Morimoto HIDs Headlights in a 2nd Generation Dodge
LED for sure is NO. It will not melt any snow or ice. HID is maybe depends on how fast the snow is falling and how cold. Up here with -20*F and heavy snow will bury the lens over. Typically no issues. I've only had my HID cover over twice now that's it. The LED's for sure are covered every single trip. In bad storm I'll stop from time to time to just clear the LED's but the HID typically will barely burn a hole through on warmer days (20 to 32*F).
Crappy Mileage No Matter What Tune
Funny thing I just scaled my truck. Front was 4,400 pounds, the rear was 2,900 pounds, for a total of 7,300 pounds currently. Here is current fuel logs with winterized fuel and outside temps between 0*F and 25*F most days. Remember I went down in tire size to increase the rear ratio. Going from 265's to 245's change the final ratio to 3.69:1 which is super quick and extremely low in engine load at 22-25% at 80 MPH. My 65 MPH is rough 15-17% engine load.
Dead pedal with no codes
Dead pedal - is when the throttle does nothing period but idle. Limited Pedal - is when the throttle works but limits to a particular road speed or RPM. Now if there is a APPS issues with dead pedal it will ALWAYS set a code. Now a dead pedal without a code is typically the VP44 PSG failing. This is because the ECM commands a value that is out of range and the PSG is protecting from a wide open throttle or below idle fueling which would stall the engine. Limited pedal is typically the ECM being the fueling map is damaged.
Crazy life - Just blogging
Made it through Christmas. It was quite the family gathering here. Eileen and I made a big ham dinner. We had my Mom come down to the guest house for dinner. Then Eileen's son family came to spend Christmas with us. I started Christmas morning with rebuilding a front driveshaft so I was ready for today's haul back south to Ontario. I will quickly say SKF u-joint have upgraded design with better seals and should hold up better. The very front u-joint was salt contaminated. So the red grease was turning white from salt and then with bit of rust inside as well on the metals. Everyone made it here about 4pm and the dinner began. Jacob and family stayed the night in my RV. They will be heading out this morning after me just about day break. I'm going to be out in the dark at 7:15am like usual. Eileen will be starting her new job this morning too. M E R R Y C H R I S T M A S T O E V E R Y O N E
Aftermarket Turbo Boot Kits
Myself I'm running a HX35/40 Hybrid (60/60/12) with 150HP Injectors (7 x 0.010) @ 320 bar and Quadzilla Tuner. No problem to hit 47 to 50 PSI of boost. I've never move a boot or clamp ever. I'm running Vulcan Performance boots.
Radiator failure
Last batch I bought was Prestone and SuperTech Universal and both were the same yellow coolant but that was some years ago. I'm back to NAPA green on this load of coolant and creek water.
Stuck thermostat?
Do yourself the favor and just change the thermostat. Please don't go the Cummins / Mopar route being Cummins and Mopar do not manufacture thermostats and currently Cummins and Mopar is using a Robertshaw 320 high flow thermostat which is produced by Mr. Gasket. Very poor quality thermostat that will separate and drop the bypass shutter in the block because of the junk design. Suggestion: NAPA thermostats have been working awesome for years here.
How bad is this blow by
Be better to re-do all the vacuum lines with air brake line and fresh vacuum hose rubber. I'm sure there is way better routing that could be done. It doesn't have to be routed through the middle of everything. No it does not have to run along the cowl either.
DIY BD Stealth cover
Mopar1973Man replied to backcountrymountains's topic in 2nd Generation Dodge Reliability / PerformanceThe original stealth cover was designed as a plastic cover with holes drilled. Then the tap hole was threaded in the plastic. Common to strip out. Then it was updated to a hex hole on the back that is snug enough to hold the nut with plastic tension. Then the screw threads into the nut now. I've got both versions of covers the old is in my toolbox and the current upgraded on the pump now.
Merry Christmas
- 2 stroke info.
Beyond me... Rare to see biodiesel here in Idaho. Then the price of biodiesel here if you do find its roughly 15 to 30 cents a gallon more per gallon over a gallon of petroleum diesel. Every time I get to Ontario, OR which is biodiesel required state and it just as high as the highest price diesel in Idaho. New Meadows is 3.399 a gallon and Ontario is 3.459. Then if I stop in Payette, ID I get super low price of 3.299 a gallon. When I tested biodiesel from Ontario I took a loss in MPG's always did better with petroleum diesel.- Morimoto HIDs Headlights in a 2nd Generation Dodge
I told you the money is worth it by a long stretch. Wait till you out on a lone road and tall trees and you'll see a way different pattern. Like I love the fact of the light pattern is super wide. It much wider than the highway then vertically it can light up just about 50 foot tall tree to the top. Make sure to set your step on the yellow center line. Then just enough vertical height to cover the pavement but not up on reflectors along the road or signs. Already have nearly 100k miles on my light no issues. Shutter, relays, bulbs, or ballast. All working as designed. You won't be able to install stock halogens again because the guts of the HID's have to have the lens pulled off and then remove the HID's then you could install the stock halogens again... Not possible on the road. Every morning the HID's are on for 2.5 hours and then every evening 2.5 hours they are one for the trip home. Power usage is much lower vs. halogen. 35w is quite a reduction vs. 60w halogen burning. Chances of failure is low. Next step would be convert the rest of the truck to LED tail lights and marker lights. Huge power usage reduction as well.- Morimoto HIDs Headlights in a 2nd Generation Dodge
Total cost of what is in the front of my truck is $1,000 worth of street legal lighting. My Morimoto D2S air aimed properly the cut off line is way low no way to blind anyone. My PIAA LED Driving lights are 100% street legal and proper cut off not like LED light bars which are not street laws in all cases. Play headlight war with me though and I will promise to light the inside of your cab like the sun just went super nova. Once in a great while I might the little low rider or such wink at me and then get the cab lit up. What? Really you need a shop for that? I've got the u-joints and the center ball for the cardan joint. Ran out of time yesterday but I'm going to repeat my last rebuild. Starting to vibrate in 4WD.- Radiator failure
Wal-Mart must of changed since my last use.- Radiator failure
Walmart is universal yellow or Prestone they are both the same and can be used in our trucks.- Morimoto HIDs Headlights in a 2nd Generation Dodge
Try 4,000 lumens in PIAA LED driving lights. That's even brighter. With winter solstice behind us... I can say I love the idea of flooding the highway with over 50 feet wide of light and 50 plus feet vertically on hi beams. The 4,000 out of the PIAAs flood the lane with light and you can see a mouse run for cover. I find tons of vehicles driving super slow because the stock headlight suck and barely light up the road. I can flood them with light even on low beams without blinding anyone...- Crazy life - Just blogging
Nope. This is a old school double knob and the neck is plastic and its leaking from the neck. I've changed the o-ring even still leaking.- Crazy life - Just blogging
Yup... The only problem is there is no money down here. He's looking for super cheap fix.- Crazy life - Just blogging
Well the one I'm dealing with is junk. Long lag to get into gear and only has 1st and 2nd. Won't shift to 3rd or 4th. The owner wrecked his other vehicle and came to get his. I told him it was beyond me and nothing can be adjusted. Should consider a rebuild at a trans shop.- Crazy life - Just blogging
Thursday trip home sucked big time. All you people with Toyota Prius's park those little stupid cars cars. All you with you wanna-be AWD cars driving 25 MPH in 65 MPH zone you are an IDIOT! Seriously!!! I'd seen 4 of them AWD off the road, then watch one bounce off a concrete guard rail 3 times. I got to the Weiser river bridge project waited for the light. There was 5 cars ahead of me and one behind. When I left the light every one crawled out at 25 MPH in 55 MPH zone. Highway was lightly snow covered. I pulled over took a leak let everyone go. Fired up my MP3 stereo and started rocking out. Took off. In just a mere 7 miles I caught the entire pile of 6 cars. Then once I past the Tamarack mill I opened up and passed all 6 cars dragging tail at mere 35 MPH and resume cruising at 60 MPH. Still only light snow on the pavement (less than 1 inch). If you holding up traffic PULL OVER not everyone wants to drag along for hours at 25 MPH some of wanna go home today! Another day... It's my Friday. Ontario trip today. Yesterday I've been working on my 6.7L CuMy relationship with Eileen @Wet Vette has been growing. We work as a excellent team when we can get together. She loves the place up here in the mountains and so does here family. Like her son came out and spent 4 days with his girl friend and son. They wanna come back for Christmas time. So, I talked it over with Eileen and she wants to learn about the website and help out.mmins with a code hole in the delete tune. I'm having issues getting the flash to go. With the weekend here I could not call for support the vendor was closed. As for my life I've done some talking to @Wet Vette and she is up to learning about the web site and helping out. She seen all the cables come in and me box up a set for DAP. My first box was 30 units so I sent 15 to DAP and kept 15 here for the web site store. Now I'm just waiting on @Me78569 to send some switch to me. Then we will be in business again. I've made the call to Timbo's APPS to get a restock again. Still waiting on a phone call back to get that going. My relationship with Eileen @Wet Vette has been growing. We work as a excellent team when we can get together. She loves the place up here in the mountains and so does here family. Like her son came out and spent 4 days with his girl friend and son. They wanna come back for Christmas time. So, I talked it over with Eileen and she wants to learn about the website and help out with the store and boxing up stuff for the mail. I'm trying to get a balance between the driving job and the wrench job. Wrench job are far and few in between right now. I've a got a few nickle and dime jobs. Then I've got the web stuff I'm trying to get to market being the website has invested thousands of dollars in to parts now we need to sell said parts to make the money back. Like right now I'm trying to keep the home functional. Fought with a leaking kitchen faucet. Darn plastic faucet leaking down back under the sink. The bathroom faucet is plugged up with something and barely any water will come out. Priced out faucets for the kitchen it like OMG Home depot in Ontario is like 100 to 300 dollars for a kitchen faucet that has some quality and metal. Below 100 they turn to plastic junk like I've got now. Like today I'm packing my laptop with me and going to work on the vector art for possible hydro-flask for sale on the site. I lost my can which is a killer 64 ounce can. I talked with the gent I got mine from he'll will to work a deal with me. Hopefully it turns out a good deal. Then a friend in New Meadows calls last night. He's a Ford man. He got his hands on a Ford truck body with no engine or transmission. He's ask for me to find him a 6BT Cummins that is p-pumped. So I'll have a retro fit to do soon. Then one of my past jobs was a transmission job on a Durango. I made a call to Jon @Dynamic and found out those transmissions are junk in design. Known for issues with solenoids and clutch issues. Nothing adjustable like the 46RE, 47RE, and 48RE. Basically this gent is going to need a transmission shop to just rebuild the transmission. Oh, The dumb thing... I got home and parked my truyck in the garage and forget about the packed snow the next morning there is water every where.- Cummins CAN bus messages
Normal. Mine in cold weather initially can be way up in timing but as it idles for a bit it drops rather fast. The VP44 can go as far as 32* BTDC for timing. - 2 stroke info.
