Dieselfuture
  1. That sucks, definitely looks low on grease. What brand of joint is that, guessing front axle shaft? Looks like it's been busted before maybe on install, how it already has rust on some surface. Try not to beat them in place and use a press, or irina can crack, same goes for bearings.
  2. Would you say with my 62/67/12 I should go with 7x10 also, or little bigger. My 75hp are OK but canbus is maxed out by 30psi or even sooner. With wire tap I'll hit 42 43 psi sometimes for some reason it will get to 45. I know my Turbo is not meant for anything over 40 psi but just for reference. Reason I like 7x10 option is just in case something happens to the quad I'll still be able to drive without too much smoke. Idk just one othem moments where I think I can benefit from bigger injectors with this turbo.@Mopar1973Man @Me78569
  3. Now that's how you take a picture, make it look like you're hauling a house
  4. Had a question on studs. If you reuse studs do you still need to retorque them, or are you not supposed to be using studs. Or is the retorque more for the head gasket and not for stretching a stud. Reason I'm asking is on my truck I have A1H11 studs from PO, I reused them and the read online that they don't require retorque. I wasn't sure what to torque them down to so I went to 135. One thing I did do is after everything was torqued down to specs to final torque, I went through the sequence and loosened up each one relubed it and retorque right back down to final 135. I've done this before on other vehicles and never had a problem but just want to get your expertise opinion.
  5. I'm with you on that, I guess I just never sat down and thought about it that hard. I got a single 62/67/12 and I like it, but with everyone lately going to compounds thinking about it myself now, just need to figure out what I'll tell wife without starting a war. I believe you could still use an exhaust brake he'll just have to be an inline one, but I am not 100% sure if it effects the way compounds work, I just thought was part of the reason I got a turbo I have so I can still use my bolt on exhaust brake. @jlbayes will be your best advisor on compounds and injectors.
  6. Nice, I think that boat is bigger than it looks in this picture. Do you know how much the thing weighs with trailer. What lake is that
  7. I have a quad with V2 tuning and I'm able to watch it live, not sure if you were able to do so Edit, this will be able to tell you also https://www.google.com/search?q=obdlink+mx&oq=obdli&aqs=chrome.1.69i57j0l3.8612j0j4&client=ms-android-verizon&sourceid=chrome-mobile&ie=UTF-8 And you're not pushing that much boost anyway you ever have a bad sensor on a short somewhere
  8. Is your map sensor junk
  9. If it wasn't for cell phones all cars would look like that
  10. @SGTmurph there is a reason it's called lieometer, need to verify by hand calculating. My litometer always tells me about 6-7 miles higher than it actually is. I got my quad dialed-in about perfect now at 155 for offset, when I fill up and hand calculate, it's pretty much dead on. I've been averaging 17-19 now that the winter is gone.
  11. This is from rockauto https://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1440064,heat+&+air+conditioning,a/c+compressor,6628 Not sure what's good
  12. This is what I'm using About 4 mouths ago I was using bottom one. Now everything should work with 98-02
  13. I got a bushing from auto zone I believe, it was poly. They had original and poly
  14. Two sensors bad is unlikely but possible, I would be checking wiring.
  15. Yes that is definitely the key, all of the things I've done prior to this job are now paying off. I'm the only one that is trying to keep things clean including bathroom, tools after i get done using them, job site bla bla bla. I had a lot of experience in fixing things like cars, trucks, small engines, furnaces, washers, dryers, I mean everything. I was never scared to tear something apart. I can go on for a while on things I've done just like a lot of us here, but the key is not to be lazy, and also have a balance between hard work and eating some sort of lunch and a bit of rest. I skipped a lot of that and over worked myself, that's why my body has been falling apart. So now I'm a bit smarter about it. Ahh I'm getting side tracked again, point I'm trying to make is because I wasn't scared of hard work I got moved up and then was asked to take a superintendent position that required school, as much as I didn't want to go back I did and it's paying off now. Wife thinks I should go get an engineering degree but man when am I going to start leaving a life, it's never enough for some. It's not how much you make its how you spend it, to a point. You know you can go broke buying deals right...
  16. Do you guys mind installing some security cameras on your property and in your house and also get them things that you talk to (lexa or something like that) and then post a link so we can all access it and see what kind of beer you drinking and what political views you may have along with what you're going to buy next. Don't take this the wrong way but technology is very dangerous. I'm sure most of you heard of a book called 1984, if not I suggest you to look it up. Here I Go Again
  17. Who comes up with this shi.
  18. Found my problem, for some reason my signature view was not turned on. Got her checked now.
  19. That's why they have continuing education classes, but what I meant with my comment is, don't just go to school to go to school to get a degree. Let your employer pay for it when you get a decent job if you like it. Not arguing just what happened to me.
  20. Some how I don't see his signature, . Maybe it's my phone, but man you really think.....I.... in fact I don't see anyone's sig . I probably did something in settings.
