dripley
Retired Staff
Everything posted by dripley
  1. Some have some have not. I have not. Installed my 3rd one 20k or so ago, including the OE one. Still happy with what i have.
  2. Bushing at the axle. Ball stud at the frame.
  3. I disconnected mine at the battery.
  4. I think the VP got a bad name early on. My oe only lasted 75k. The remain Dodge put on it lasted 150k. And now 220k on this one. I am not knocking what you want to do. If the VE is what you want, go for it.
  5. Got stuck in 4th gear. I had to hulk out of 4th and it would not go back in. Never made a sound or gave any warning. Don't know what happened.
  6. No. The one I have now came from the salvage with 52k on it. The truck had about 250k on it at install. That's really about 220k on it.
  7. This pulsation seems more rapid than the rotors a turning. Kind of odd for warped rotors.
  8. Cant answer that for sure, but it would seem to me they should be the same.
  9. Possibly pushed the axle to the passenger side due to the springs sagging. A longer track bar would do the same.
  10. How many miles on said transmission? Could just be normal wear and tear. My 6 speed with 200k has some movement.
  11. Get the code reader and see what the codes are.
  12. The PCM is telling you the ECM has a problem. My opinion anyway. The 606 is an ECM failure code. Go to the articles section, 2nd gen, engine, obdII error codes and look at the 606.
  13. The ECM and the PCM are two totally different family members. They are NOT the same thing.
  14. I cant argue with what @Dieselfuture says on adjust ability. I have about 20k on my second MOOG non adjustable track bar. The cost was about $100 from Rock Auto. the first one had about 160k on it. Hopefully this one will get the same. Dont know yet. My springs, as best I can tell, have not sagged. At least if they have they have done it equally.
  15. Riddle me this one. My brake and ABS light are both on and have been for a while. Never felt any pulsations prior to the lights being on but now have those pulsations under hard braking but I know the ABS is not working because I can lock all four wheels up. ???
  16. Very much what happened to mine when the ECM committed suicide. I did not have the 606 code but it acted the same. From the 216 code you might have lost the vp too. Hard to say with the ECM flailing around. You cant trust the codes to much.
  17. There are other things that can do the same to you. Not just the VP. Hard to carry a spare anything. The stock filter is supposed to be very good, but I for one opted for more with the AD as many others have. Kind of a personal preference. You do NOT have fly by wire like my 02. Yours is vacuum controlled. Here in NC we have no emissions on the 2nd gens, but a lit CEL will fail inspections. I am at the present working in Bowie MD and will be for the next 2 or 3 months. Maybe a get together is in order.
  18. I ran my stock clutch with a Banks Ottomind tuner, 75 rwhp advertised power. I pulled a 14k pound 5th wheel with out any problems. May be I was one of the lucky ones. I do not what clutch was rated for.
  19. The VP does not like high pressure when starting. The ECM regulates the starting pressure by turning the lift pump on and off rapidly. Pressures north of 20 psi while running are not recommended as that is hard on the VP. Fuel temp does play into this since the fuel is cooling the computer on the VP.
  20. Like to hear a little more info from them on that. I have been feeding mine between 15 and 19 psi with normal cruising pressure at 17 psi for 7 years for about 190k miles with a total of 220k on the VP I have now.
  21. I currently have 220k on my pump. I fed it a steady diet of 2 cycle it's whole lifer and good fuel pressure also. She might blow tomorrow, who knows. It has lasted longer than the 2 that proceeded it together.
  22. Screens clogged in the module?
  23. I am in the basket with absolutely no regrets.
  24. The needle valve should not pull the pressure down any.
  25. I can only add this. cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/list-of-verified-and-reliable-pc The link did not work but the article is in the articles section under 2nd gen, electrical.
