dripley
Retired Staff
Everything posted by dripley
  1. While getting the seal moist again might help, I would be keeping an eye on it. If it doesn't stop soon, I would be replacing it.
  2. I went back twice before leaving for good. It was nice to know the door was always open. It never took long for me to get back out because as Tom said once you taste it you always want it. Sounds like you have a good enough job to get back out. good luck. Beautiful sunset by the way.
  3. DAP uses bosch products also. I have seen the picture where they look very shiny, not sure that is how they come. Give them a call and put your mind at ease. I have purchased from both and they are very reputable and will give you a good product.
  4. you even spelled Cackolacky. I am proud to know ya.
  5. Back in my younger days the first to shots went down pretty hard, it's the 3rd and beyond that it really taste good. Got way to easy to drink after that.
  6. Too many years of practice.
  7. Still have the oe fan bearing but the but the idler bearing went at just over 300k.
  8. As far as Junior's goes, it is the recipe his granddaddy and daddy used for decades. It is just made legally instead of in the woods. Should be the same product without the mystique.
  9. I would do it but only in the summertime. Dont think I want to try a build one during a winter like yall just had. I dont own a wardrobe for that kind of weather. I did a job in Wilkes Barre Pa about 20 years ago. 124" of snow and several doses of sub zero weather. That was enough for my lifetime.
  10. "Turn the key off". Thats a funny one right there. True, but funny.
  11. Here are the ones listed in your state, but I dont know if you are near any of them.http://www.chick-fil-a.com/Locations/Browse/MN
  12. You could get a mechanical test gauge and double check your pressure and see if they both are fluctuating. My first FP gauge was a Glowshift and it worked fine for a while then start going crazy, but not just at idle. Do you have a needle valve or snubber or something protecting the sender from the VP pulses? The pulses will destroy the sender.
  13. The food is good, they are good people to work with and they have been putting groceries on my table for 16 years. I guess I am a little prejudiced. But if they are packed, I am going somewhere else.
  14. The throw out bearing would be making noise with the clutch in and not out.
  15. I was thinking more like wood stake rails on the 12+ year old truck. At lest my truck is an 02, but the rv is 05 and I am still paying for it. Bad financial decision on my part.
  16. You are like me with nothing but a 'woodie' to drive.
  17. I used to be a big advocate of corn ethanol. Anything that got us off the Arab *** had to be a good thing. It did not take long to see that using a food source for fuel was bad thing. Anyone who thinks this has done any good for fuel prices does not pay any attention to what they are spending at the grocery store. All of the other things yall have mentioned above just make it that much more of very fruitless endeavor to say the least.
  18. If they are not leaking you should be good. When I installed mine I torqued the injectors first and then the nut on the cross over tubes. They all leaked. I went back loosened all the injectors, tightened the lines to the tubes and then torqued the injectors. No more leaks. If I ever change them again I will tighten the cross over tubes first and then torque the injectors.
  19. Welcome. I believe AES is the rebuilder I dealt with. Bad experience for me.
  20. Welcome, Drew.
  21. Glad to hear you found the problem.
  22. I am running one from NAPA that only cost like $25 IIRC, I bought like 4 years ago. Rock auto has them for $30 to $125.
  23. I like my truck running right also. I have re calibrated mine many times after disconnecting the batteries, but occasionally have forgotten to. I have never noticed anything different when I forgot to, thats why I asked. I have had erratic shifting but I think I have to blame my self for that.
  24. Got er figured out yet DW???
  25. Thanks, I tried to do it myself and it told me the pic was to big. I figured a good ole double dog dare would make it happen. Laughter is truly the best medicine. I am enjoying it.
