Tractorman
  1. Congratulation are in order for your perseverance! - John
  2. I had to look up the meaning of "quiet quitting" as I had never heard the term before. I thought it was the event that happens when I start the engine in my truck. - John
  3. I am assuming the truck was running fine before you started the turbo and PacBrake project. If that is the case, you probably inadvertently did something along the way to trigger this new problem. Is it possible that there is something blocking the intake or exhaust ports? Like a rag or anything that may have been used to protect the intake and exhaust while everything was apart. Just throwing out ideas. - John
  4. Good information from you. It is not a dead pedal or limp mode symptom. It sounds like a direct engine miss, as if the signal to the fuel solenoid valve (inside the VP44) is being interrupted. I recommend that you recheck the work you performed when you did the W-T wiring modification - especially the ground circuit for the ECM and the VP44. You could also swap out the fuel pump relay in the PDC (power distribution panel) with another relay in the PDC. The fuel pump relay supplies power to the the fuel solenoid in the VP44. - John
  5. Just want to clarify a "dead pedal" occurrence. This is a a condition in which the engine falls to and stays at idle speed for 30 seconds or so and then corrects itself on its own. The transition is smooth and no engine miss is involved. This condition can occur with a faulty APPS, but not limited to a faulty APPS. Another condition that can occur is a reduced power mode (sometimes call "limp mode"). This condition will last approximately 30 seconds or so and then correct itself. The transition will also be smooth and no engine miss will be involved. This does not sound like a "dead pedal" condition nor a "limp mode" condition. Have you done the W-T ground wiring modification recommended on this site? A bit more history on your truck will be helpful - total mileage, mods, how many owners, other related problems / repairs, etc. - John
  6. As Hank would say, "That engine runs on propane and propane accessories." - John
  7. Overnight low of 43° here in Baker City. Also, the coldest night for over two months. - John
  8. Under what conditions is your axle wrap occurring? and which gear? Details matter. What clutch did you install when you swapped to the G-56? Why not go back to the OEM rear spring setup? There are plenty of OEM 2WD pickup trucks with 6 speed manual transmissions out there that don't have any drive-ability problems. - John
  9. @Nekkedbob, I apologize for my part in hijacking your thread. - John
  10. @JAG1, I appreciate your response. I strongly agree with most of what you are saying. But, I am not challenging any of those things. In fact, I have done some of the things that you mention - mounting my lift pump on the frame rail, modifying the suction line inside the fuel tank, adding a serviceable coarse suction strainer just upstream of the the lift pump, and rerouting the return fuel flow to the fuel tank filler tube. What I am challenging is the long-lived belief that somehow the lift pump pressure determines how much return fuel (cooling for the VP44) comes from the VP44 via the 14 psi overflow valve. Over the years I have read many posts from the leader / leaders of this site who have referenced that if lift pump pressure is less than 14 psi, then there is no return fuel flowing over the 14 psi overflow valve, thus no cooling for the VP44 injection pump. I have also read many posts that say the VP44 will be damaged if the if lift pump pressure is less than 14 psi. It is my opinion that this is simply not true. I have never seen any documentation to support these beliefs. I have performed fuel return flow tests that dispute this concept. Others have also performed this same test using flowmeters and driving their trucks for real-time documentation. Some of the tests were performed and results were posted over 15 years ago. In fact, one of the testing events involved a vendor that was going to market improved lift pump systems, but dropped the idea when the fuel return flow test results were documented. One of my goals for posting this information is to help the readers decide what fuel system is best for their truck and to help the readers diagnose any fuel related problems. Years ago I attended a truck driving school. The school was taught by veteran truck drivers, each with over 30 years of safe driving experience. Toward the end of the training I was talking with one of the instructors. I was thanking him for the knowledge he shared. One thing that stuck in my mind was something that he said. It was something to the effect of, "You can learn a lot from a veteran truck driver - including any bad habits or misconceptions of the trade. So, don't be afraid to challenge what you hear" That has always stuck with me. I am hoping that my challenge will be addressed. - John
  11. In my opinion, there is a lot of incorrect information being posted here. I am assuming you are referring to the 14 psi overflow valve in the VP44, The moment the engine starts and idles, there is approximately 19 gph of fuel instantly flowing through the 14 psi overflow valve and returning to the fuel tank. This flow is provided by the VP44 internal fixed displacement vane pump - NOT the lift pump. If the lift pump pressure is 5 psi or 20 psi, the 19 gph return flow will remain the same while the engine idles. If there was no lift pump and the internal vane pump was drawing directly from the fuel tank, there will still be 19 gph fuel return flow from the VP44. The internal vane pump pressure regulator is set to around 135 psi - certainly more than enough pressure and flow to ensure that the high pressure pump chambers fill and that fuel flows through the 14 psi overflow valve. At 2000 rpm there will be about 28 gph of fuel returning to the fuel tank via the overflow valve. That is certainly much more than the 2.5 gph injector consumption. It is also likely that if the lift pump pressure is around 15 psi, then the lift pump flow will be much less than rated 150 gph. The lift pump manufacturers do not provide flow vs pressure performance charts. The most information that I could ever find was from FASS - which stated that the rated flow was at 0 psi. So, I would not be surprised if that 150 gph rated lift pump is only flowing half of that rating at 15 psi. If this were the case, 75 gph minus 2.5 gph minus 28 gph equals 44.5 gph returning from the lift pump to its own inlet, or returning to tank by separate line. Not true if you are referring to 10 psi lift pump pressure. At 10 psi (or 5 psi, or 20 psi), 19 gph of fuel will be passing through the 14 psi overflow valve and returning to tank with the engine at idle. The only time the 14 psi overflow valve is closed is when the engine is shut off. I made these charts below to illustrate the combined series and parallel fuel circuits involved in the VP44 fuel system. The 19 gallons / hour of fuel returning to the fuel tank from the VP44 is based on return flow tests that I and others have performed. The test is at engine idle. The circuit on the left uses a 60 gph / 6 psi lift pump that returns fuel to its own suction. The circuit on the right uses a 100 gph / 17 psi lift pump that uses a separate line to return fuel to the tank. Compare the different flow rates in some parts of the two circuits. Note that the return flow rate from the VP44 does not change in either circuit. - John
  12. @Caleb Hardy, I like what you wrote. I think the words "effective ratio" are a better choice of words to present a case of how different tire diameters affect engine performance. Earlier today I was writing about this subject, but I wasn't ready to post. I am now posting below what my thoughts are. I changed the words "final drive ratio" to "effective ratio" as a result of reading your post. Thank you. I think the intent is to say, for example, "When a smaller diameter tire is installed on a truck with a 3.55:1 rear axle ratio, then the "effective ratio" at the ground would make the truck behave like it was closer to a 3.73:1 rear axle ratio." I think that in order to make a fair comparison, the only time "effective ratios" should be compared between different vehicles is when the vehicles that are being compared are using a transmission gear that provides a direct 1:1 gear ratio. There is only one gear in each of the three available transmissions for 2nd generation trucks that meets this requirement and that gear is a different gear in each transmission. Direct 1:1 ratio gear are: * 5th gear (NV5600) * 4lth gear (NV4500) * 3rd gear (47RE) Over drive gears ore: * 6th gear (NV5600) 0.73:1 * 5th gear (NV4500) 0.75:1 * 4th gear (47RE) 0.69:1 - John
  13. For your truck, tire size, transmission, and 3.55 gears - sounds like you are right where you should be to me. - John
  14. I apologize for any confusion with my instructions. Please disregard my initial instructions. As I recall now, I used the method for installing injectors from the service manual for a common rail fuel system. I have more confidence that this method will provide a more reliable leak-free connection at the intersection of the connector tube and the injector opening. The injector hold down torque is the same for both fuel systems. It's just how you get there is different. The connector tube nut torque is 28 ft/lb on the VP44 fuel system, versus 37 ft/lb on the common rail fuel system. While I am writing this, I see that @Doubletroublehas posted. His explanation works well, too. From the 2004 FSM (installing injectors): (a) Install fuel injector holdown clamp (mount- ing flange) bolts. Do a preliminary tightening of these bolts to 5 N·m (44 in. lbs.) torque. This preliminary tightening insures the fuel injector is seated and centered. (b) After tightening, relieve bolt torque, but leave both bolts threaded in place. (c) Install high-pressure connector and retaining nut. Do a preliminary tightening to 15 N·m (11 ft. lbs.) torque. (d) Alternately tighten injector holdown bolts to 10 N·m (89 in. lbs.) torque. (e) Do a final tightening of the high-pressure connector and retaining nut. Tighten to 50 N·m (37 ft. lbs.) torque (28 ft/lb for VP44 injectors). - John
  15. It has been awhile since that repair, but if I recall correctly, the nut that is torqued for the fuel line connection is also the same nut that pushes the crossover tube (connector tube) into the injector inlet port, so, yes, it is necessary to torque all of the fuel lines. If there is a leak at a fuel line connection, it is usually because there is a small piece of foreign material or a scratch / burr on the mating surfaces. This is a fairly common problem, but usually loosening the fitting and slightly moving the tubing as the fitting is retightened usually will stop the leak. If a leak occurs, it is likely to be just a weep. Sometimes, the weep will disappear on its own. - John
  16. This link should get you to the procedure for injector R&R. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/59_fuel/fuel-injector-install-removal-r5/?do=getLastComment&d=4&id=5 My OEM injectors came out easily - even with 303,000 miles logged on them. The washers stayed on the injector. I think I used a flat blade screwdriver to break them loose and then they basically came out by hand. It is very easy to bar the engine over using the alternator pulley. I believe a 15/16" socket works well. Be careful to not bend any fuel lines. Loosen or remove fuel line brackets beforehand. Remove crossovers tubes before lifting out an injector. The crossover tubes use a steel to steel compression contact that fits into a machined slot in the side of the injector. If the crossover tubes are not pulled back or removed, the injector will not come out. When installing the new injector and new / used crossover tube, the tightening sequence is very important. Be sure to understand the method, otherwise you are likely to have a high pressure fuel leak. Basically, install the injector with the fuel entry port aligning to the crossover tube entry. Slide the crossover tube into its bore and ensure the tip engages into the injector fuel entry port. Tighten the injector bolts to a low torque value, then install and tighten the associated crossover tube to its torque value. This will force the injector to rotate and center the compression connection at the injector fuel entry port. Then perform the final torque on the injector. Just take your time, so you don't miss any steps. - John
  17. Here is another link. This one is W-T's version. I like his - he uses bigger words. - John
  18. I think this will link you to the Mopar1973Man's version of the W-T wiring modification. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/w-t-ground-wire-mod-simplified-r574/?do=getLastComment&d=4&id=574 The alternator output wire is in a loom that crosses in front of the engine eventually arriving at its connection at the power distribution center. It is a large gauge wire connected to a 140 amp fuse at the entry of the PDC. Remove this wire from the fuse and connect the wire to the positive terminal on the passenger side battery. I recommended installing a 150 amp fuse in-line near the passenger side battery. This fuse will prevent a fire should the the alternator ever have a serious short ciruit to ground. I left my alternator output lead long until I establish a permanent mount for the in-line fuse. - John
  19. @Zach B, just FYI, note the ND emblem in the center of your first photo. That stands for Nippondenso. - John
  20. That sounds more like it since you are located near sea level. The vanes in those pumps are lubed with a dedicated engine oil line. This is why those vacuum pumps are so efficient and why they rarely fail. Good to hear you have it fixed and the solution was simple. - John
  21. @leety, I checked the on-line Banks vacuum operated exhaust brake owner's manual for 98.5-02 trucks. Unfortunately, there is no information for testing the vacuum source in the troubleshooting section. However, there is information for the 04.5-07 trucks where a vacuum pump is provided by Banks. Here is part of what is stated, "Connect this hose to a vacuum gauge while keeping the other end connected to the Vacuum Pump. Make sure the truck is in park and start the engine. Measure the vacuum at 1900 RPM. The Pump should generate a minimum of 10 psi (20.4”Hg) of vacuum." I think your vacuum pump is fine. - John
  22. It is too bad Banks didn't say what the minimum required vacuum is for the exhaust brake actuator cylinder. That would have been most informative. I think it would be a lot closer to around 15"HG. A faulty vacuum pump could be be a possibility for your problem, but I am inclined to think the problem is elsewhere - such as a vacuum leak or a faulty actuator seal (even though it supposedly tested okay). For example, the actuator seal may perform fine when cold and then start leaking when ambient temperature rises around the actuator. Or, vice versa. Also, the FSM really is not that clear as to what vacuum pressure should be at engine idle. The FSM states, "With the engine running, vacuum output should be a minimum of 25 inches, depending on engine speed." It is that clause, "depending on engine speed" that leaves me wondering what the real value should be at idle. If it is believed that at least 25"HG is required to make the exhaust brake fully operational, then vacuum operated exhaust brakes would not work in high altitude locations. Example: Leadville Colorado at just under 10,000 ft elevation - current barometric reading is 30.53"HG. Station pressure (the absolute pressure) is currently just under 21.00"HG. According to Banks the exhaust brake would not perform properly. I disagree - I believe it would perform fine. I have personally driven my truck over many 11,000 ft mountain passes and my vacuum operated exhaust brake (although a PacBrake) operated just fine. The vacuum pumps on our trucks may need a seal replacement or a coupler replacement, but the vacuum pump portion of the pump is pretty bullet proof. I have been using a vacuum operated PacBrake actuator cylinder for well over 400,000 miles on my truck (70,0000 while installed on a '99 truck and 367,000 on my current truck). I have gone through two actuator cylinders in which the seals were slowly destroyed by heat from the exhaust system. The early symptoms were always intermittent and / or sluggish operation. When I tested the cylinder using a vacuum hand pump, they would sometimes pass the test and sometimes not. Also, I recommend to not use worm-drive hose clamps on the rubber lines. They tend to distort and cut the lines they intended to seal, sometimes creating leaks. I recommend properly sized spring tension clamps - they handle vibration and thermal expansion / contraction very well. So, after saying all of this, I would make absolutely sure there are no vacuum leaks on your truck and I would get a second opinion on the performance of the vacuum operated cylinder. - John
  23. In late October of 2015, my wife and I were finishing an East Coast Fall Colors Trip with our travel trailer in tow. We traveled though some southern states on the return portion of the trip. While we were passing through Arizona, I told my wife that I would like to stop at ATP in Irvine, CA to check out the engine thermal blanket kit available for our slightly noisy Cummins 2nd generation 24 valve engine. We arrived at ATP about mid-morning and I met the owner Tim Thompson and, as @Hutch24vstated - he is a great guy. He gave us a tour of his shop and introduced some of his employees. The shop is hard to describe. Basically, it is filled with employees operating commercial sewing machines (like long arm quilting machines, except heavier duty). He said he got the thermal blanket part of the business going because of the need for it in the car racing circuit. Now he does custom fitting on engine exhaust systems on the Coast Guard fleet of boats and ships. He also insulates engine compartments on high end motor homes - such as ones that celebrities drive to his shop and visit with him while his crew install the material. He said that Ernest Borgnine would stop in with a new motorhome every couple of years to have the engine compartment insulated and while he waited, he would visit with the crew for a couple of hours and telling jokes. The crew loved him. Anyway, Tim offered to make and install the whole kit (except for under hood) for $1,000 while we waited. We agreed. When the job was complete, we test drove the truck. We were only able to attain about 30 mph in the neighborhood. We left the windows down while we drove around, it was definitely quieter. I was trying to not be overly optimistic about the sound difference, after all, Tim told me the product is primarily used to minimize heat transfer. When we returned to ATP, TIm asked how we liked it. I told him that we didn't have the opportunity to do try it on the freeway, but it is a bit quieter in town. Here's the part that impressed me. He said it will be noticeably quieter on the freeway, but if I have doubts or I am not satisfied with the product, he would happily have his crew remove it and refund the money. He said he was serious about that statement and that there would be no hard feelings. My wife said, "NO! We are keeping it!" And that was that. On our trip back to Oregon, it was definitely quieter in the cab and as a bonus, my wife said the floor stays cool now when going up those long hills. One of the benefits so far has been the durability of the product. It is not supposed to degrade, deform, or lose its effectiveness for up to well over 2,000° F. So far, it has done its job well. - John
  24. That thermal blanket looks familiar. Did you get it from Advanced Thermal Products? They installed a 5-pieces set on my engine. Helps with engine noise abatement, but really keeps the engine bay and passenger side floor much cooler. The blankets have been installed for almost 7 years and over 120,000 miles now. There is no sign of degradation of the material or the components the material covers. The initial cost was high, but for me, it has been well worth the expense. - John
  25. Just be sure no one is watching..., you know, sniffing your rear end. - John
