  1. That Edge Comp isn't going to be set up for 150 HP injectors very well. I tend to agree there is something wrong with the Edge Comp box. I've got to ask was this the proper Edge Comp for this engine? You didn't modify the MAP sensor leads to make it work? Then being your missing the PCM there is no way to read error codes. I would disconnect the Edge Comp and run without it and see if the problem goes away.
  2. If your injecting the fuel too late and the ignition is occurring after TDC then the power is completely wasted and fuel most likely isn't being burned completely. Might see a gray haze. Then what is your CANBus fuel curve like? Then what is your wiretap settings like? Yes. I know exactly how to create massive smoke that just proves that your way over fuelled and wasting the power. Black smoke could prove that your timing is off depending on when the black smoke is seen. Black smoke is not good period! Just means your flooding out the engine and lacking boost pressure.
  3. Exactly... Majority of us are just daily drivers here. None of that will amount to anything being you don't run WOT all the time. Like myself, my average engine load is 17 to 19% and about 2-3 PSI of boost at 65 MPH. Flow is super low so there is nothing to gain by porting the head. Now if your 1/4 mile racing, dyno queen or tractor pulls then your going to see some gains by porting and such where you run WOT nearly 100% of the time. Just upgrading 3-inch exhaust to 4-inch exhaust on my Cummins gained me ZERO. No change in MPG, no change in EGT's, no change in power. Just like intakes don't gain anything for daily drivers because the flow is too low. Now as for injectors (7 x 0.010 @ 320 bar), turbo (HX35/40 hybrid 60/60/12), and Quadzilla now that had produced serious power gain. EGT very controlled. MPG at 20.64 at the last tank. Can tear the tires loose on command. Awesome sprint truck. Drop the hammer its passing 85 MPH in the length of a semi-truck from 45 MPH. There is more to it being I've got a correct final gear ratio to the ground at 3.69:1 where most are on oversized tires and below 3.55 heading towards 3.00:1 which add massive amounts of load on the engine and heat.
  4. Just go to... https://mopar1973man.com/register Fill in the blanks and go from there.
  5. The sender is dead on the money at 17.5 gallons displayed on the Quad at 1/2 tank. I've been below 1/8 tank few times and Quad gallon display has right there within +/- 0.05 gallons typically.
  6. Another way to look at it. Here is the stock 30-inch tires sizes and dimensions. Here is the stock 31-inch tire sizes and dimensions. Then the popular 285...
  7. RV275 injectors. You need to look at the timing setting you over advanced. That is the only reason it popping and backfiring. I would start out with 15, 18, 21, 24 with a Max of 25. Then on the Low PSI Timing Reduct set it for 5 and then 50% scaling. Be a good start. You need a good amount of retard on sudden WOT operation. That is why the backfire or bucking. Like my truck even with 7 x 0.010 injectors, I can reach over 28* without backfiring or bucking. Retarding timing will build boost rapidly by dumping more expanding gases out the exhaust manifold to the turbo. Once the turbo lights off then the Quadzilla can advance the timing and pour the fuel too it.
  8. Ah... I was hoping there was an update. Thanks, I'll give that a try tomorrow. I assume its this update then... Opps, that's a 2.8.4... @Quadzilla Power you need to upload the 2.8.5 here on M73M.com...
  9. As for the flooding it pretty well over. Things are drying up for now. As for the MPG game. 20.64 MPG on the last tank. I was hoping for much more being I past 300 miles at the 5/8 mark on the fuel gauge.
  10. Somedays I wish I never sold my 1973 Dodge Charger...
  11. The way I look at Smarty S-03. No matter how much you can adjust the Smarty S-03 you still have to play by the rules of the ECM. It is like having an Edge Comp or Edge Juice (no wiretap) that is stuck on Level 1 but sublevels you can adjust. Remember CANBus fueling is from 0 to 4095. That is it. There is no magic bullet than the Smarty S-03 can do to expand past that fuel limit. Timing wise yeah you can adjust it but no one really knows what the map looks like. Is it optimal for larger injectors, not really? The only thing a Smarty S-03 does is get to the 4095 faster than stock. Torque Management allows for fuel early heading to 4095.
  12. Stock sizes... 265/75 R16 245/75 R16 (door sticker) 235/85 R16 One ton 215/85 R16 One ton
  13. 35 inch tires and 3.55 gears is a bad combo. Always high in EGTs. I'm down to 550 at 65 MPH now but 30 inch tires and 3.55 gears.
  14. Give up. You'll never finish that list. I'm still fixing crap and adding back to the list.
  15. I'm curious if there is a update of firmware for the Quadzilla. I've lost count of what version I've got and what is the current version. I've got fueling issue in the 1000 to 1200 RPM range. For some reason Quadzilla oscillates up and down regardless of timing. You can watch engine load jumping up and down.
  16. I should con you into writing an article on this for others. I'm sure others would jump on it.
  17. He got away for cheap. I was right at $2,000 with the ARP studs, machine shop (valve guides and seals), then gaskets and so forth.
  18. Wow. Talk about a time long forgotten. Back when pedal cars are made of steel. Woman (or girls) wore dresses. I wish I could turn back the clock some times.
  19. Makes me want to pull my cover again and check my bolts. Might explain the weep oil leak behind the case.
  20. Got them installed. I used every single blub. All 20 got used. I'm doing a full run test. I've got all the light on while I'm here at the RV and test to see any get hot. Here you go...
  21. Size is only half of it. Weight is the other part. 285's typically are close to 90 to 100 pounds a tire with the wheel. The rotational mass has a minus in there too. This why ricers beat us hands down. Small tires and little rotational mass.
  22. Me I opted for the tip to keep the soot off the truck. 5 inch tip is what a friend gave me.
  23. My current tune looks to be able to reach nearly 22 MPG then still on the 245's. If I can do it twice ill release the tune for download. Find out more when I fill with fuel today.
  24. Quadzilla runs off of Circumference measurement rather than rev/mile or tire height. If you want to just pass the stock speed signal without math enter 95.7 that is the pass through number.
  25. White smoke... Timing retarded excessive blowby worn piston rings pop pressure too low on the injectors valve lash incorrect Basically white smoke is unburnt fuel that didn't ignite. Being that compression creates the heat to vaporize the fuel to make it go bang. Now that makes you think of all the things that might affect compression or fuel atomization. Finer the automation of the fuel the easier it is to ignite.
