Everything posted by IBMobile
Need to ground my tool box.
Where are you getting the power from? What does the connection in the box look like? Are you planning on rolling the box around when working or leave it in one place? One easy way to get power is buy an extension cord, cut of the female end and use that to wire into the tool box. With this you can plug into an outlet and still be able to move the box around if needed. 10'- 16 gauge at Harbor Fright $5.99.
seat belt question
Try pulling the belt out fully and spraying the last 1-2' of the belt with silicone. Let the belt retract and pull it out a few times then let the spray dry before using.
190k brakes?
How @Mopar1973Man really makes his brakes last.
AirDog Toggle Switch hardware
- killer dowel pin question
There are KDP repair kits to be had just search "cummins kdp repair kit". There are also a few how to videos on YouTube with the same search "cummins kdp repair kit". Most of the videos are for the 12 valve engine with a few for the 24 valve.- Wait to start delay
- W-T ground mod
This fuse is for alternator protection only with the stock alternator out put at <140 amps. When the engine starts the grid heaters alternate being on and off. The two are not on together and there is about a 3 sec. delay between switching grid heaters so only about a 90 amp added load. When the grid heaters come on with engine running only and no other electrical load the voltage will drop to about 14.1 volts and 1269 watts. Example: grid heater #1 on for 5 seconds then turns off, all heaters off for 3 seconds, grid heater #2 on for 5 seconds then turns off, all grid heaters off for 3 seconds, Repeat.- Machine shop
Clam it as a commercial grade chicken tenderizer.- W-T ground mod
I do a lot of camping south of there at 7200' with the morning temps at 25°-32°F. The engine starts with the heaters disconnected but with a lot of white smoke (unburned fuel) and rough idle. This is why I made the grid heater bypass switch so I can use them when I need them with no 'check engine' light.- Idaho teen travels to Seattle and makes 35K in four days plowing
Remember, the populous of Seattle believe in 'Global Warming' and will pay any thing to get rid of the white stuff.- W-T ground mod
Yes, it can be in stalled to protect the alternator in that cable. Some people are using a 150 amp circuit breaker and others are opting for a fuse block with a 150 amp AMI/MIDI or ANL/AMG type fuse. circuit breaker- 24 v care and feeding
It's a little hard to run your 2 stroke boat motor on a frozen lake so sales of it are down and no need to carry it. The Walmart by my place has it for $13.84 / gal. The lake around here don't freeze in the winter.- Machine shop
Call or go into a few truck/auto repair shops and find out who they use. They are only going to use reputable machine shops because the truck/auto repair shop's name is on the line if something goes bad. With the high mile you have you might want to have the head gone through and renewed. See what they say about inspection and repair. Order of work Clean , pressure test, magnaflux, inspect valves, valve springs, valves guides. valve seats. Repair, resurface, replace valve guides and springs if needed, reface/replace valves and valve seats as needed, new valve guide seals.- Ram 2500 5.7 Hemi dropped a valve seat
I came across this. https://www.ramforum.com/threads/how-far-can-a-5-7-be-bored.114818/ As for low cost cylinder heads all ready built, there are a few machine shops that did videos about how bad the heads were. You get what you pay for.- No fuel pressure but Fass pump is working.
When you say fuel system relay is this the relay supplied by Fass for the lift pump or the fuel pump relay, in the PDC, for the VP44? RELAY TEMINALS old number new number 86 1 85 2 30 3 87a 4 87 5 Most systems use terminal #86 (1) to energize the relay solenoid and terminal #85 (2) for ground.- Quadzilla transmission temp.
I put the trans temp sender in the line from the front of the trans to the oil/water heat exchanger. The truck is mostly used for towing a 8k lb 5th wheel. It takes about 10 miles to start seeing a reading and a normal reading between 155°-180°F depending on ambient air temp with 190°-210°F in stop and go traffic or backing up.- Days like today lots of snow
You and @MoparMom be safe in your travels today.- Trailer Wiring install '71 F250 Fummins
CONNECTOR TRUCK # FUCTION COLOR GAUGE --- # COLOR 1 GROUND WHITE 12-10 --- ADDED WHITE 2 TRAILER BRAKE BLUE 12 --- ADDED BLUE 3 TAIL/MARKER BROWN 16 --- 285 BROWN 4 BATTERY RED 12-10 --- ADDED RED 5 L-TURN/BRAKE YELLOW 16 --- 283 YELLOW/BLACK 6 R-TURN/BRAKE GREEN 16 --- 282 GREEN 7 BACK-UP/AUX ORANGE 16 --- ADDED ORANGE The red wire is use to recharge the trailer battery and supply added power for additional equipment such as a power winch. Determine the load and install 12-10 gauge wire with a corresponding 20 to 30 amp auto-reset circuit breaker. The added white wire is used to ground the trailer's electrical system to the truck's electrical system. The wire gauge should be the same size as the largest power wire, brake or battery, 12-10 gauge. Grounding the white wire at the battery negative terminal will give the best system performance. The wires for the trailer's turn signal/brake, marker/tail and back-up lights can be run to and fused in the extra PDC before going to the extra pin connector. Indicated below are a couple of places the truck wire harness can be spliced into for these lights.- fighting through my scenario............
So many going to hell that they had to build a highway. So few going to haven that there is only a stair way. greater lesser both evil.- Trailer Wiring install '71 F250 Fummins
Trailer brake controller installation is straight forward following the instructions provided by Tekonsha. I'd use the 20 amp auto-reset circuit breaker and the black, white and blue wires be 12 gauge with all connections soldered and sealed.- DAP Injector Upgrade 7 x 0.010 @ 320 Bar
So what it come down to is number of holes (X) times size of holes (.Y") at pop pressure (Z bar) will equal a smooth running no smoke engine. If this is the case then it should be graphable.- Days like today lots of snow
I've never had to shovel rain.- Gummed up VP44
The best stuff for cleaning deposits, varnish, and gummed up parts is a 'throttle body and intake' cleaner. It melts deposit and varnish off of parts. Mineral sprits won't do it, I've tried it in my solvent tank and after a day the deposits were still there. Mineral sprits as well as diesel fuel will work as a degreaser.- Days like today lots of snow
It's been 44 years since the last time I shoveled snow from my driveway. Do I miss it? I'll let you know in another 44 years.- Trailer Wiring install '71 F250 Fummins
This is to put you headlights on a rely and take the high amp load off of the headlight switch. If you're running H6024 halogen blubs then the high beam amp load would be about 10 amps at the switch. With the relay it will be about .2 amps. 18-16 gauge wire will be fine with a 15 amp fuse. The fuse and relay can be mounted in the spare PDC. Cut the red/yellow wire about 2"-3" from the connector at the headlight switch. Connect the red/yellow wire from the head light switch to terminal #86 of the relay. This is used to energize the relay solenoid. Connect terminal #87 of the relay to the red/yellow wire that is left and goes to the headlight dimmer switch. This will bring battery power to the head lights when the head light switch is turned on. I'll have another diagram for the brake controller tomorrow, I hope. In the diagram below the wire runs are numbered with the number corresponding to a color. - killer dowel pin question
