Everything posted by IBMobile
Screeching Noise From Rear of Truck
The best way to test a U-joint is to unbolt the drive shaft from the differential's companion flange and move it about on it's two axis. It should move freely in all directions with no binding or play between the bearing cross journal and bearing cup. Unbolting the flanges should only take a few minutes. This inspection will either confirm or rule out a problem with the U-joints. Be sure to set the park brake, if it works, and chock the wheels.
Alternator diode heat
Can we get some ohm readings posted to see if the resistance of the grid heaters increases with just age, mileage or on/off cycles. This would be a good indicator to whether a given ohm reading is pass/fail. Just tested mine and both came in at .1 ohm with 109,000 miles, used mostly in warm So Cal.
Winter is coming - Did you change the air in your tires?
There or on eBay from a little store in Quebec for our Canadian friends, eh.
Yes, for a trouble free 4 wheel drive winter experience change out the original vacuum hoses. Be sure to install only Mopar factory winter hoses.
Air Impact Wrench Recommendation
Both my 1/2" and 3/8" pneumatic impact guns are Ingersoll Rand.
Back from 10 days of fishing in the Sierra Nevada mountains and this is what was in the campgrounds, the twins. This is at 7100' and night time lows of 26°-33°F.
brake bleeders
I use a vacuum bleeder and stopped the air sucking by taking the bleed nipple out and wrap the threads with Teflon® tape.
Source for Thermostat Seal Cummins # 3942454
I used one from a Volvo thermostat the other day when I was flushing my cooling system. I bought a bag of them from one of my suppliers for about $1 each. If you want to try one I'll mail it to you.
Transmission dip stick question
My trans doesn't have this problem. It could be that your transmission vent is plugged up. When the transmission heats up the air expands and pushes the dip stick out.
ATF Oil Change. Service Manual Capacity Incorrect?
I did a trans service last month. I let it sit over night then sucked the trans fluid up through the dip stick tube then dropped the stock pan, more fluid came out. I then did the band adjustments, replaced the filter and refiled it with 7.5 qt.
Good buy or no?
- The Future of Trucks
Go outside and look around. They're out there. I was at the Volvo dealer yesterday complaining about the cost of a battery cable: 2/0 about 14" long with a fusible link at one end, $124. If the front turn signal led blubs in a new Volvo go bad the complete headlight assembly has to be replaced at over $800.- Dash cover
Is that a competent potty trained 2 year old? I made a glue/filler out of broken pieces from an old trailer AC cover that was melted in a jar of acetone. I used this to fix a small crack in the front cover of the 5th wheel. It worked good.- VP44 Keyway Dropped into Gear Case
With the cover off this would be a good time to take care of the KDP, Killer Dowel Pin.- Turbo moaning with boost
If my turbo whistles I wouldn't hear it. I turn my hearing aids off when I drive: this makes my truck nice and quiet.- 2001 Cummins has HickUps Engine Quits then Runs (P1689 code solved)
I've reset my monitors by driving on the freeway at 65mph for 5mi one way and then back home, stop and let engine cool. Do this three times and by the end of the third time the monitors are reset.- I Need Some Advice
Don't put any money into it. You never get it back out.- Can you do this?
I can poor oil like that....all over the outside of the engine and none going in.- Wierd idle
@Dieselfuture could you please do a wright up about the Ford and top hat seals and put it in the 24valve engine section. The next time some one needs help with seal it will be readily available.- New Injectors + new codes + zero throttle
My axle ratio is 4:10 (4.1 turns of the drive shaft to 1 turn of the axle) and my tire size is 245/75R-16 giving me a final ratio of 4:22 which translates into a little higher RPM at cruising speed and a lot of pulling power.- New Injectors + new codes + zero throttle
I'm using the Edge EZ with the jumper set on #2 and RV275 injectors with zero smoke problems. I tow an 8,000lb 5th wheel and I don't want to overwhelm the almost stock 47RE transmission with more power.- Looking for how-to on the PCM ground...
@rotorhead here you go. It's on page 4 of this long thread.- Rear Brake Hard Line
Cut out the bad section with a mini tube cutter and splice in new tubbing with compression fittings. You can find new brake line repair kits at any auto parts house. Home Depot sells the tube cutter in the plumbing department.- Diesel "The Dog" - Rest in Peace
Sorry to hear about the loss of a friend.- Fuel Tank Module Check Valve
The Bosch or mini type relay is common and can be purchased in any auto parts store. Napa relay part #ECH AR272 is ratted for 30 amps and has a resistor suppressor. This is a mini relay with suppressing resistor and mounting tab "Common in" refers to pin #30 where in this case the 12 volt power from the battery comes into the relay. - The Future of Trucks
