Thinking of upgrading my Edge W/Attitude. Suggestions?
I'm only anti-Edge Juice. People tend to mis-use the alarms and limits and create a performance issue, laggy, loss of power on the upper end, etc.
Whats going on in southern Idaho?
I didn't feel or hear anything... Yeah I know I'm a long ways from it too.
COLD
Even still almost 3 hours later its 18*F and 88% humdity outside I know exactly what you mean about blowing through your bones.
Ripped intercooler boot
I checked with Vulcan Performance and they are like NAPA for price. Sorry to say its going to get a bit pricey...
NAPA??? I just checked over there the web site price is high. But try anyways...
lf9028 and what oil?
At least the 2nd Gens can run a full 7,500 miles I'm pretty sure the 3rd Gens have a slightly longer change interval.
COLD
Here at the house is 18*F... http://lb.511.idaho.gov/idlb/rwisstations/rwisstation.jsf?id=9&view=state&text=m&textOnly=false
As far as I know just the display changes. The software should all be the same.
Winter is finally here!
Here is what I've got coming...
COLD
Down to 28*F right now. http://forecast.weather.gov/MapClick.php?lat=45.24525270653619&lon=-116.3321042060852&site=mso&unit=0&lg=en&FcstType=text#.VKIOmbADA http://weatherspark.com/#!dashboard;loc=45.2363,-116.3274;rd=12;ropts=speed:12,loop:1,alpha:0.7;fcs=0;msl=pressureAltimeterMbar;mol=radar;units=temperature:f;graphs=spaitg:1,pressure:1,precipitationRate:0,siitg:1,stidpg:0,smeisg:1,solarPosition:1,humidity:0,saf:0,subZero2:0,windIcons:1,sdpitg:0,windDirection:0,precipitation:0,windSpeed:0,clouds:0,tiles:0,precipitationAmount:0,temperature:1,dewPoint:0 Forecast for -2*F tonight brrr....
Isspro oil pressure sender location.
??? But the stock oil pressure gauge sender is mounted in the next hole back from his picture.
Finally this last storm has dropped a bunch of snow finally. I was starting to wonder if I was going to have a green lawn all winter. The little 1996 Dodge is doing just fine! Chains are for sissies!
House Fire Call in Riggins, Idaho
I was called to a house fire last night in Riggins, Idaho. This one is rather odd. The owner just bought the house just a few weeks ago and also just after the purchase of house he installed a brand new energy efficient wood stove. The last night went over to stoke up the fire and when he opened the stove door the stove back drafted on him. When this occur it burned the home owner from the flash of fire also it ejected other flaming material out into the room. All I can say is the house is a complete loss. The theory on cause is possibly using un-cured wood that is way too wet. Or... Improper operation of the stove choking it down really low to save wood. Please people be careful with heating appliances...
FASS filter cross reference
Could I get you to post this in the article database for me? (Please!)
Rough idle then dies
Timbo's APPS doesn't have a voltage to set. You can mount it and do a APPS reset be good to go. The adjustment process only for taking slack out other than that it has no bearing on the performance of the Timbo's APPS sensor. As for diagnostics for the rough idle and dies. What is your fuel pressure at idle and WOT at highway speeds. Any error codes present? Check with OBDII reader.
CCD Failure Help
Just for the sake of it here is the CCD network wiring again. http://articles.mopar1973man.com/general-cummins/34-engine-system/81-ccd-data-bus
Who's Burning?
Maybe 10-12 miles. I live in the wild country as you put it.
I'm pretty sure that is a oil gallery. The stock sender is mounted on that side too. But I think you going to run into issue with the rust threads.
Part name
Might of taken too much Florida salt?
Where to start with a no start problem?
Diesel require 2 things to run. 1. Compression 2. Fuel So working on the fuel side. Does the Wait To Start come on instantly? Do you have fuel pressure from the lift pump? Do you have a fuel pressure gauge? How about any error codes?
CCD Failure Help
Thanks Hotboater for jumping on the forum. I suggested that he try Yankneck's idea of cycling all plugs 3 times with di-electric grease to hopeful recover the connection some where. Seems odd that the OBDII port is still bringing data to devices from the device that have problems? But then the cluster is non-functional. Help me out guys.
Who's Burning?
LOL. You should see my neighbors then. They just cut down a tree about one month ago, left the rounds laying in the weather. Then go out spit and haul to the house as needed. My wood is typically split and stack in early spring in the wood shed so all summer long the summer heat is drying my wood. Now the left over wood in the yard now is no going to be burned till next year. But there is a difference out here the soft wood dry really fast. I've fell trees and loaded then on the trailer and hauled them home. Just from the summer heat the wood is splitting open in less than 24 hours its got cracks in it. Local trick is if you can hit a piece of a wood with a splitting maul and it pop the piece right off with a easy hit then the wood is good in dry. But if you need a sledge hammer 2 splitting wedges and pull the pieces apart the wood is still too wet. Even with a wood splitter if the wood is wet you'll see the water squeeze out or the wood is stringy. Now the few bits of hard wood (Birch, Apple, Cherry, and Apsen) I've gotten yeah I will agree it takes a long time to season that stuff. Mostly why I tend to chase the soft wood. I only fall dead and dry trees. I really do hate to load up wet anything because you get less of a load. 3 foot x 16" slice of spruce looks heavy but when I harvest it its rather lighter than you think because its dry. Here is my last load of 2014...
Who's Burning?
Aren't you lucky. I've already burned 2.5 cords already. As for my chimney it was swept out at the beginning of the season and like usual it was a mound of black chunky creosote. It typically takes the shop vacuum and suck it out of the wall. Even though I run the pyrometer all the way to 1,600*F with a roaring fire, pipe tinkling, popping noises in the pipe, etc. But still in all plenty of creosote. I bet its the wood we burn out here vs. the hard wood you burn.
new truck 2013
Might toss it up on the Classified section for others to see.
