CTcummins24V
Everything posted by CTcummins24V
  1. Have the sensors in the tranny ever been replaced? As Mike stated governor solenoid, pressure transducer and band adjustment. Cascade has a whole kit. It is recommended to replace those sensors whether they need it or not every 50k miles. http://www.cascadetransmissionparts.com/a61847rh47re.aspx
  2. Welcome fellow New Englander
  3. Paypal, 6 months to pay it off interest free. DAP uses it
  4. Replaced the hard line from the tranny to heat exchanger with fittings and hose, because mine was bent and a pain to line up the threaded ends. $63 from Jegs -8 AN= 1/2" Fittings at transmission- 1/4" NPT to -8 AN and -8 AN 90 degree bend push loc Fittings at heat exchanger- 3/8" NPT to -8 AN and -8 AN straigh push loc 10' of -8 AN(1/2") parker hose
  5. Turbo specs? 60/60/12 gated?
  6. So when are you getting a pop testing device and start popping and rebuilding members injectors?
  7. I think that's the one I used, pretty sure it's Larry Bs. When I got my truck with 202k the starter was sticking. Rebuilt it, no issues in the last 25k miles.
  8. Looks new to me. Made in India though
  9. I got one the about 2 months ago... https://puredieselpower.com/dodge-products/98.5-02-cummins-oem-paintable-cast-aluminum-valve-cover.html
  10. Dammit IBMobile, we're keeping jobs in America!
  11. https://www.napaonline.com/en/p/PSR9832?searchCategory=700.7011&searchIndex=Prod Chrysler MS5931
  12. http://www.torkteknology.com/cummins-injector-puller-kit-1998-5-2002-pn-cip040/
  13. If you don't need the extra ground clearance, subaru outback. My wife has a 2011 4 cylinder nonturbo wagon, averages high twenties around town, 33-34mpg highway. My mom has a 2006 wagon, almost 300k, original motor and tranny, averages about 25mpg. Never got stuck in a New England winter.
  14. I had ebc green stuff, I think, ceramic, didn't like the stopping power loaded up. Rolled through a stop sign or two when there was significant weight in the bed. They heat up. However, my 1/2 ton has ceramics with no issues, but I don't haul/tow the same weight as the dodgey.
  15. I'm pretty sure borgeson doesn't make the 2nd gen box anymore.
  16. Stock tranny/valve body? You can have a hard 3-4 shift if the 3-4 spring is broken, which is common. If you're going to drop the pan anyways for a filter change, you can take the 3 screws out from the 3-4 accumulator housing and check the spring. 3rd to 3rd lockup can be "harsh" and 3rd to 4th can be "harsh" if you have a triple disc and modified valve body. http://www.cascadetransmissionparts.com/a61847rh47re.aspx
  17. Gotta love it. I respect people's choices and liberties, that's the beauty of this country! But, I am sick of this getting crammed down our throats everyday in the main stream. Like that make up commercial with all the women and then the guy whos a girl, or dressed like a girl with make up, I don't even know. You can thank all the "do good feel good" politicians and activist groups, and wonderful heart filled brainless people that support them that don't stand for anything.
  18. Good question. I dumped oil in the doors and packed grease in the folded lip and the rust hasn't grown. How to fix it? No clue.
  19. With DAP 60s and edge ez on highest setting (level 3, which is comp 2 level) I also had smoke until the turbo lit too, only with heavy throttle.
  20. http://www.rockauto.com/en/moreinfo.php?pk=6759336&jsn=13&jsn=13 $275. I paid less than that last summer from rockauto. You will need to buy the nuts separately.
  21. What do you have for a torque converter? Single? Triple? I had a billet single slipping (grab and slip grab and slip) in 3rd lockup and 4th lockup. Felt like slight shuddering, especially up hills.
  22. Correct me if I'm wrong, but the teflon tape is just a band aid. If the the nut to head connection is leaking that means the hard pressure line to connector tube isn't sealed. Local cummins is usually cheaper than online if you get new connector tubes.
  23. You guys are just upset because your home team didn't make it haaa. That was the only game I watched all year.
