dripley
Retired Staff
Everything posted by dripley
  1. Got tomwork this morning and my laborers showed. Much to my surprise, an unexpected person is here. You are not as tall as I thought you would be.
  2. The alphabetical Things you see should have a dotted underscore under them. Just put your cursor over them and an explanation is revealed. Like RPM. Try it.
  3. i would not worry about 200k. I am at 450k and just now facing it. though I could be pretty lucky.
  4. Someone correct me if I am wrong here, but to expect 90hp injectors to burn clean with no lag on a stock truck is a lot to ask. My 50's with the comp are smokey and laggy if I just stick my foot in it, If I take a short roll into the throttle and let the boost build a bit before I stick my foot in it I can limit the smoke and the lag but you have to use your foot for a governor on both. I get pretty good results for me with that method.
  5. Have you spoken to DAP about the problem? If you want a decent kick in power and are a ways away from a tuner, get you some new RV275's. You will not be sorry. They are very good injectors and should give you a good life. Not sure what NEW 75hp injectors you are seeing on DAP's site. I have a set of their 50's, with aftermarket bodies, with 100k on them that are just now showing some weakness. The RV's are great on a stock truck or with a mild tuner.
  6. No pictures here but after 458k miles mine still has no play in it. One thing that stuck with me after buying the truck and taking to one of the service techs was to let everything cooldown after a long pull or drive. Did not understand why at the time but it stuck in my head.
  7. I dont believe a leaky return line can cause a miss. Loss of prime and extended starts yes.
  8. 8 I would be suspect of the ECM rebuild. I went thru 2 from Automotive Scientific Inc out of Florida. The first tripedthe 606 code that the OE one did not tripand the second under warranty that lasted about one year. It just died driving down the highway, no warning what so ever. If the wiring checked as good as you say it did, will a new harness do any better? I did a little research into Auto Module Source. I found glowing reviews and really negative reviews. The ones that caught my attention were on the BBB site. They went back to 2016. In 2016 they were very buisness like and apolagetic for the problems in the responses, but 2018 the were blaming the customer and un apolagetic. In fairness to them some of it was the customers fault. The one that boggled my mind was the gentleman that recieved two PCM's that he was sending back to them for refund. Upon receipt of the package they said they weighed and it was not heavy enough to be 2 PCM's, so they tossed the box in the trash without opening it and would only credit him for one. In fairness to AMS I realize that negative reviews are most times easier to find than positive. And the reviews I found did not state what kind of vehicle these modules were for. I am just naturally suspicious of electronic rebuilders in general unless I know some real history on their products. @pepsi71ocean has been working on and has posted an article on this very subject.
  9. that looks more like a gutted fish than the underside of a dash pad!! What does that thing weigh, 50 pounds?
  10. Something aint right. Either the pump is upside or the wrong one. There is no PSG on top of it in the picture. I would check into it more. Give them a call.
  11. Happy to hear she is up and running.
  12. I believe the early model 24v have both. Not sure on years though. I would ask who tested and rebuilt your ECM?
  13. The 1693's are just telling you the companion modules each have code. Just ignore them they are not blaming each other. Good fuel pressure and a gauge are a must for these trucks. Good advice above before you start spending alot of money.
  14. Thats good to hear. Been worried about him. Glad it is electronics and not something else. Thanks for the update.
  15. Good to hear. At least we were barking up the right tree with the MAP sensor.
  16. I ran Banks tuner, 75 hp and tapped the pump, with the RV's puling 15k 5th wheel and did good job. 6 to7% grades could be done in 5th at 50 t0 55 mph. It was a good set up. I did switch ovet to a Comp, but only ran it levels 2 and 3 wnen towing with very similar results. Mileage was around 11 or a touch over with good power. Funny thing about wanting a couple more gears is when a 4 speed I was always looking 5th, got 96 Dodge with a 5 speed and starting looking for 6th. Now i have had a 6 speed for 17 years and still occasionaly find myself looking for 7th. I do wish I had a gear between 5th and 6th for towing.
  17. I would have to ask the same. Mine was cracked about that bad and I did replace it. Could not help but think if I repaired it that it would just crack somewhere else. I know my bezel did.
  18. Food for thought on hearing the pump. I just put a new pump head on my AD and i cannot hear it run. The only way I know its running is the my pressure gauge shows the pressure. I have not had an oe pump pump since 06 to remember how much noise they make. Even with my pump blown the truck would fire right off. The VP will pull its own fuel though it is not good for it. I still think you have a small loss of prime somewhere. Still going to be hard to find the problem if you cant work on it. Wish I knew some body to take it to but I dont.
  19. We still have the butcher bill to pay from 2008 and just keep adding to it.
  20. I just hope we in the US dont end up looking to Greece for advice on hole we are digging.
  21. I was figuring for myself to just switch the power leads off of the battery. Just something simple to turn them on and let the ECM regulate until I turn them off. Start the truck, let them cycle a couple few times and then turn them off. That way if I did leave them on the ECM will shut them down before any damage is done. That is Sparky the chicken's idea anyway.
  22. Probably the wrong place for this but I have ask. Is the UK running huge budget deficits as we are here in the US? With those tax rates I would hope not.
