Everything posted by IBMobile
1998.5 Cummins 24v Surging
So you have new batteries? Check the wire grounds under the driver's side battery. You might have to pull the battery and battery tray to get to them.
Truck stuck in 3rd gear limp mode
When you have the pan off disconnect all the solenoids and transducer, turn key on. If the fuse blows before any component is plugged in then there is a wire shorted to ground. Now plug the old components back in one at a time and be sure their bodies are grounded. When the fuse blows you'll know which component is bad. Power to pin 30 of the transmission control relay comes from fuse I (20 amp) in the PDC.
2 Different Boost Readings - Bad MAP Sensor?
This might explain it. https://mopar1973man.com/topic/14708-iquad-boost-readings-lower-than-boost-gauge/ https://mopar1973man.com/topic/16186-quadzilla-v2-reading-inconsistent-boost-under-load-on-1999-24v/
Mishimoto trans cooler
Two week ago I was towing my 5er with the boat behind, it about 16k LB. Got caught in stop and go traffic for 3 hours north bound I-15 going up the Cajon pass. Tranny temp, post converter, climbed to 250°F and stayed there. Wish I had and extra trans cooler then.
Here are a couple of members that have installed a Derale cooler https://mopar1973man.com/topic/14095-derale-aux-trans-cooler/ https://mopar1973man.com/topic/17573-derale-trans-cooler-install-and-test/
Isspro fuel sender
Yes
Isspro fuel sender
I started loosing fuel pressure at idle over a couple of years 17PSI and now down to 8 PSI. 18-19 PSI at 2000 RPM and drops to 16 PSI under load. I checked the "fuel pressure regulator" saw no problem; I've blown out the fuel lines with compressed air then tried clamping off the fuel return lines with no increase in pressure.
Derale is another high quality manufacture of fluid coolers. https://derale.com/ If you get a cooler w/fan be sure to have a fan controller or thermostatic on/off switch.
ssion coolerThat's a lot of money for "supposedly better cooling capabilities". When driving down the road The torque converter is locked up, generating little heat and good air flow over the cooler. Most heat increase occurs when accelerating, backing up, or in stop and go traffic especially when towing. During these conditions there is little to no air flow over the transmission cooler so an increase in size and volume would provide a marginal decrease in transmission temperature as opposed to a cooler with a fan. https://www.mishimoto.com/heavy-duty-transmission-cooler-kit-electric-fan.html
Is your oem cooler going bad or do you just need extra cooling capacity? If it's extra cooling you need get an extra trans cooler with a fan.
Last job I'll ever need...
Good luck for your new job! Enjoy success with this new venture.
Dash repair
How much would a dash from LMC Truck cost? http://www.lmctruck.com
I think I got a decent deal on a dually bed
Yes, Bed is just pressed sheet metal with no strength for towing.
$400 sounds good to me. When i was looking to repair/replace my bed a repurposing facility (wrecking yard) had one for $800 installed. It had a BIG dent in the panel that is behind the cab and pealing paint.
Summer is coming!
Here is the fix for that ground splice at the PCM. PCM Ground Splice Repair - Electrical - Mopar1973Man's Dodge Cummins Forum https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/pcm-ground-splice-repair-r675/
Summer is coming!
Don't forget the blinker fluid.
Turbo Compressor Dirt
Here is an article @Tractorman did on making the BHAF a little bit quieter. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/air-exhaust_56/bhaf-muffler-uhh-r612/
APPS
Yes! Timbo APPS sold in the site store but out of stock right now. Mike is working to get more. https://mopar1973man.com/store/product/62-timbo-apps/
No power in reverse
I have a HX35 turbo and an 800 RPM stall convertor with no problems backing an 8K 5th wheel up a steep driveway into my backyard. The rear transmission band may be slipping. Put the transmission in manual 1st and accelerate checking for slippage. Only reverse and manual 1st use this band.
My truck almost killed me today, Don't look if if you don't like seeing carnage
- My truck almost killed me today, Don't look if if you don't like seeing carnage
One bourbon and one scotch would have help that beer kill the pain. You're right! We're all ways getting an education in the school of hard knocks. I've been in that school for so long I'm getting my doctorate.- Fan clutch locked up
Free tool rental at O Reilly auto parts 441 US highway SW Hickory, NC https://www.oreillyauto.com/detail/c/evertough/tools---equipment/rental-tools/rental-tools--air-conditioning---cooling/12095d53bcad/rental-tools-evertough-fan-clutch-wrench-set/ren1/67063/v/a/139817/automotive-suv-2017-hyundai-santa-fe?pos=2- Turbo Compressor Dirt
Did you see this thread? https://mopar1973man.com/topic/18490-dirty-turbo-vane-and-what-to-do-about-it/- Pacbrake Install - ECM Signal
Pacbrake 2.5gal tank part # HP10093 $80-$95 Pacbrake 2.5gal tank w/kit # HP10050 $204-$208- Preparing for road trip.
I do the same pre trip prep; check this and that, pack a few spare gizmos (like a TPS) ; none of them have helped. One trip the VP44 went out in Riggins ID, then there was the crank speed sensor that went bad in Moab, UT, another time the lock up clutch in the torque convertor went out in Beaver Creek, OR, last was the right front wheel hub at @Mopar1973Man house. My wife insists on bringing her own mechanic with her but she wants him to work for free. - My truck almost killed me today, Don't look if if you don't like seeing carnage
