Everything posted by guesswho512
strange code
that code is for crankshaft sensor. i found some tips but it for chevy diesels. http://www.dieselbombers.com/chevy-gmc-duramax-06-07-lbz/31179-p0336-crank-position-help.html
Time for ball joints, alignment
mine is the same way. and i have a 2wd. on the last 1.5yrs i have changed the whole front end. the biggest difference was when i changed the steering gear box. my local part store(oreilly's) only stocked remans (by the brand CARDONE). at first it was AWESOME, but over time the slop and extra work came back. the gear box has a lifetime warrenty, but i have been to lazy to remove it and take it back. as far as the moog balljoints. i have their uppers and lowers on both sides. they have been good so far
3,000 or 7,500
the oil filter is not the same as a fuel filter. the filter has a by-pass valve inside it to prevent oil pressure loss. as the filter becomes clogged to slow the oil pressure, the valve opens to prevent pressure loss. after a point the full flow filter is not filtering anything.
Looking for some help on how to change a rear wheel hub on a 1996 3500
- As The JL Welding World Turns
if it's cracked in the usual spot, then it should run fine. depending on the crack it could be a few drips to a sieve. with your luck, if it has any problems other than a water leak, leave it alone. what is your plan to repair the crack?- Piss poor and more......
lmao. i was surprised that a knew a few of these. many of them caught me by surprise, like the "yearly bath" . no wonder some of the conquered civilizations thought the western man was a barbarian.- 12v vs 24v truck
emissions....the computer only care about meeting the emission laws at the time the vehicle was made- 285/75R16 any clearance issues
i had 33x12.5r16.5 on the back. i lost 1-2 MPG when i put the factory tire size back on. not everyone loses MPGs from big tires- Oil Change
- 3,000 or 7,500
7500 miles for me. my 91 honda accord also has a 7500 mile interval also. 3000 mile oil change is a myth created by oil companies. most vehicles i have driven actually had a 5000 mile scheduled intervals, or higher- Track Bar Question
some people go with luke's links. their kit does NOT work with MOOG track bar. only dodge and NAPA track bars. go here to download the instructions, and see if its something you wanna do: http://forum.mopar1973man.com/downloads.php?do=file&id=80- Getting rid of the 24v
the cts is a bad mamma jamma....a coworker bought a new 1 in ~06 with a 3.6 gasoline direct injection. lets just say that 140mph down I-10 happened quite often. with the traction control on you cannot spin the wheels(no matter how hard you try), but with it off, you can break them loose with NO effort. i don't know if the VVT is thru the use of "extra" cams or hydraulically controlled. the whip picked up more poon than you can shake a stick at- MPG fooler - Design phase
i think we need to figure out if the VP44 even reports the timing to the ECM. i have read that the FPCM (fuel pump control module, ie vp44's computer) has final say in fueling and timing. if it does report it to the ecm, then it would be possible to monitor it.if i am right, anything on the CCD bus has "access" to everything on the bus. each module only looks at a small spectrum of the bus. like a television. you may be able to pick up several station, but you can only watch one channel(the one you are TUNED into) i believe that all info could be accessed if you have a device that can "tune" in to the proper frequency. i have had limited success using the ELM327 as it gets its info from the ECM/obd.- Posi Lock Cable
low gears = more torque2LO = low gears(from transfer cases reduction) - 4 wheel drive- breakdown
well that would explain no communication....glad to hear that is fixed. i hope your clutch is all that is left.- What year factory rims will fit a 98.5
- Oil Pressure
- Wiring harness melted
- Mpg
so what is the vent mod?- Happy Birthday, bjytech!
- Which batteries??
i got the wallyworld batteries. what is it, EVERSTART MAXX. i don't know what group it is, but is 1000ca each. only $75 a piece. walmarts are everywhere and it was ~$20 cheaper than all the part stores i found. even some of the new walmart don't have tire and lube, but still have an automotive section with batteries- 2006 Transplant no start
- Editing Thread Titles, anyone oppose?
just don't break the linksbesides i thought the moderators jobs were to make sure the thread says on topic(ie the title)- Weird line from the sun
click the link- Weird line from the sun
its project HAARP they can heat the atmosphere into a plasma and communicate with submarines anywhere in the world. russian nukes could be melted if in the flight path. they can put enough energy into the atmosphere to create its own aurora. where is my foil hat again? - As The JL Welding World Turns
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
