Everything posted by IBMobile
Weird fueling issue
#1 and #4 is the fuel draining off. I'd still start with replacing the sealing washers for the return line at the back of the head even though it shows good. Next put some new injectors in it. The truck most likely has some old injectors that are worn out. Try some RV275 injectors, they a mild up grade with new o-rings and washer when installing them.
Derale trans cooler install and test
Looks good, nice job mounting it to the bed frame. 250° is cooking, it will be interesting to see what it is now during a hard pull.
Rear window glass removal/install?
$45, no brainer, let them do it. If they break it or it leaks they own it.
Moose Horns (Towing Mirrors)
Nice, are they powered, heated, sequential turn signals and have puddle light all for $160.00 a pair?
Received an unexpected surprise!
That's having a friend with benefits, nice.
Fass 165 install help
- M73M.Com get together at Mopar1973Man's
I had a great time at Camp Mopar1973Man RV Resort and Truck Repair. Camp sites are spread out for social distancing with lots of elbow room. We even have electricity If your truck breaks down there is a covered work area with tools. There is even an on site mechanic if I need one. And the people are all friendly and the fees are reasonable. I highly recommend this resort to anyone traveling through.- Idles only
I'd be looking at what @hdpwipmonkey said.- in tank fuel pump amp draw help
Amp draw test. https://www.hagerty.com/media/maintenance-and-tech/measuring-current/ A cheap Harbor Freight multimeter will work. https://www.harborfreight.com/automotive/diagnostic-testing-scanning/7-function-digital-multimeter-63759.html- Cannabis
- W-T ground mod
The distance from the alternator to the right battery with a circuit breaker/fuse in line is just over 24" ( 2' ); 4 awg will carry 180 amps 72" ( 6' ) safely.- Heater core or something else?
Heater Treater for heat/AC blend door. I installed one in @JAG1 truck two weeks ago in conjunction with the heater core and AC evaporator replacement. Note: when installing a heater treater, before removing the dash and HVAC housing, turn the ignition key to on and set the heater controller knob to the middle position. This will make putting the case back together easier and the motor will be indexed. http://heatertreater.net/dodge-ram-95-02- Did I fix everything?
My VP44 took a dump, with out warning, while driving down a long grade at 55 MPH; the engine just died. The control board went bad with just over 90k on it. It was the original VP and there was never a yellow anti-tampering tag on it.- Did I fix everything?
One trip I took the VP44 went bad, Mopar1973man had one delivered to his house and we installed it at a campground near by. Another time, in Moab, U,T the crank sensor went bad and found one at an O'Reilly. This last time had the right front wheel bearings go bad on the way to Mopar1973Man's house. Mike picked up a hub for me in Lewiston, ID at an O'Reilly and I had all the tools with me except for the socket for the spindle nut, Mike had one. So, if something brakes when your on the road you can get the parts in a day or two and may be have the tools or get them also to fix it yourself. Be safe, have fun, and enjoy the adventure.- Replace Rear Axle Seal
Info like this should be written up as an article so this good info is easily found.- *Oil Consumption 5.9 Cummins with 87K-Valvoline Premium Blue Restore Oil*
I would. It would give a idea of the valve and ring health. If low compression is found then do the leak down test on that cylinder to determine the problem.- Cracked manual trans mount
Only if they took their truck to Clown Garage. By the look of it and what you said that clown broke it, "welded" it, and hoped you would never see it. If he kept on doing repair work for you no one else would see it either, And you get to drink beer while doing it.- Heater core or something else?
Course ground black pepper good for over a year in a Toyota on Guam.- in tank fuel pump wiring help
Never mind fooling with the unknown and make up your own wire harness; that will take the guess work out of what color wire goes to what. The article below may help you make a harness. @dripleyI've been in JAG1's driveway for the past 10 days redoing the roof on my 5er with him while I redid his heater core and AC evaporator in his work truck. He has wifi but where I'm located on the driveway it is really slow.- Best place to get power for switch box
Write what your going to get on the back of your hand next time. For lighting you can get power from the blub for the ash tray. You can run all the wiring through the rubber grommet on the left side of the fire wall. A few extra feet of wire for some applications but no drilling, no rust.- Heater Core
This is true. People have to evaluate the condition of their HVAC box and ability to perform the task then take action accordingly. For some trucks, the driveway queens, just pulling the heat core is all that is needed. Trucks that are in forest or farm conditions all the time will most likely need a complete remove, clean, and refit. Yes, I remember @flagmanruss. He lived out in the woods of Coventry, RI,- Heater Core
@JAG1 and I pulled the HVAC box this past week. What a PIA. Your evaporator doesn't look that bad. The evaporator was blocked about 15%, not real bad. If all you need to replace is the heater core then just replace that with a core that has swivel tubes, that's what we used, then clean the evaporator, ,install those Genos cabin filters like @Tractorman posted and call it good.- Comprehensive Component Monitor has me stumped
From the FSM is for check engine light and trouble code (P code) self erasure with 40 drive cycles. Now the condition the OP and I are addressing is resetting the monitors not erasing the p codes.- Doing the WT ground mod
This show the voltage and amperage on the blue wire from the PCM to the alternator at idle with the headlights on with high beam, the heater fan on high speed, and radio playing; that's a 4.5 amp power draw. If the load on the alternator load increase there is a chance the 5 amp fuse will blow so I sized mine to 7.5 amp.- Comprehensive Component Monitor has me stumped
Before having the the state mandated emission test performed 0n my truck I've reset the monitors with 3 drive cycles after clearing a P code. This has been done several times over the years. - M73M.Com get together at Mopar1973Man's
